Question about Kenmore Washing Machines
Kenmore model number 110.26822692 we need to remove agitator due to garmet wrapped around the agitator. PLEASE TELL WHAT TO DO FOR REMOVAL. THANKS
  • budwilliams Jan 06, 2011
    We were able to remove the agitator and get the clothing out that was caught. The time for the answer was excellent. Thanks Daniel for your assistance.
  • 4,323 Answers
Hi
To remove the agitator from your washer please unplug the Kenmore washer power cord from the wall outlet. Open the washer lid and pull the fabric softener dispenser off the top of the agitator. The fabric softener dispenser lifts out with your fingers. Locate the notch in between the top of the agitator and the service cap. Insert a flat-head screwdriver into the notch to pry the service cap off the agitator. Remove the bolt on the inside center of the agitator that secures it to the transmission shaft with a socket wrench and extension adapter (Very limited space to use wrench). Grasp the bottom of the agitator with your fingers and pull it up out of the washer. It is necessary to angle the top of the agitator toward the front of the washer once you have it halfway out. This enables you to maneuver the agitator completely out of the washer. Please check the video below for details---
Hope this helps... Please post back if you need more information.
Daniel
Posted on Jan 04, 2011
Tie wrapped around the agitator. How to remove to agitator? model 267A3088P405
could not find the model number but this link may help you
http://www.wikihow.com/Remove-a-Stuck-GE-Washer-Agitator
May 27, 2011 | General Electric Washing Machines
Tooth floss got wrapped around underneath the agitator. Can't reach it to get it all out.
you would need to remove the agitator,,,pop the cap off the upper agitator and remove the bolt holding it on and just pull up on the agitator,,fairly easy to do
Mar 06, 2010 | Kenmore Washing Machines
Kenmore 90 tub spins excessively clockwise during wash cycle.
there should be 2 or 3 springs that hold it, they mite have broke, take off back panel an check.
Jan 04, 2010 | Kenmore 24032\24036 Top Load Washer
I have a kenmore top load washer, The top part of
If the bottom agitates and not the top, the problem is likely the 4 "agitator dogs" designed to allow the top agitator to turn only one way.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
The top section of a two part agitator is designed to turn only one way. If the "agitator dogs" in it are worn, it wont agitate either way.
Look at the section on the Sears site for Agitator, basket and tub.
Remove the fabric softener unit, lift the top agitator cap (use a screwdriver) and you should see a plastic part in the center of the top agitator with a 1/2" square drive.
Remove the drive and lift off the top agitator. Turning it over you should see the 4 "dogs", replace these and the top agitator should turn in one direction only.
Replace the 1/2" drive, the cap and fabric softener unit and the top agitator should work.
Also see the following on how to do it.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=136
Oct 28, 2009 | Kenmore Washing Machines
24032 \ 24036 Top Load
Unscrew the knob on the top of the agitator and remove the agitator.
Jul 26, 2009 | Kenmore 24032\24036 Top Load Washer
How to take out garmets cout underneath the
The wash plate on a Calypso is called the "nunater". The following link explains step-by-step how to remove it:
http://www.fixya.com/support/r1065026-calypso_nunater_removal
It is common for clothing to get wrapped around the u-joint, or leveler assembly. Use care when removing any garments not to damage any if these components under the nunater.
Let me know if you have any questions. I hope this helps you.
Jul 24, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
How do i remove the agitator
If this is a true Maytag, there is a 1/4 inch hex head bolt in the lower portion of the agitator, on the side. Loosen the bolt and pull the agitator off. If not a true Maytag I will need a model number.
Jul 05, 2009 | Maytag Washing Machines
Agitator removal
Yes it does, I believe the dispenser will twist an 1/8 turn and pop off. There is a cap with a handle below it that pulls out. The last part is a bolt. Try a 7/16 deep well socket with a nine inch extension, grasp the agitator and loosen it. Leave bolt intact and lift agitator from the bottom. Looking from the date if you have solved the issue this will stand as a general post for ag removal.
Jul 31, 2008 | Kenmore 22422 Top Load Washer
1975 whirpool washer
This problem is usually caused by the wig-wag not functioning. There are ele celinoids on it and they go bad. If the washer agitates properly but you just dont get the spin cycle, its probably the wig-wag. You can look up the part on sears parts site and see if it is still available or obsolete.
Mar 31, 2008 | Kenmore 2303x Top Load Washer
Washing Machines Logo
168 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
