Question about Acer Aspire One D255-2670
Wireless network is not responding. How do I get it to work. Also, Windows is not working.
  • sheepdog0331 Jan 04, 2011
    Do you have access to another pc to download diagnostic software to a thumb drive? If so download Ubuntu net book addition to a thumb-drive to try booting the nonfunctional computer to unbuntu. If Ubuntu works then the problem is most likely a windows related issue
  • 114 Answers
There is a switch on the right hand side below the keyboard to turn on the wifi, as for the " Also, Windows is not working." you will have to clarify the issue to get any help.
Posted on Jan 04, 2011
The wifi is not working
There are soooo many things this could be. I will give you every idea I can. Respond to this post whether these steps work or not. If you do, I will continue working with you on this until you can connect.
1.) Can any other computers connect? If you have other devices which can NOT get online, the issue is with your modem/router. Unplug the power cable(s) to your modem and router (if you don't have a router, disregard anything I explain regarding a router) AND SHUT DOWN your PC. Wait about 1 minute and plug the power cable into JUST YOUR MODEM. Wait 3 minutes for it to get a connection. Look at the lights on your modem to ensure they look normal (the "ethernet" will be OFF. That's OK.). After 3 minutes has passed, plug the power cable into your router (IF AND ONLY IF you do NOT have a router, turn ON your PC). Wait another 3 minutes and turn ON your computer (If you have no router, you just did this and it may be disregarded.) ---- In case the whole PC/router makes little sense: If you have no router and just a modem and a PC, then 3 minutes after you plug the power cable back into your modem, turn ON your PC. If you have a router, then follow the instructions exactly). ----
2.) Check for a switch on the left edge or front edge of your laptop which says "Wireless" or "Wifi." Be sure it is in the ON position (Not every laptop has this. Some have a wireless button above the keyboard and others have nothing at all.). It is very common for a user to accidentally bump this switch to the OFF position without realizing it.
3.) Perform a System Restore to take your PC's settings back to when it was working. Click Start/Programs (or All Programs)/Accessories/System Tools/System Restore. Go through the System Restore wizard to select a date BEFORE this issue happened. System Restore should NOT be interrupted. It can take up to 20 minutes in some cases. When it begins, set a timer for 20 minutes, walk away, and come back after that time has elapsed.
3a.) Windows XP: http://support.microsoft.com/kb/306084 3b.) Windows Vista/Win7: http://windows.microsoft.com/en-US/windows7/products/features/system-restore
4.) Clear your network settings from your PC and then reconnect to your network (if you do not know yourSSID (network name) and wireless network key (wireless password), then do not do this step. Instead, respond to this answer with the brand of router you have as well as the operating system you're using). This is where it would be nice to know which operating system you're using. I'll do my best with this while not knowing your OS.
4a.) Windows XP: Click Start/Control Panel/Network Connections. Then RIGHT-click your connection labeled "Wireless Network Connection [#}" and do a normal left-click on Properties. The network properties window will open. Click on the upper tab labeled "Wireless Networks." Under the Preferred Networks section, click the network you're trying to connect to and it will highlight. Then click Remove (immediately below the list of networks). If you are not sure which network in this list you are trying to connect to, repeat this process until that white box is empty. Then click OK. Again, RIGHT-click your connection labeled "Wireless Network Connection [#}" and do a normal left-click on Properties. Click on the upper tab labeled "Wireless Networks." Then click the button "View Wireless Networks." You'll be brought to a window where you can choose a wifi network with which to connect. Click the network you want to connect to and it will highlight in blue. Click "Connect" in the lower-right corner of this window. It will most likely (not always) ask you to enter your Network Key (network password). Enter this exactly; capitalization (Big letters and little letters) matters!
4b.) Windows Vista/Win7: Click Start/Control Panel/Network and Sharing Center. Click on Manage Wireless Connections. In the list, click the network you're trying to connect to and it will highlight. Above the list, click Remove. If you're not sure which one is the network you're trying to connect to, then repeat until all of the networks are removed and the space is empty. Once done, goto this link (CAUTION!!! I would right-click on this link and choose "Open link in new tab" OR "Open Link in New Window" to allow these instructions you're currently viewing to remain open): http://windows.microsoft.com/en-US/windows7/View-and-connect-to-available-wireless-networks
If none of this works, respond to this answer and I'll help further. I hope this helps!
Sep 25, 2011 | Toshiba Computers & Internet
Trying to connect wireless router so we can have access to x box live
Go to network sharing and turn network discovery on make it a private network and then go to windows media player go to bottom of library click on media sharing click share your media it should show your XBOX and if doesnt have a green check on it click on xbox and then click allow sharing. If this doesnt work I can walk you thru let me know and we will have to go another route to get it working for you but talk you through it on here. I need to know computer operating system, is the wireless network working with your computer, version of media player, and steps you have taken so far and go from there. I will be available for the next few hours so if you respond I will get back to you ASAP..
Stormi
Nov 16, 2010 | Microsoft Wireless Network Adapter Xbox...
It does not connect
Wireless Adapter is a device that will receive the wireless signals and will make your computer wireless adapter. without the wireless adapter you can not use the computer to connect to the wireless network. Now a days all the laptops and desktops are equipped with the built in wireless adapters.
First check whether you have a wireless adapter on your computer ?
WIN XP
Right click on MY COMPUTER ==> properties ==> Device Manager ==>
you will see Network adapter ==> under network adapter you will see the wireless adapter ==> Right clink on the wireless adapter ==> properties => Check whether it says the Device is working properly or not ?If it says working properly then that's great !
WIN VISTA/ Windows 7
Click START ==> Control Panel ==> In the right hand side at the top you will see " Classic View "
Switch to classic view ==> you will see Device Manager ==> Under Network Adapters you will find your wireless adapter listed . Right clink on the wireless adapter ==> properties => Check whether it says the Device is working properly or not ? If it says working properly then that's great !
If you do not see wireless adapter in the Device manager , then either you do not have the adapter or the wireless adapter is not working .If you see "yellow exclamation mark" on the wireless adapter, that means the drivers are not installed for the adapter or not working. Reinstall the drivers.
Once your adapter is working properly , try to connect to the wireless network.
If you are installing the external wireless adapter to the computer and if you are using Windows 2000 or Windows 98 , ME, then you will have to connect to the wireless network using the utility of that adapter.
If you are using Win XP then you can use windows to connect to the wireless network or you can use other utility.
In case of Win VISTA, you will use windows to connect to the wireless network.
Click Here for more info
Dec 09, 2009 | Dell 1450 (D1450U) Wireless Adapter
How do you connect WIndows Vista to Windows 7 through ADHOC?
Dec 04, 2009 | Computers & Internet
Wireless
it means yor wireless is disabled , go to device manager right click on your wireless driver and enable it. good luck
Dec 30, 2008 | Microsoft Windows XP Professional With...
I have a Toshiba Satellite Notebook and I'm having a problem with the wireless router network connection. When I go to the wireless network connection, no wireless networks are found in range. I try to...
sm times wireless network did not respond due to wrong setting in internet connection setting....
checked it out.....
see nother lptop which recieve wireless network n do urs setting same as that....
than connect wireless network u will be able to connect it....
ask me if it creates more problem.....
also available for live chat.....
Jun 22, 2008 | Toshiba Computers & Internet
XiMeta's NDAS NetDisk and Windows Vista Blue Screen
Take a look at this: http://www.ximeta.com/forum/viewtopic.php?t=13. The patch from Microsoft worked for me.
Feb 20, 2008 | Ximeta (NDU10200CU)
CISCO 2800 router interface stop responding
What kind of cable do you have connected from the DLINK to the Router? Is it an ethernet cable 3,5e,6?
Sep 13, 2007 | 3Com OfficeConnect (3CRWE454G75)...
Acer Aspire One D255-2670 Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
