Question about Kenmore Vacuums
Kenmore Model 116 28014700 intuition vacuum cleaner. Latch for hose connection to cannister broke. I have the new part. How do I remove the hose from the broken part and replace it on the new part? Thanks
  • 4,323 Answers
Hi
To remove the broken part from the latch use a small screwdriver to release the tabs on the latch on the connector. When latches are released the latch assembly and the plate will slide out of the connector. When the plate is removed the adapter and hose will slide off the connector. Release the tabs that hold the hose to the adapter and put the hose on the new adapter.
You need to position the terminal plate inside the adapter before sliding the adapter and hose on the new connector. The latch and terminal plate have to slide under the small guides on the connector. Its reverse of removal. Please check the pictures in the below link, it may help---
Link 1
Link 2
Link 3
Hope this helps... Please post back if you need more information.
Daniel
Posted on Jan 06, 2011
When I replaced the bag, the bag replace light comes on unless I don't use any attachments. what is the problem?
Could be a blockage, push a broom handle through the pipe that will clear it.
Oct 18, 2014 | Kenmore Vacuums
My Dirt Devil Envision #086710 is not picking up. Hoses clear, new belt, brush cleaned of hair etc. Air leaking from the place where the cord comes out of the vacuum at the bottom is this normal?
Sounds like you may have a hole in a hose somewhere. Check the internal hoses and make sure they are connected correctly. Check that your cannister is locked in. This may be preventiing suction also.
Sep 27, 2014 | Dirt Devil Envision Vacuum Cleaners
How to Unclog Vacuum Hose
you may have to make something out of heavy spring material so you can push it down the hose and be able to manipulate it.simular to what plumbers use.
Aug 14, 2014 | Hoover Vacuums
Dyson hose is broken how do I replace it
The colored pieces on the vacuum are latches. You can remove most parts. For the hose, you may have to remove the cannister to get to the latch through a hole in the main upright part of the vacuum. You can find parts with a search of the Internet. You will have to get the hose with both ends attached, but one source has it for $21.95.
Oct 20, 2013 | Dyson DC14 Animal Bagless Upright Cyclonic...
Is there an operating manual on the web for a Kenmore Intuition vacuum cleaner
Hi, here is a link to a site that holds the manuals, but you will need the model number of your cleaner. Hope it helps! Please rate me. :) http://www.managemylife.com/mmh/owner_manuals/search/product_type.Vacuum,%20Upright?query=Kenmore
Jul 17, 2010 | Kenmore Vacuums
I need the owners manual for kenmore cannister 24212
If you type in the model number on your searchbar, the website will be listed "after" all the sponored sites. Use the site that has YOUR manufacturers name in the url. Under the "support" section choose manuals and especially the term pdf. Thank you, Dana
Feb 13, 2010 | Kenmore 24212 Whispertone Bagged Canister...
Kenmore cannister style. Cannot remove the
It depends on the model you have. Do you know the model number? If you need a replacement belt you can get one here:
http://www.vacbelts.com/kenmore.htm
Oct 25, 2009 | Kenmore Vacuums
Troubleshoot Bissell Lift-Off Revolution Pet Vacuum Cleaner
Probably a hose clog. Check the hose on the back of the cannister. Most likely clogged where it attaches to allow debris into the cannister. If cannister is not filling up, that's a sure sign. To remove from top of back of cannister, just turn the ring on the end of the hose to release. Take it outside and push a long thin object through it to force out the clogged hair or debris. The motor is designed to shut off the vacuum cleaner for 30 minutes when this happens to avoid burning up your motor.
Jan 04, 2009 | Bissell 37604 Lift-Off Pet Bagless Upright...
Vacuums Logo
386 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
