Question about Team International Hawk Talon V3 RC Indoor Helicopter
My hawk talon v3 will not lift off the ground and the bottom rotor barely rotates.
The lower rotor has a problem where the gear on the motor shaft slides down and does not engage with the rotor gear. You can reach in through the skeleton with a small screwdriver and push the gear back up to engage. Happens every now and again, usually after a crash.
Posted on Jan 09, 2011
I would assume the batteries are charged? If they are maybe they just will not hold a charge anymore. You may have to get new ones.
Posted on Jan 04, 2011
How to string a talon garden hawk trimmer
https://www.youtube.com/watch?v=tXUrdUoS_PU
Mar 18, 2015 | Garden
Restringing a talon hawk whipper snipper
There may be a latch that has to be released in order to rotate it.
Jul 19, 2014 | whipper snipper Garden
My hawk talon v3 is doing everything fine except it wont come off of the ground the blades are spinning they are taking some wait off the ground but in all the helicopter stays down what can i do?
try taking the body off of the skeleton and cleaning the rotor cylinder, might be dirty or have some carpet/hair fibers keeping the blades from running at full speed even if the battery is fully charged
Jan 08, 2011 | Team International Hawk Talon V3 RC Indoor...
How to synchronize a Hawk talon V3 radio control helicopter with the remote control
If it has 3 channles then you turn the helicopter on first, then turn the remote on. If its not a 3 channle helicopter i dont know sorry.
Jan 04, 2011 | Team International Hawk Talon V3 RC Indoor...
Hawk talon v3 wont get enough power to lift off the ground after being fully charged. another hawk talon v3 rear tail rutter wont spin to go forward. how do I fix these problems in these two...
I too had the lift-off prolem and I fixed it by gently pushed the upper gear all the way up, using a nail through the bottom of the copter and a hole in the lower gear, while pushing the lower rotor down.
Dec 29, 2010 | Team International Hawk Talon V3 RC Indoor...
Hawk talon v3 - bottom rotor won't spin
I just got one for Christmas too. Had it flying for 10 seconds, and lost control. I have to work on my piloting skills! After that initial crash, I prepared for another take off and realized my lower rotor was not spinning. It turns out that the tiny vertical gear that powers the lower rotor gear fell off its axle. The axle is connected to the sensor that receives the signal from the throttle. Luckily, I found that tiny gear sitting inside the head of my helicopter. After spending 2 hours trying to place it back on the axle, I got it running again. The rotor was spinning again, but it wouldn't take off. I did some troubleshooting, adjusting the trim multiple times. Then the gear fell off again. I found it and noticed that I had damaged the plastic teeth from using my tweezers to reinstall it. You can go to Team-RC.com to buy a complete gear system for $6.95. You won't need to replace all of the gears, just the one that fell off, and it's always a good idea to have spare parts just in case.
Happy flying
P.
Dec 28, 2010 | Team International Hawk Talon V3 RC Indoor...
Crashed hard and now the bottom rotor is not spinning as fast as the other two. What should I do?
loosen the body screws. lift the right side front so you can see the engine gears, The little gear has slipped on the shaft and is not making contact with the big gear (white plastic gears). Slide the little gear down the shaft so it meshes with the bigger gear. Close the body back up (don't tighten screws yet). Turn the Heli on and make sure all is well (while holding the body closed). Tighten screws...Enjoy...
Dec 25, 2010 | Team International Hawk Talon V3 RC Indoor...
Starting Instructions Talon Grass Hawk
i would like insructions how to replace trimes cord
Mar 13, 2010 | Talon Electronics - Others
F2 flashing on lower drawer
F2 means "motor not sensed to be rotating"
You said "very rarely used" also. The two go hand-in-hand in most cases. If you leave the drawer sit unused for months and months, this can ruin the motor rotor. The rotor comes out with no tools. Remove the dishrack, the wash arm (both simply lift off) and then the stainless steel filer/cover. This is removed by rotating the collar counter-clockwise and lifting it up. Now rotate the collar for the rotor counter-clockwise and lift the motor rotor out of the pump base. See if it spins freely. it;s probably frozen. You also can try swapping the rotor from the upper drawer into the bottom and see if that will work for you. if the rotor is bad, it is a part number 525884P and you can get them here:
http://www.fisherpaykelparts.net/ecart/item.php?item_id=231
If you find this info to be accurate and correct, please rate my answer as a FIXYA.
Thanks...
Feb 01, 2009 | Fisher and Paykel 24 in. DD603H W Built-in...
Team International Hawk Talon V3 RC Indoor Helicopter Logo
585 people viewed this question
Top Team International Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Team International Toy Expert? Answer questions, earn points and help others
