Question about Compaq Evo N800c Notebook
My keyboard won't type anything. It will let me put password in to open windows
What do i do when a key(i don't know which one) is stuck on my laptop restricting me from typing in my password?
You have a couple options. If you are running Windows 7 you might be able to activate the onscreen keyboard. Details here: http://www.softwareok.com/?seite=faq-Win-7&faq=22
Alternatively I suggest you buy or borrow a standard USB keyboard and plug it into an available USB port. This should get recognized by Windows and you should be able to login.
Ultimately your laptop keyboard would need to be repaired. It is possible that a small object such as a staple has fallen into under a key causing the problem. With the power turned off and the lid open, you might turn over the laptop and gently shake the laptop to see if anything falls out.
Sep 10, 2014 | Dell Inspiron Computers & Internet
I forgot my password
You will need to reinstall windows
Apr 05, 2008 | Dell Latitude D600 Notebook
Computer not used for 7 years. won't boot up. get error message about date and time
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer Windows Advanced Options Menu Please select an option: Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode Start Windows Normally
Reboot
Return to OS Choices Menu Use the up and down arrow keys to move the highlight to your choice select safe mode with command prompt Click start run type cmd press Enter black screen should open DOS mode this will vary depending on your operating system type in net user username For eg. If you want to change administrator password , type net user Administrator It will prompt you to enter the new password. Enter the new password and the password is changed if this fails you will need to Select safe mode with networking to download you could download all of these or just one save them to a usb drive for later use if one fails to remove the password Windows Password Recovery Basic http://majorgeeks.com/CmosPwd_d239.html A CMOS BIOS password recovery tool Editors note: This tool should only be used by experienced computer users. Please see the enclosed read me if you would like to run it from Windows. Failure to follow instructions (from Windows) will cause your anti-virus to flag this as a virus. http://majorgeeks.com/Dr._Freeware_System_Utilities_d6416.html Dr.Freeware System Utilities which includes data recovery software, data backup, password reset tools for Windows helps you to maintain your system. Dr.Freeware is freeware, you can download and use it for free. Hope this helps.
Dec 19, 2012 | IBM ThinkPad A21m 2628 Notebook
My keyboard on my Windows 7 PC starts acting crazy now when I went to type something. Instead of being able to type a letter, the computer wanted to open a program and won't act normal. What's
Run a full virus scan, and hook external keyboard to see if it will work, if okay the laptop keyboard will need to be replaced. Go to www.ebay.com type make and model of laptop, refine search to keyboard.
Jun 10, 2012 | Toshiba Computers & Internet
Dell vostro a860 won't connect to internet
Why not? Do you have the wireless turned on? Did you put the correct password in?
Maybe you don't have your wireless turned on. Look on both sides and in front for the Wireless Switch and turn it on.
Also once the wireless switch is turned on there are keystrokes that can toggle the wireless on or off. Normally you would Press and Hold the FN function key located at the lower left of the keyboard, then hit the correct F1 thru F12 key that toggles the wireless. The correct F1 thru F12 key to hit will have the wireless signal icon )))) on it. Or it might have the icon of a tower with the wireless signal icon )))). Normally the screen will display Wireless On or Wireless Off when you toggle the wireless.
If you put the wrong password in, it will never connect. it will keep trying to connect but never will.
Authentication
That means you probably don't have the password or the Authentication Type set correctly.
For Windows XP below:
Click Start/Control Panel/Network Connections then Right Click on the Wireless Network Connection and select Properties. When the Properties window open click the Wireless Networks tab. Click on the SSID for your wireless network that you connect to and the Properties window will open. You can change the Authentication Type to match the type set in your wireless router and you can also change your password or Network Key to make sure you have it in correctly.
For Windows Vista below:
Click Start/Control Panel/Network and Sharing Center then look to the left of the open window and click Manage Wireless Networks. Find the SSID of the network that you connect to and double click it. When the window opens click the Security tab to change the Security Type (which is the Authentication), The Encryption Type and the Network Security Key (which is the password).
For Windows 7 below:
Click Start/Control Panel/Network and Internet/Network and Sharing Center then look to the left and select Manage Wireless Networks. Find the SSID of the network that you connect to and double click it. When the window opens click the Security tab to change the Security Type (which is the Authentication), The Encryption Type and the Network Security Key (which is the password).
May 28, 2012 | Dell Vostro A860 Notebook
Vostro 1520- keyboard stuck on randomly repeating keys after small liquid spill.. no liquid inside, only a few drops on keys and it won't type right. Tried USB keyboard but it won't override the...
short of replacing the keyboard, there is not much you can do. If not killer expensive, then you could at your own risk put isopropal alcohol inside the tray - move around and then turn upside down. this will be easier on the electronics and may dissolve the liquid depending on what it is. If the viscocity is too high, then it wont work but worth a try.
Jun 14, 2011 | Computers & Internet
Computer prompts for user name and pass word, it was givin to me i dont know user name and pass word
You can try putting in Administrator and leave password field blank and see if it works, otherwise try one of the following:
- see this for XP http://support.microsoft.com/kb/321305
- or this for Vista/Win7 http://windows.microsoft.com/en-us/windows-vista/What-to-do-if-you-forget-your-Windows-password
- or if anything else didn't work you can use third party software from Hiren's Boot CD to reset your login password http://www.hirensbootcd.org/download.html
Feb 05, 2011 | MPC Computers TransPort GX Notebook
Wireless keyboard
Try new batteries, try the reset buttons that should be on the keyboard and/or the base of the unit. From there you will have to use a wired keyboard and then set up your wireless when you are in windows. Thanks,
Lee
Jul 09, 2009 | Microsoft Wireless Notebook Optical Mouse...
Volume control keys on MS comfort curve 2000 keybrd not working
Restart the HID Human Interface Service. To fix this problem yourself, follow these steps:
  1. Open Microsoft Management Console (MMC) snap-in for Services.
In Windows Vista or Windows 7, click Start, type services.msc in the Start Search box, and then press ENTER.
If you are prompted for an administrator password or for a confirmation, type the password, or click Continue.
In Windows XP, click Start, click Run, type services.msc in the Open box, and then click OK.
  1. In the list of services in the Details pane, double-click HID Human Interface Service, and then make sure that the Startup type is set to Automatic. Then if not running start.
Worked for me J
Mar 28, 2009 | Microsoft Comfort Curve 2000 Keyboard
Compaq Evo N800c Notebook Logo
114 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
