Question about Maytag 18.6 Cu. Ft. Bottom-Mount Refrigerator - Black
What is the best temperature for refrigeration for vegetables?
  • 784 Answers
The best temperature for vegetables in the refigerator is between 34 F to 40 F,, cool and high humidity is best.
c...
Posted on Jan 04, 2011
Model XRSS465BB Refrigerator - what is the correct refrigerator setting to avoid frozen vegetables? Also what is the correct deepfreeze setting?
usually meduim setting is good'
FREEZER /FRIDGE NOT COOLING: Optimum refrigerator temperature at or below40° F(4° C). The freezer temperature should be0° F(-18° C). Check temperatures periodically. Appliance thermometers are the best way of knowing these
Jun 14, 2015 | Amana Refrigerators
Vegetables & fruit freeze when stored on the bottom shelf of the refrigerator
Cold air settles to the bottom of the refrigerator. Turn the temperature of the refrigerator up until the vegetables do not freeze.
May 30, 2011 | Refrigerators
Vegetables freezing in crisper drawer
This is an issue with the convection system in the refrigerator, while the cold air trapped withing the crisper drawer remains and the temperature of the moisture in the area drops below the freezing point, the water content acts as a cover and thereafter enables the vegetables to freeze. A slight rearrangement of the utensils within the refrigerator solved the problem
Jan 21, 2011 | GE GSS22SGM Side by Side Refrigerator
Our Amana AF12538 AE Refrigerator is causing the vegetables in the vegetable bin to freeze. What could cause this? the Units is only 2 years old.
Refrigerator temperature control set too cold or faulty Fresh Food thermistor.
Adjust refrigerator temperature control or check thermistor.
1 Refrigerator section too cold
2 Refrigerator airflow not properly adjusted
3 Check air flow.
Just too much information for this page. If you would like the long version please let me know. I am a Technician and have the tools and the answers if you would like my assistance. I will go out of my way to help you and would rather tell you this first so please do not rate unless I assist you Thanks, Sea Breeze
Dec 30, 2010 | Amana AFI2538AE
My GE Profile Performer refrigerator is freezing fruits and veget
PUT THE REF. ON 5 AND SET THE
FREEZER ON 2 1/2 AND SEE IF THIS WORKS
Apr 23, 2010 | GE Profile PSW26P Stainless Steel Side by...
PSS25S side by side is freezing vegetables. We
Sir, To solve this problem, you must open the compressor area at the back bottom of the refrigerator and chek the temperature of the pressure line. If the temperature is between 55celcius to 60 than its ok. Or else you need to change the refrigerant. I suggest you to contact the service authority.
Thanks for contacting Fixya.
Sep 12, 2009 | GE Profile¿ Arctica® Energy...
Bosch Refrigerator ice forming in vegetable drawer
Emptied drawers and cleared the drain hole. Drawers were then refilled BUT MADE SURE THAT THEY WERE NOT OVERLOADED
Jul 28, 2009 | Bosch Classixx KGV28323 Bottom Freezer...
Vegetables are freezing inside vegetable bin
Most likely your refrigerator is set at too cold a setting. Just turn the temperature adjustment to a warmer setting.
May 03, 2009 | Refrigerators
Water despenser is apparently frozen
You may have two mutually exclusive probems... one being the water dispenser doesn't dispense water... As you stated, the obvious remedy would be to replace your filter to see if that is restricting water flow.. secondly, your vegetable crisper is freezing vegetables... chances are that the inlet between the freezer compartment and that vegetable darwer is near there and the damper needs to be closed a bit... See if you can locate the cold air inlet vent and partially close the damper ... Hope that helps...
Aug 14, 2008 | Amana AFD2535DES French Door Refrigerator
Maytag 18.6 Cu. Ft. Bottom-Mount Refrigerator - Black Logo
65 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
