Question about HP Office Equipment & Supplies
ERROR MESSAGE OX61011BEF WHAT DOES THIS MEAN
Why does my treadmill stop after a few seconds then error code E1 displays. What do i do?
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
True Treadmill Errors and Service Messages
  • The True 600, 700, 725 and 750 series treadmills are equipped with built-in diagnostics and maintenance reminders that display either an error message or service message as they occur.
  • The error messages that may be displayed by the built-in diagnostics are as follows:
    • E1:INCLINE
      • This means that the incline is moving when it has not been commanded to.
    • E1:MINIMUM
      • This is a minimum incline calibrating error that can be cleared by calibrating the incline.
    • E1:RANGE
      • This means the difference between the treadmills zero position and maximum incline is not sufficient.
    • E1:STALL
      • This means that the incline is not moving when it has been commanded to.
    • E2:OVERSPEED
      • This occurs when acceleration greater than 2.1 mph occurs as this is greater acceleration than anticipated.
    • E2:CAL
      • This means feedback cannot reduce or increase speed to target and error can be cleared by calibrating treadmill.
    • E3:EEPROM
      • This error happens when a data error is detected on the EEprom. The control panel needs replaced if this error occurs.
    • E5:SENSOR
      • This error occurs when there is no speed or RPM feedback detected from speed sensor.
  • The service messages that may be displayed by the built-in maintenance reminders are as follows:
    • S1:LUBE
      • This service message displays when it is time for inspection of the deck lubrication system.
    • S2:CLEAN
      • This service message displays every 500 miles and is your prompt to clean the treadmill.
    • S3:MOTOR
      • This service message displays every 2500 hours and is your prompt to check the motor brushes.
  • This information should help you understand the cause of the error message or code and how to take action to repair your True treadmill
Errors for True Treadmills E5 Sensor E2 Cal S1 Lube and more
Oct 12, 2015 | Exercise & Fitness
When this comes up ox61011BEF how do I repair it?
that code is for the ink cartridge. it is either incorreectly installed or incompatable. try replacing it with a HP cartridge set.
Jan 06, 2015 | HP Officejet Pro 8500 A910A Multifunction...
What does error message number 9 mean on my kymco mini s mobility scooter?
hi, it's a controller trip error message this can mean a bad connection or at worse a controller fault ...
Regards
Rob
May 05, 2014 | Health & Beauty
Janome MemoryCraft 6500. What does error message "BM init error" mean? What does it take to fix it?
That's an initiation error. I would call Janome direct and ask them.
Dec 02, 2012 | Sewing Machines
I have HP 6500 series printer. I am getting this error OX61011BEF. The papers are going through the printer without printing
Hello and Welcome to FixYa
Sir/Ma'am, Error 0x61011BEF usually occurs in HP Office jet Printers.
To solve this error try the following steps:-
1.Without turning off the product, disconnect the USB cable from the rear of the product.
2.Remove the cartridges from the printer
3.Wait for the 'Insert Cartridges ' message to display on the control panel.
4.Disconnect the power cord from the back of the product.
5.Wait 60 seconds.
6.Reconnect the power cord. If the product does not automatically turn on, press the Power button
7.Reinsert the cartridges, and then close any open doors on the product.
8. If you receive a prompt to print a calibration page, do so.
9. Reconnect the USB cable to the rear of the printer
Try printing again.
If the error still exist try to reset the printer to the factory defaults:-
1. Unplug the power cable from printer when the printer is powered on and wait for 20 seconds.
2.Then, press and hold # and 6 while plugging in the power cord and continue holding until it displays semi full reset message in the front panel
If you have completed all the preceding steps and are still experiencing this error then it surely be an hardware issue and it cannot be fix up here. In this case Determine if your product is in warranty or out of warranty.If your product is in warranty , Simply contact to HP Service Center or from where you purchased it and claim the warranty. Your problem will be solved
I hope this solution helps you and you have clear picture in your mind
Let me know if you have any confusion in your mind.
Sir/Ma'am, Your Rating as Five Stars for this solution and Words of appreciation as Feedback for me will be really esteemed
Thank You for taking my service
Concerned: Muhammad Uzair Team : FixYa
Nov 13, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
GETTING ERROR ox61011bef, what should I do to fix this problem
1. Plug it directly into the wall, rather than into a UPS
2. Verify that the unit is switched on.
Disconnect the USB/Ethernet cable from the All-in-One and also disconnect power cable from All-in-One and also from wall outlet.
3. Wait 30 seconds.
4. Plug in the power cable to All-in-One and also to wall outlet.
5. Check for the functionality.
(repeat the procedure but remove and check the cartridges too ..Close any lids you opened .)
If the issue persist ..try to reset the printer to the factory defaults as it follows:
2. Then, press and hold # and 6 while plugging in the power cord.
Continue holding until it displays Semi Full Reset message in the front panel of the All-in-One.
If those two steps do not resolve the problem then its is hardware related and can't be solved here.
Error code OFOO:O75D error:OFOO:O244
Is this from a blue screen error ?
A "STOP" MESSAGE in white letters behind a blue background?
If it's a sata message (hard drive error message), this means that your harddrive is dead or about to die. Most likely its already dead, this error means also that the harddrive cant be read anymore.
Mar 05, 2010 | Dell Inspiron 1501 Notebook
TE message. machine turns on but nothing else. I found out the message means a thermastor problem
Perhaps the error is "[-E" and it means the thermistor is out of error. Replacing it will correct the problem
Apr 27, 2009 | LG WM2277H Front Load Washer
Help Toshiba E-Studio 162 Copier error
how can I reset the Toshiba estusio162 without calling for maintenance
Sep 03, 2008 | Toshiba e-Studio162 Copier
Jenn-air Oven Model W256W
just scroll down on this e mail and in the comment box you can answer my question
Feb 14, 2008 | Jenn-Air JGW8130A Electric Single Oven
274 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
