I got a reddy heater R50A, a hand me down from my Dad. I don't have a manual. I plug it in and the fan starts but it doesn't ignite. I filled it with new fuel before I started.
    Scholar:
  • 146 Answers
Here is a service manual for the heater.
http://www.desaparts.com/service_manuals.html
You first need to check for spark on the unit. If you have spark then make sure you have air pup pressure coming from the air pump / rotor on the back of the motor.
If you have other questions we can try to help.
Thank you.
M Cramer
www.allpartsinc.com
Posted on Jan 04, 2011
Fan runs but no fire on igniter plug
Here are a couple of tips that I wrote that tell you how to troubleshoot a Torpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters
Torpedo Heater Pump Pressure Adjustment
heatman101
Feb 10, 2011 | Dayton E51 Oil Filled Utility Heater
Tip
On my R50A Reddy heater, the long protrusion is the plug for the air pump...
The most critical factor in getting your kerosene torpedo heater to run is the air pressure that the pump puts out. This air pressure is what pulls the fuel out of the bottom of the heater. It is very important that this is set correctly.
You will need a low pressure gauge (0-15 PSI) and a screw driver to make this adjustment.
On the back of your heater there will be a short and a long protrusion. Pull the plug out of the short one and insert the pressure gauge. The longer one is the adjuster screw. This is a very simple device that has a ball a spring and a set screw. Turn in on this screw just places more tension on the ball to allow less air to escape and raise the pressure inside the heater.
If you cannot get a high enough pressure then there is a leak or the pump is worn too much. To check for a leak use soapy water and check all the parts. The black plastic back can crack or the cork of the pump gasket can leak. Sometimes the rotor and vanes will go bad but not likely.
So, insert the pressure gauge in the short port, start the motor and check reading, you will only have a short time to do this if your heater is not firing. Turn the longer screw in or clockwise to raise the pressure and out CCW to decrease the pressure. Adjust to factory specs. And you will be getting warmed up.
http://www.fixya.com/support/r3818299-reddy_heater_troubleshooting_torpedo
http://www.fixya.com/support/r3903547-torpedo_heater_kerosene_heater_portable
on Feb 12, 2011 | Heating & Cooling
Reddi heater 155 owners manual?
If this has a hot surface igniter, can you see it glowing? If not the igniter could be bad or the control
board for the igniter is baed.
If you are able, remover the igniter and hook it up to a 110 outlet, if it glows the problem is in the board.
If it has a board, follow the incoming power to line 1
and line 2. You will either have to splice the two leads
from the igniter into L1 and L2 or get a special spade
connector that can hold two leads on each terminal.
Plug unit in, glow coil should glow and unit should run
thats assuming you have that style of unit. Do not
attempt to do this unless you can safely perform this.
If you know of an electrician he can do this.
Jan 18, 2010 | Heating & Cooling
When filled with kerosene then plugged in, the heater will kick on for about 3 seconds and the fan will run but it will not ignite, then it shuts off. reddy heater 55, 55000btu. runs on K1 or fuel oil.
REDDY HEATER 40 KEROSENE FIRES UP FOR A FEW SECONDS AND QUITS WITH A WHITE CLOUD OF SMOKE COMING OUT THE END
MY REDDY HEATER 35 KEROSENE RAN OUT OF FUEL AND WILL NOT RUN AT ALL WHEN PLUGGED IN
Jan 11, 2010 | Reddy Heater-30-55,000 BTU Variable
Reddy Heater R50A will not ignite
yep.plug the unit in and look in the back of unit.should see an orange glow.if you don't the glow bar is not comming on
Feb 23, 2009 | Reddy Heater-30-55,000 BTU Variable
Trys to start. Motor turns slowly (revolution in 2-3 seconds).
Either:
  1. the reset (safety control) is bad
  2. the photocell is defective
  3. both of the above
To test the photocell http://reddyparts.com/photocell_test_sp.htm
Nov 29, 2008 | Reddy Heater-30-55,000 BTU Variable
Reddy heater 110,000 btu forced air portable kerosene
try this, take off the top cover. plug in the heater and when the humming starts, rotate the fan sharply with a screwdriver. keep your fingers away from the fan. if the fan spins under power your start winding is shot. get a new motor. www dot desatech dot com
Dec 06, 2007 | Reddy Heater-30-55,000 BTU Variable
Heating & Cooling Logo
281 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
