Question about Yamaha HTR6230 Receiver
All of the sudden my htr-6230 is getting no sound. Can I reset it?
  • jlasne Jan 05, 2011
    Thanks smarthome2. I tried that and I have sound coming to the sub and rear speakers, but nothing to the front. I have tried every setting I can find, but nothing.
    President:
  • Yamaha Master
  • 1,114 Answers
Unplug it for 30 seconds and then plug it back in. Make sure your speaker select is on either "A or B" or AB. you will see it on the display panel. If you still have an issue, post a comment and I will help you further.
Posted on Jan 04, 2011
Yamaha receiver HTR-3064 turn on but go to protection mode no sound
Htr-3064 reset power on - Fixya
www.fixya.com/support/t22761844-htr_3064_reset_power
Jan 8, 2014 - htr-3064 reset power on My Yamaha HTR-3064 will not turn on at all. ... 'straight' button as you power up to go into "advanced" menu (under DILLIGAF's post.) ... Not sure if I needed to unplug everything, but I was about to .... How do I turn ofprotection mode on my optimus sta 3200 receiver digital No sound.
Turns on but no sound - Fixya
Yamaha HTR-5460 Repair Brief.mpg - YouTube? 15:04https://www.youtube.com/watch?v=keaq2F4LrU4Feb 5, 2011 - Uploaded by Mark ZachariasThe Multimeter Junkie fixes an HTR-5460 with protectionproblems. ... Yamaha RX-V459DAB - Not powering ...Missing: 3064Yamaha HTR-5640 AV-Recei
Dec 21, 2015 | Yamaha Audio Players & Recorders
WHAT IS THE 5 DIGIT CODE FOR A HTR-6230 YAMAHA RECEIVER SOUND SYSTEM THAT I CAN USE ON A RCA UNIVERSAL REMOTE?
Did you check the manual? Did you contact the manufacturer of your universal remote for the code if they have it?
Sep 05, 2015 | RCA 4-Device Universal Remote
Remote code for vizio tv
I have an HTR-6230 and the LG codes worked for me. Thank you wjcooper
Jun 25, 2012 | Vizio 42 in. LCD TV
I have a Yamaha HTR 6230, bought in US ( 120V 60Hz). I want to use it in India ( 230V 60 Hz). How can I do that?
Buy a transformer that is compatible with local electrical connectors and supports the wattage it draws.
http://www.world-import.com/all-transformers.htm
People take electrical products between the 2 main voltages all the time.
Apr 07, 2011 | Yamaha HTR-5230 Receiver
Hi I have a Yamaha yht 292 surround sound system with a model htr 6230 reciever. I have a panasonic (42'') plasma HDTV (model TC P42X1) attached to the receiver by a HDMI cable. I also have a Samsung Blue...
As per HTR-6230 specifications (http://www.yamaha.com/yec/products/productdetail.html?CNTID=5028494&CTID=5000400&ATRID=1020&DETYP=ATTRIBUTE) the HDMI function is only "audio-passthru", which means your receiver is not able to get the audio from HDMI cable, it can only pass it forward to TV. You would need a receiver with "HDMI switch" to be able to listen to audio via HDMI cable. You can find such receiver by looking if it supports TrueHD audio (which can be transferred ONLY via HDMI cable).
With your current receiver, you can connect it to the Blue-ray player via Optical SPDIF cable. I have checked the specs and both receiver and BD player supports optical connection.
Feb 25, 2010 | Yamaha YHT-390 Theater System
How do I connect my xbox 360 to my yamaha HTR 6230 receiver?
Use HDMI because they combine picture and sound in one convenient cable. You can buy the cheapy ones because they work the same as the pricey ones with no degradation in sound quality or picture.
Feb 18, 2010 | Yamaha RX-V463 Receiver
VIP 1225
Did you ever find a code to work???
Jan 19, 2010 | Yamaha HTR-6130 Receiver
Want to use all 5 speakers on surround sound yamaha htr-6230 on tv programs. how set up?
Depends on the audio source for your TV sound. If it's a digital cable box, run a coaxial or optical cable from it to an available digital input, assign it as "TV" and you're done; or if the cable box has 5.1 analog outputs, usethose to the Multi Ch imputs.
If your TV sound source is only RCA cables (stereo) you're stuck with DSP surround modes.
Dec 27, 2009 | Audio Players & Recorders
NO sound, display says CHECK SP cable? Just bought yamaha292 theater system with AV receiver HTR-6230, all speakers are wired, plug with 1 optical to my TV, selected the inputs and there's no sound. ...
Probably the speakers are not wired correctly. Check this by turning on the receiver without speakers connected. If the message is gone, issue was in the connection of speakers. Check that you have not short-wired the + and -.
Dec 13, 2009 | Yamaha HTR-6130 Receiver
Problem with sp cable (yamaha)
The speaker cables are the ones that clamp or tighen down on the back of the reciever. All the spkr wires have to have the positive and negative leads correct. Also not aven one little strand of wire can be touching another conductor or you will have this problem. Make sure all leads are correctly ran and hooked up positive to positive and negative to negative from the back of the reciever all the way to the speakers. This should solv your problem.
Jul 25, 2009 | Yamaha HTR-6030 Receiver
Yamaha HTR6230 Receiver Logo
206 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
