Question about Jura Capresso Impressa E70 Espresso Machine
I have got ants in the machine. how can I get them out? can I open up the cover?
How do I clean my Jura f50 before the machine tells me to? It is full of ants.
I can't help you with the coffee maker but I can help you with the ants. Mix boric acid with a little wet cat food and leave it out that will kill the ants back at the colony they carry back the food and the whole Colony ends up eating it and dies if they are sweet ants mix the boric acid with sugar water and make a paste same thing will happen
Jul 01, 2017 | Coffee Makers & Espresso Machines
Ants in my Keurig
I had the same problem after getting a Keurig model 525C and took it back to Costco, with ants still in the coffee maker. I haven't had this problem with other Keurig coffee makers. Keurig needs to come clean and admit THEY have a problem with at least one of their coffee makers.
Apr 25, 2012 | Keurig Ultra B50 1-Cup Coffee Maker
Well my Keurig wasn't working as fast as it used to and this morning when I went to add water...I removed the cover and a zillion sugar ants came pouring out of it. Right from the hole where the water...
I HAVE THIS SAME PROBLEM WITH ANTS IN MY KEURIG. I've had ants in the past during the springtime and I've never had a problem with any other coffeemaker being infested with ants. I saw two ants actually crawling around underneath the blue brewing light while the machine was brewing plain water! I've de-scaled it with vinegar and have run water through it over and over and over again. There are STILL ants in it. It's currently outside my home and I have no other ants in the house. I called Keurig just to see if they have heard of this happening and they told me no and that it's an environmental problem. That's obviously a lie because all you have to do is Google Keurig and ants and you can read of other problems. I think I am probably going to throw the Keurig away . . .
Feb 19, 2011 | Keurig B60 Coffee Maker
I am replacing the power antenna mast on a 2005 hyundia sonata...I have turned the radio on but cant get the cable of the portion of the old broken mast to come out
You need to remove the top cap cover, this is the ring on the top of the antenna that holds it to car then use some small needle nose pliers to pull the rest of the mast, if theres a broken part stuck inside then you will have to remove the ant and open the side to remove the rest of it, then reasmeblt unit and put back on car then slide new one in and have someone turn radio off as you feed ant in, if it doesnt go all the way in then turn radio on but dont let it come out then turn it back off fast and feed the rest of ant in, once its in place install the top cover ring to lock it in place. hope this helps.
Dec 24, 2010 | 2005 Hyundai Sonata
An ant carries food at a speed of 1 cm/s. How long will it take the ant to carry a cookie crumb from the kitchen table to the ant hill, a distance of 50 m? Express your answer in seconds, minutes and...
Since there are by definition 100 cm in a meter, the distance is 50x100 or 5000 cm. At 1cm/s it takes the ant 5000 seconds to cover the distance. There are 60 seconds in a minute, so it takes 83 minutes and 20 seconds.
Sep 14, 2010 | Casio FX-115ES Scientific Calculator
I need to replace my antenna with either an electric one or a standard one...how do I access the antenna?
inside the left rear 1/4 panel cover a 10mm nut holds the ant bracket, then unscwew the top nut at the ant base. pull it through the bottom unplug the ant lead and ground wire. easy said then done right !...
Oct 15, 2009 | 2005 Hyundai Sonata
Instructions for ant farm
http://www.unclemilton.com/company/manuals/AntFarmGelManual.pdf
You'll receive 25 to 30 non-breeding adult Harvester worker ants.
Important: Before you open the tube of ants, place the
tube in the refrigerator (not the freezer) for about 15
minutes. This makes the ants less active and easier to
place into the habitat.
When you're ready to add the ants, carefully
open the plastic tube and gently shake or tap
them in. Replace the habitat lid securely.
Mar 12, 2009 | Uncle Milton Ant Farm Gel Colony
The message is 'Inner cover is open. Close the inner cover and pr
try to power off and unplug ed the all data ant power cable for a few minute
and set the power and data cable and on the printer .
If it is doesn't work try to reinstall the printer divers
Feb 13, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Jura Capresso Impressa E70 Espresso Machine Logo
96 people viewed this question
Top Jura Capresso Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Steve
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
