Question about Nixon Banks Watch for Men
Im looking to add some links that came with the watch, i looked online and it says i have to push the pin in the direction of the arrow. I have nothing that fits the hole in the watch. I dont know if i have to go out and buy something or what, but i would like to use the watch and in its current size, i cant.
    President:
  • 2,501 Answers
If you haven't got any suitable tool for the job, then it is not worth buying one, as you may never use it again!
I suggest you go to a jeweler and pay them to do it for you. It isn't very expensive.
Posted on Jan 04, 2011
CANNOT REMOVE LINK FROM BEN SHERMAN WATCH
If it's similar to my Ben Sherman watch it will have what looks like a screw on one side. It is in fact not a screw but the 2 sides of the split pin - which you simply push out using a map pin, small strong screwdriver, or similar. If you look inside the links you should find arrows to indicate which direction to push the pins out - usually pushing the end opposite the "screw" end. Note: It takes a fair strength to get the split pins moving.
Jan 15, 2011 | Watches
I need instructions on removing links from a Fossil Stella watch
you will need some sort of tool for a pin pusher to actually remove the pin from watch . It can be a strong needle of some sorts but I suggest getting an actual pin pusher to prevent from damaging the watch or hurting yourself.
if you look inside the watch band itself you will see on the links an arrow pointing one direction. That is the direction you need to push the pin since the pin head is larger and cannot be pushed the opposite direction .
On the side of the watch links you will see a small circle endented with a pin head. That is the link pin. Place your pin pusher or other similar sized object and with a small or jeweler hammer slowly and lightly hit the pin pusher down until pin comes out of opposite side , you can use tweezers or needle nose pliers to pull pin all the way out
There are some pin removers that screw also or just push down to pop pin .
Once out repeat process until you have removed enough links that watch fits comfortably. Then slide pins with head of pin entering the side where the arrow on back of link is pointing to. Once all the way in gently hammer rest of pin till flush with link .
Oct 17, 2010 | Fossil FS2919 Wrist Watch
How do I add a link to the wristband?
Thank you for contacting FixYa.
  • Turn your watch on its side so the links are vertical. On the inside of the links closest to the clasp you can see arrows, which point in the direction that the pins must be pushed out. Only about four links on either side of the clasp have arrows, because these are the only links with removable pins. On the edge of the links on the opposite end from where the arrow is pointing you will see a small circle where the pin is inserted.
  • 2
    Place the tip of your pointed tool on the small circle mentioned in Step 1. Push downward on the pin in the direction the arrow is pointing. Once the pin starts to come out of the link, use your fingertips or a pair of tweezers to completely remove the pin from the link. You may need to use force, but be careful not to scratch your watchband. Use a pointed tool from a jeweler's or hobby kit or watch pin removal tool.
  • 3
    Slide the links apart where you removed the pin so there is a gap in the watchband. Slide your new link into the gap and fit the neighboring links into the new link so it matches the rest of the watchband.
  • 4
    Insert the new pin into the watchband. You will need to insert two pins, the pin you moved in Step 2 and your new pin, into the two empty pin holes. You need to insert the pin small end first so the larger pin head does not pass through the link. Insert the pin against the direction of the arrow rather than in the direction the arrow is pointing like you did in Step 2. Use your pointed tool and your fingertips to push the pins completely in the links until the pin head is flush with the edge of the link.
  • Best regards. Jewel
    Sep 16, 2010 | Nixon District Watch
    How can I shorten the watch band. I've tried pushing the pins, but they don;t seem to move. What is the significance of the arrows on the back of the band segments? Thank you for your help!
    The arrows show you the direction to push out the pins.
  • Look for an arrow on the inside of your watch band. The direction the arrow is pointing is the direction the pin should slide out of the band. If your pin is screwed in, you may not see an arrow on the inside of your band.
  • 2 Look on the edge of the watch band for a small round object, the pin. If the pin head is flat, then it needs to be pushed out. If the pin head has a screw driver groove, then it needs to be screwed out. Depending on the type of watch pin you have, take a sharp pointed tool or a tiny screw driver from a hobby kit or watch tool kit and place it on the head of the pin. You should be looking at the end of the pin on the opposite side from where the arrow is pointing.
  • 3 Push on the sharp tool to push the pin out of the watch band. You will need to use force to push the pin out. If your pin is screwed in, gently unscrew the pin until it becomes loose. Remove the pin with your fingertips. Make sure to put the pin in a safe place, because you will need it again when resizing the watch band.
  • Aug 18, 2010 | Kenneth Cole 1213 Wrist Watch
    Remove links
  • Wrap the watch band around your wrist to determine how many links need to be removed for the watch to fit properly.
  • 2 Place the watch face-down on a flat surface.
  • 3 Look on the back of the watch band. You will find an arrow that indicates which direction you should push the pins to remove the links.
  • Find the point at which the extra links need to be removed for your watch to fit your wrist. Using a 1 mm flathead screwdriver (or the edge of one side of a pair of tweezers), push the pins in the direction indicated by the arrows.
  • Finish removing the pins with your pliers.
  • Keep the extra links in case you ever need extra room on your watch band.
  • For further assistance, check out the link:
    http://www.pulsarwatches.com/home2.asp#FAQ
    Aug 17, 2010 | Pulsar Men's Stainless Steel Bracelet...
    Adjust-a-Casio-S-1087DY-Watch-Band
    On most brands, there are pins that form hinges for the links of strap. You need to push them out to remove links. Usually you would find arrows marked from inside of the metal bracelet which show you the direction in which to remove the pins. You can remove it if you have a small watch maker's screwdriver but you have to be careful. or get one of these ..
    http://www.amazon.co.uk/Watch-bracelet-link-adjuster-remover/dp/B001ZKIL2S/ref=sr_1_1?ie=UTF8&s=watch&qid=1254695541&sr=8-1
    which should help you to remove the link pins safely without scratching.
    Aug 31, 2009 | Casio Edifice EFA110D-1AV Wrist Watch
    Fossil AM4200 shorten band
    Depending on the age of the watch you will see indicators of pin direction on the inside of the band. Little arrows that point the direction the pins should come out. If there are no arrows you can look at the edge of the band. You are looking for a split in the pin that makes it look like a screw. The opposite side will be solid. You want to push on the side that is solid so the side that looked split comes out. This is a cotter pin and the split side is bigger and needs to come out first. Use a small punch to push the pins out. Make sure you take links from the band evenly on either side.
    Jun 09, 2009 | Fossil AM 3688 Wrist Watch
    Trying to remove links on a fossil watch w/arrrows pointing out
    Are you pushing the links in the same direction as the arrow is pointing? If so, are you using a tool specifically made for removing watch links? If the answer to both of the above is "yes" then look closely at your watch. The pin will look different on both sides. One side will look like the head of a "screw" and the other will look rounded and just come to a point. You always want to use the watch link remover tool on the ROUNDED end and push the "screw" looking end out. It could be that your watch was assembled w/the pin facing the wrong direction.
    If you appreciate me solving this for you then please rank this solution as "fixya" or at least "helpful", thanks!
    Jan 08, 2009 | Fossil AM3726 Wrist Watch
    I just bought a fossil watch ch2331 and need to remove a link. how do i do it?
    Some of the links are removable on this watch & some are not. Look inside the band you should see some tiny arrows on the removeable links. You need to push the pin through in the direction of the arrows & remove the link. Then to put the band back together you need push the pin through in the opposite direction of the arrow. Make sure the widest part to the pin goes in last or it won't fit.
    Mar 09, 2008 | Fossil CH2331 Wrist Watch
    Shorten watchband
    I have a similar watch and removing the links are not easy. There are pins in certain links that have arrows on the inside of the band. I used a push pin to remove the pins in the direction of the arrows. Snip the end of the push pin with a wire cutter or pliers so that it fits into the hole and tap the top of the push pin with a small hammer until the other end of the pin is exposed enough to extract it with a set of needle nosed pliers. Repeat for other side of link. When the pin is extracted, twist the link inward and it should snap out.
    Remove the link and reverse the procedure, placing the pin in the opposite direction as it was extracted. You may have to tap it gently with the push pin and hammer to get it to go into the holes flush.
    It takes a little while and some patience, but if you can get someone to hold the band for you while you tap the pin, it will be easier. Also, if you remove the spring loaded pin from the band fastener so the band can be laid out straight, it will also be easier. Good luck!
    Mar 30, 2007 | Timex Outdoor Casual Expedition®...
    Nixon Banks Watch for Men Logo
    51 people viewed this question
    Top Nixon Watches Experts
    Ansel Alberto
    Ansel Alberto
    rhodesworks
    Are you a Nixon Watch Expert? Answer questions, earn points and help others
