Question about Sylvania G-Netbook
Cannot find a way to manually configure proper IP address, Default Gateway, DNS, Subnet mask etc. on SYNET7WID. to open IE, MSN, etc., let alone recognize my router. Booklet is no help, and Digital Gadgets website takes it for granted it is a "plug and play" device while their tech hotline seems to deny its own existence.
  • 114 Answers
Windoze ce network config should be Start - Programs - Connections. In the drop down box, select the Network connection
Posted on Jan 04, 2011
How do I set up the ecb350 as a repeater. I have an xfinity wifi that doesn't reach the whole house but I can connect with an Ethernet cable to the back of the ECB350 out in the area I need wifi acce
What are you using for your main router (xfinity wifi)? The best way is to set the ecb350 in AP Router Mode not a repeater since you have a rj45 cable long enough to go from one of the ports on the xfinity wifi router and hook it into the ecb350. You will need to know what your ip address range is for example if the xfinity is 192.168.1.1 then you want to assign a static address for the ecb350 to be 192.168.1.100 (assigned IP Address) You will also need the Subnet mask, Default Gateway IP Address, and Primary DNS and Secondary DNS of the xfinity wifi router. Then on the ecb350 you will need to configure the following with the info you go off the xfinity router:
Static IP Internet Connection Type Select Static IP to begin configuration of the Static IP connection. Account Name Leave Blank Domain Name Leave Blank MTU Auto IP Address ie: 192.168.1.100 (assigned IP Address) IP Subnet Mask Specify the subnet mask of your Xfinity Router Gateway IP Address Specify the gateway of your Xfinity Router Primary DNS Specify the primary DNS server's IP address of your Xfinity Router Secondary DNS Specify the secondary DNS server's IP address of your Xfinity Router Discard Ping on WAN Check to Enable to recognize pings on the ECB350 WAN interface or Disable to block pings on the ECB350 WAN interface. Note: Pinging IP addresses is a common method used by hackers to test whether the IP address is valid. Blocking pings provides some extra security from hackers. Accept / Cancel Click Accept to confirm the changes or Cancel to cancel and return previous settings. Note: Clicking Accept does not apply the changes. To apply them, use Status > Save/Load Hope that this help you.
Sep 10, 2014 | EnGenius ECB350 Wireless-N Indoor...
Can't connect to router interface 192.168.1.1
Took another look by fixing word wrapping in notepad.
It's missing DNS Servers. Check your NIC settings and make sure you don't have a DNS server manually set to another IP. Plus, you might try resetting the router to default in case there is a DNS modification there.
I'm not sure if this is the cause, but I couldn't hurt. It's part of trouble shooting.
Good Luck!
JD
Oct 02, 2012 | Computers & Internet
I have a Sylvania netbook SYNET7WID. I've entered the DHCP, Primary and seconary DNS, IP addresses, sub-net mask, SSID, password, network key and pass phrase. This piece of junk says I am connected but...
that will depend on the problem on why you cant connect
please reply with this values:
IP address
Subnet Mask
Default Gateway
DNS Primary:
DNS Secondary:
also check if you have mac filtering "on" on your router.
Mar 24, 2011 | Computers & Internet
I just configured my MFC 490cw for wireless printing. It works but now I have IP address conflicts across all computers XP & Windows 7) and X-box in the house. If I turn the printer off, the network...
When configuring an address for the printer, the IP configuration might look like (just an example):
IP Address - 192.168.1.2
Subnet Mask - 255.255.255.0
Default Gateway - 192.168.1.1
It's important to note that even though you are not using any IP addresses in the default range for DHCP, the Subnet Mask and Default Gateway addresses will be THE SAME.
If you have another device on your network that will be assign a fixed address, you would use for example:
IP Address - 192.168.1.3
For any other devices, just increment the IP address by one, 192.168.1.4, 192.168.1.5, etc and use the same Subnet Mask and Default Gateway.
(see the owners manual or site for steps on configuraing the printer TCP/IP information). This should take care of any conflicts.
Jan 29, 2011 | Brother MFC 490cw Color Inkjet...
Linksys NH1005 V2.2 Ethernet 10/100 5 Port Hub Router. I cant get the other computers connected to the hub to connect to the internet. I've tried everything.
Hello!
I will just illustrate on how to configure or to set the correct IP addressing;
Assuming that we will manually put IP address on each computer:
PC1:
IP Address: 192.168.1.13
Subnet mask: 255.255.255.0
Default gateway: 192.168.1.1
Preffered DNS server: 192.168.1.1
***note that 192.168.1.1 is the IP Address that your ISP gives to you, so on the other computer (see below)
PC2:
IP Address: 192.168.1.18
Hope I was able to help.
Oct 09, 2010 | Linksys (NH1005) 5x10/100 Mbps Networking...
Lan is ok but pc cannot open net
Try to check your IP ADDRESS--if its configured properly, please see below:
IP ADDRESS: 192.168.1.13
SUBNET MASK: 255.255.255.0
DEFAULT GATEWAY: 192.168.1.1
DNS SERVER: 192.168.1.1
note: 192.168.1.1, is the IP ADD from your router or from your Internet Service Provider.
Jun 17, 2010 | PC Chips MB PCCHIPS P25G V3.0 P4M800CE 478...
Laptop will not connect to wireless internet says it doesn't have a valid IP configuration. Have unplugged loads of times can get other wireless connections in the area but not mine.
In your laptop, try to put an IP Address, subnet mask, default gateway and preferred DNS server. (please see below)
example:
IP address: 192.168.1.13
Default Gateway: 192.168.1.1
DNS Server: 192.168.1.1
note: 192.168.1.1, is where your modem or your internet is connected (or the IP Address). This is the one that is provided/configured by your Internet Service Provider.
Jun 07, 2010 | Buffalo Technology Buffalo LinkStation...
Router connection
1. Please check your computer have a static IP address.
2. Please put your computer's IP address shout be automatic.
Mar 13, 2010 | Linksys WRT160N Wireless Router
How do i use my wireless ethernet? it recognizes the 1394 net adapter and i have the needed drivers with no splat problems. do i need to set up a wireless connection through the connection settings? i have...
If you are in a network, you need to have a thing called IP address which is usually assigned by a DHCP server or a wireless access point.If DHCP Server is not available in your case then you need to configure evreything manually.If DHCP server is available then you don't need to configure anything.Just search for the WI_FI signal and connect with it.
For manually configuring Wireless Network Setting
Go to control panel and click "network and Sharing Center", click Change Adapter settings" Right Click on the wireless adapter, Select "properties", click on "Internet Protocol version 4(TCP/IPv4)".
Select now use the followinf IP address,
Manually fill the IP address :
                       Subnet mask :
                       Default Gateway:
Select "Use the following DNS address "
Manually fill Preferred DNS address:
                Alternate DNS address:
For example :                           IP address               : 192.168.0.10
                       Subnet mask               : 255.255.255.0
                       Default Gateway           :192.168.0 1
                    Preferred DNS address    :218.248.234.117
                     Alternate DNS address   :218.248.136.142
IP address is needed for communications between devices.
subnet mask is needed for identifying your Network Address Node.
Default Gateway is usually your Router or Wi-Fi access point IP Address.
DNS address for resolving domain name(mostly for Internet browsing)
Hope you can connect it now.
HAPPY NEW YEAR.
Dec 31, 2009 | Gateway 4525GZ Notebook
Configuring leviton router
You can get the router's IP address from the functioning PC. Go to the command prompt by clicking on Start / Run ...and then enter "cmd" in the text area and click "OK". In the black window that pops up...type the command "ipconfig". The computer will list it's IP address, subnet mask and default gateway. The default gateway is the router's IP address.
To enter the Default gateway (router) address in the PC that isn't working...click on Start / Control Panel / Network Connections / Local Area Connection / Properties. In the "Local Area Connection Properties" window....scroll down and click on Internet Protocol (TCP/IP) to highlight it. Now click on the properties button.
In the Internet Protocol Properties Window....click on Use the Following IP address:...now you can enter the IP address for the computer to use, the subnet mask, and the default gateway. The default gateway and subnet mask are the same as the working PC. Hopefully you already know what the IP address for this computer is supposed to be....it must be unique on this section of the network. To function properly, this computer also needs to know what DNS server(s) to use. You can enter the DNS server address at the bottom of this screen.
If you don't know the DNS server addresses, you can look them up on the other machine also. Use the command prompt as described above and enter the command: "ipconfig /all" Look for the DNS server addresses in the command output.
Jan 14, 2008 | Computers & Internet
Sylvania G-Netbook Logo
216 people viewed this question
Top Sylvania Computers & Internet Experts
Mike
Are you a Sylvania Computer and Internet Expert? Answer questions, earn points and help others
