Question about HP LaserJet 5200n Printer
After print command printer shows data received but does not print. continuously showing processing. Print gets failed.
Can duplicate IP address of printer and other in the network
Posted on Sep 30, 2011
Riso Rp3700 won't print from computer
We suffer the same issue. Have you find the solution?
May 02, 2013 | Office Equipment & Supplies
My Lexmark E250DN : 02 led on the right hand is ON, the system restart and can not print. Any suggestion for help???
The printer is ready to receive and process data. In addition, the toner in the toner cartridge is getting low.
You can press and release Continue button to clear the light sequence and continue processing the print job. Turn the printer off and remove the toner cartridge, and shake it to extend the life. If toner light is on, replace the toner cartridge.
For further assistance, please call Lexmark Technical Support.
Jan 11, 2011 | Lexmark E250dn Laser Printer
I am using the above mentioned printer and have been for a few years now. The issue that I am having is that when I print from a certain program, the print receives the data, processes the data, then goes...
Delete the printer, download the latest drivers and try again. If problem continues I would reload the program that is causing the problem.
Sounds like something got corrupted. I'm assuming that it is this one application that is failing. If all other apps work it tells me that that app is hosed.
Dec 05, 2010 | HP LaserJet 4100n Printer
Our Genicom Tally printer fails to keep settings. The model type is 6312. What could be the problem?
There may be a number of reasons for the 6312 failing to keep your settings, the first thing to identify would be that you have changed the settings on the printer and then saved these settings. If you do not save the settings to a menu / configuration they will be lost if the printer is powered off or receives a reset command.
Once you have made your settings changes, the settings can be saved in the following way;
Ensure the pritner is OFFLINE
Press Menu
Press Up Arrow until display shows Config Menu
Press Enter
Press Up Arrow until display shows Configurations
Press Enter
Press Up Arrow until display shows Save
Press Enter
Press Up Arrow until the Config Number Or Name appears that you want to save the settings to (Default is Confg 1)
Press Enter
Press Clear, to return to Offline mode.
If you save your settings you can then print a configuration report to see the values that have been saved, this can be done in the following way;
With the printer OFFLINE
Press the Menu key
Press any Arrow key until display shows Config Menu.
Press the Enter key.
Press any Arrow key until display shows Printer.
Press any Arrow key until display shows Report.
Press any Arrow key until display shows All Configs.
Press the Enter key and the configurations will be printed.
This should show your saved settings, try powerign th epritner off and back on again and again print the Congfig report to check the settings are retained.
If you find the settings appear to change when you print to the printer this will be caused by your print job, escape commands in the print job will take presidence over the printer menu settings.
You would need to check the host computer system to see what might be causing the problem; chack page size, fonts, ensure the correct printer driver is used etc on the system.
Jan 26, 2010 | TallyGenicom 6312 Matrix Printer
Shows ''receiving data'' then does nothing.
You are better off installing the Brother software.
Hope it helps.
Sep 05, 2009 | Brother MFC-465CN InkJet Printer
Samsung SCX 4521F: Incoming faxes 'receiving' but fail to print
Has the main board been changed??if yes the liu board(modem) board needs replacing.
Jul 18, 2009 | Samsung SCX 4521F All-In-One Laser Printer
XP SP3 sends docs to print que but nothing prints
Open up your print queue. Cancel All jobs.
Go to the start menu and either click on, or search for cmd. This will open the command window. You also need to open your task manager.
In the task manager, search for a process called spoolsv.exe, or if that doesn't exist, find a process with "spool" in the name. This is your print spooling process. Right click the process, and end it. You can close the task manager now.
Next, go to the command prompt. Type "net start spooler" without the quotes, and hit enter. This should restart your spooling process. Close the command window, and try to print.
If this doesn't work, you should check to make sure you're printing to the correct printer. If it doesnt solve the problem, uninstall your current printer (you may have to end the spoolsv.exe process again), and reinstall the drivers for your particular model, which you can find at the manufacturers website.
Jun 23, 2009 | HP Remanufactured Compaq Presario SR1130NX...
Printer dont print 2 command
i experience it before but i just restart the pc and printer or the printer itself and after a while its ok..^_^..
May 17, 2009 | Lexmark X5470 All-In-One InkJet Printer
Zebra S4M Printer doesn't print
The fact that the Data message is displayed, means it is 'seeing' something. You may be losing the command character at the beginning that would cause the machine to ignore the rest of your code. If this is the first time you have attempted to use the serial port, you may have a setting incorrectly set. You need to match your Host exactly or the data may be framed incorrectly. The old standard was to send your data 8 bits, 1 stop-bit and no parity. Try Xon-Xoff with hardware handshaking too. I hope this helps.
Apr 04, 2009 | Zebra S4M Thermal Label Printer
LaserJet 4350n Error 49.C02
49.XXXX PRINTER ERROR To continue turn the printer off then on Description The printing operation has been aborted. The issue can be caused by a firmware error, invalid print commands, corrupt data, invalid operations, poor quality parallel cables, poor connections or specific applications. Action
  1. Press Cancel Job to clear the print job from the printer memory.
  2. Turn the printer off and then on to clear the error message.
  3. Try printing a job from a different software program. If the job prints, go back to the first program and try printing a different file. If the message appears only with a certain software program or print job, contact the software vendor for assistance.
  4. If the above action does not solve the issue, contact HP or authorized service provider.
Dec 05, 2008 | HP LaserJet 4350 Printer
HP LaserJet 5200n Printer Logo
102 people viewed this question
Seeker5211
Seeker5211
