Question about SanDisk Sansa e250 MP3 Player
Didn't work Your suggestion didn't work (although I appreciate the help). What else can I Do??
  • 8,596 Answers
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on Aug 14, 2008
Maytag fridge right door won't stay closed
it may be necessary to reset the hinge adjustment to move the door further across the opening giving the magnets a better area to hold on to . there is a slight amount of adjustment in the mounting points of the hinges. You may have to replace the door gaskets as they become hard over time and the magnets cannot work properly in the hard plastic
Jun 21, 2013 | Refrigerators
Error link to emc
First I suggest to check fuses; keep in mind that the OBD-II port didn't work because the power wire in the connector corroded and didn't have a connection anymore. No power equals no OBD worked.
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Aug 17, 2012 | 2001 Volkswagen Cabrio
Obd2 port not recognising diagnostic tester
Aug 17, 2012 | Hummer H2 Cars & Trucks
Car runs hot!!
I have the same car and had the exact same problem. I had the heads worked on, replaced the radiator, replaced the cooling sensor, replaced the thermostat, replaced a relay switch under the hood (in fuse box) and it was STILL loosing all the water and then running hot. Auto shop told me the fans were only cutting on, on low and I needed a whole fan assembly kit. $300 later and it's still doing it. Come to find out it was the overflow tank that leads to the raditor. The threads (where the cap goes on) were bad. (Although they didn't look bad at all.) Spent $30 to replace the overflow tank and haven't had a problem since. I hope this helps you out. I'm no mechanic, but I sure wish someone would have offered that suggestion to begin with. I've been fighting with this car since I got it in May and didn't have it fixed till Thanksgiving Day
Dec 27, 2011 | 2002 Chevrolet Malibu
Trans, won,t shift up automaticly,I changed oil, didn,t help.
I suggest check valve body solenoids or torque converter issue.
Hope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day.
Dec 01, 2011 | 1995 Jeep Grand Cherokee
Sparking at brushes
This isn't abnormal although cleaning the armature with fine emery or sandpaper can help.BTW, new brushes will always need a period of run-in before their contact with the armature has reached its best.
Nov 27, 2011 | Food Mixers
Here is my imei:353399046540526.send activation code
I didn't get your question. you didn't add your network provider. did u mean unlock code? if its unlock code take this:
Your Suggested unlock code is :
#pw+242545366006651+5#
Type: DCT4
Nokia Model: 6600
IMEI: 353399046540526
ASIC Type: 5
Box serial: 032811
Hope this works.
Sep 20, 2011 | Nokia 6600
2003 NSR125 lights all went out on the way to work this morning & Rev counter dropped to zero and didn't move although the bike didn't shut off as soon as i turned the engine off no electrics...
you will need to find out if the battery is being charged when the motor is running.if it isnt you will have to check wiring from the charging system.There could be a problem with the regulator/rectifier unit.
Jun 17, 2011 | Honda NSR 125 R Motorcycles
I have a neptune front loader, after the wash cycle is complete the clothes smell like they have not even been wash with a **** moldy smell. I use Tide HE as directed but they still smell like i...
Hello, Thank You for using FixYa. I will be helping you today.Try 2 cups of white vinegar on a heavy duty cycle with hot water.Pour it in the detergent dispenser after it starts to fill. Also the affresh tablets work good i would use 3 tablets at one time if your unit is as bad as you say.
Thank You and please rate my answer if it was helpful..
Jun 17, 2011 | Maytag Neptune MAH5500B Front Load Washer
SanDisk Sansa e250 MP3 Player Logo
14 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
