Question about Targus WORLD POWER TRAVEL ADAPTER (Retail) (APK01US) AC Adapter
Can the Targus APK01 adaptor be used with a 3-prong US device?
If you try using a three prong plug in this you don't get the security of having the item grounded. Having the ground plug helps with situations like a lightning strike, etc. You would be using at your own risk.
Posted on Sep 21, 2011
Manuals free
Your question was worded poorly and it's difficult to understand what you are asking. As a guess, if you are looking for a 30-amp adaptor cord set, perhpas this will work:
Conntek 20601 25 Foot 10 4 30 Amp 125 250 Volt 4 Prong L14 30 Transfer...
If it's a 3-prong adaptor:
Camco 55333 30 AMP 3 Prong Generator Adapter
Or a 15 to 20 adaptor:
Coleman Cable 09020 12 3 9 Inch Generator Cord Adapter 5 15P to L5 20R
Aug 27, 2014 | Electrical Supplies
Targus apa10 replacement charger when in use the blue light goes out and stops charging after 2-3 minutes. You have to disconnect the first ac cord from the charger and plug it back in order for it to...
It looks like the 65-70 watts that the Targus can provide is insufficient to both charge your notebook's battery and power the CPU at the same time. Try removing the battery to see if that solves the problem. Your Targus may be able to work without tripping when it doesn't have to do the double duty of charging the battery and operating the notebook. If you can confirm that your adaptor is tripping due to overload, you may have to get a higher power unit.
Power Accessories for Travel and the Office
Sep 08, 2017 | Computers & Internet
HI there! I am using a targus universal wall power adaptor for laptops, it has an output of 19.5 V and 90 W. I was wondering if I could use this to charge my UK laptop from ADVENT. The charger for this has...
The wattage is to different, the wattage for the adapter is 90watts, and the charge for the advent is only 65w.
You can always try it, but you risk damaging your battery, or motherboard.
Jul 16, 2011 | Targus APA30US AC Laptop Charger AC...
We have s6000 generator and a 38 foot camper that runs on 30amp. Do we need to buy and adaptor and can we use the 30 amp plug on the generator. And do we use the 4 prong or three prong
You will probably have to buy an adaptor. Read the owners manual for the generator, the 4 prong should only be for 240V. The 3 prong should be 120V. But READ the owners manual. If it is this way you should be able to get an adaptor at your local hardware/electrical supplier or any RV store.
Jan 31, 2011 | Electronics - Others
I am getting a lot of distortion feedback when I connect my computer to the mixer but the feedback only starts when the computer is connected to an electrical outlet. I have plugged the computer to a...
Sounds like a ground problem. Try to hook a ground strap or wire from the case of the computers power supply to the ground of the mixer. If it still has noise, try to touch the ground to the bracket of the computers sound card. Most likely, the computer uses a three prong adaptor and the mixer does not. Outlet grounds have voltages which bleed off from motors and other devices, which could cause the 60hz noise. If your mixer has a three prong plug do not plug your computer and mixer in separate outlets with separate grounds or you could fry your system. If you still have problems use a three to two prong adaptor and attach an isolated ground wire on the adaptor for the computer.
Jun 25, 2010 | Gem Sound CDM-150 Mixer
Gets dark wave in three waves,
The first thing I would suspect is a noisy AC supply. Try using a ground adaptor. Sounds technical, but if you every went to Grandpa's he may have been using a few and you just didn't know what they were. They are commonly used to adapt a 3 prong electrical plug to a 2 prong AC outlet. If your TV does have a 3 prong AC cord, give this a try before you do anything. It's a cheap solution and often works like a charm.
Mar 17, 2010 | Vizio Televison & Video
Trying to hook a 3 prong hook up with 4 prong cord how do i do it?
A 3 prong plug is for 240 volt (hot-hot-ground) the 4 prong plug is for 120/240 volt (hot-hot-neutral-ground). If your device requires a 4 prong plug, it is not a good idea to connect it to a 3 prong circuit (you will create a possible lethal electrical condition). If your device requires a 3 prong connection, a 4 prong cord can be used by not connecting the neutral (white wire). If you have any questions, let me know.
clarkco
Mar 31, 2009 | Maytag Dryers
Need an adaptor for a toshiba satellite
YOU CAN USE 15V 6A ADAPTOR FOR YOUR LAPTOP
YOU CAN USE 90W INSTEED OF 75 WATTS CAPACITY
Jan 23, 2009 | Toshiba Satellite 15" Flat Panel LCD...
Wall plug is 3 prong, dryer is 4 prong...is there an adaptor available?
The following link explains the wiring scheme for 3 and 4 prong power cords. I know the instructions are for converting from a 3 to a 4 prong, but if you look under the "Additional Notes" section it explains how to convert back to a 3-prong if you are currently using a 4-prong.
http://www.fixya.com/support/r793520-3_prong_4_prong_power_cord_conversion
I hope this helps you. If you have any questions, please let me know.
Aug 13, 2008 | Estate TEDX640JQ Electric Dryer
Targus WORLD POWER TRAVEL ADAPTER (Retail) (APK01US) AC Adapter Logo
415 people viewed this question
Top Targus Computers & Internet Experts
dhnguyen
J John
Are you a Targus Computer and Internet Expert? Answer questions, earn points and help others
