Question about Whirlpool Washing Machines
Hi, we have had some problems recently with water remaining in the tub after the spin and rinse cycles are complete. Tonight, I removed the hose from the back of the machine and a fair amount of water came out. From that, I'm guessing that something is blocking the base underneath. do you have any suggestions? Thanks, Mike
  • honeymokey
    honeymokey Jan 04, 2011
    Is it spinning real fast ?
  • kingsley_mic Jan 04, 2011
    No, just like normal. The water just doesn't leave. I figured it was a little sock or something, but if there is, it is somewhere else.
    President:
  • 3,113 Answers
Need a model number.
Posted on Jan 04, 2011
  • 1 more comment
    Model #LSQ96591WO
  • honeymokey
    Here this might help you. The outer tub has a screen where the hose to water pump connects."not shown". If you machine does not spin fast it will not get all the water out or you may have a blocked pump. Remember the faster it spins the stronger the pump is. A worn clutch will make one not spin very fast.
  • honeymokey
    http://www.appliancepartspros.com/partse...
IN THE WASH CYCLE THE TUB FILLS ALMOST TO THE TOP THE DRAINS. THE OL CODE THE APPEARS AT THE END OF THE CYCLE
Hi, the OL code means Overloaded..
OL flashes when the machine/motor control detects a load size that exceeds the washer's capacity.Open the door lid to clear display, remove excess laundry, then restart the cycle.
Oct 04, 2010 | Whirlpool WTW6400SW Cabrio Washer
Have a front load Kenmore elite He3t washer...goes through a complete cycle including spin but clothes remain wet...spin seems to be slow
There is a water pump in the machine which pumps the water out of the outer tub and into the drain, after the wash and rinse cycles.
It is possible that this pump isn't working properly. I think if it weren't working at all, you wouldn't be able to get beyond the wash cycle.
It has been my experience that small articles of clothing may get washed or spun out of the inner tub and into the area around the pump pick up, thus partially blocking the flow to the pump.
It's also possible that the drain hose from the pump to the drain may be partially clogged.
It is also possible that the pump doesn't run sufficiently long to get all of the water out because its' motor gets hot and shuts down or because of a problem in the control mechanism which manages the the starting and run time of the pump.
First, I would unplug the washer from the wall outlet and probe under the inner tub, or possibly remove the tub to see that there is no blockage from clothing.
It's also possible that things left in clothing pockets like paper clips, small plastic items, etc. can get into the pump and lock up the impeller.
If you're sure it isn't blocked you can then run a "short cycle", no load and water only, and watch to see how much water comes out of the discharge hose where it's hung on the drain pipe.
It should gush out, and tub should be free of standing water prior to the start of the first rinse cycle.
If it does not, then you'll have to access the pump and clear it of obstructions or replace it, if defective.
As it drains, it should start spinning slowly, then speed up as it drains; the final portion of the spin cycle is very fast.
Essentially, the spinning tub wrings out the clothes using centrifugal force.
With the water remaining in the bottom of the tub, it would appear that it is:
a) not spinning long enough, or
b) there is something preventing all the water from getting out in the time allotted by the timer to perform this task.
A fair handy man can get to pump either from the rear of the machine with back plate off, or by removing the cabinet cover from the frame, depending on the model of the the machine.
As always - before attempting any repair, UNPLUG THE UNIT!
When clothes are wet at the end of a cycle, check these:
Motor coupler
To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning:
If it's spinning when you lift the lid, the coupler is fine.
If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
Spin cycle
If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component.
Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician.
Siphoning
If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess.
Water-inlet valve
Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question*^%%
Jan 25, 2010 | Kenmore Elite 45986 Front Load Washer
The rinse cycle on my washer leaves soap and the spin cycle leaves water. I've decreased the amount of soap and ran through another spin cycle with no change. I ran the spin cycle while watching it and at...
Good day,
There is blockage between the outlet of the tub on the machine to the end of the hose.
First, if you have the outlet hose that is fitted into a standpipe, that could well be the problem.
In other words, there is nothing wrong with the washer, it is plumbing problem in the vertical drain pipe. Happens often.
Shut the water to the machine off, remove one of the hoses, and stick it into the stand pipe. Turn the water on. If it backs up, that is your problem.
If not, then the machine is at fault. A hose runs from the bottom outlet of the tub to the pump. Then from the pump to the outlet hose.
You'll need to remove the hoses, and pump to inspect them. It's even a possibility the pump's impeller is slipping, and lastly, check closely where the hose was removed from the bottom of the tube. Could be the classic "sock" problem.
You did not give the model. Get that information, and then type into google....................
"How to change a water pump on a ( your info) washer".
You'll get the hits you need to see how to access the pump and related accessories.
Dec 09, 2009 | Kenmore Washing Machines
The final rinse isn't rinsing thoroughly. I have
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
Aug 30, 2009 | Kenmore Washing Machines
Our whirlpool duet washer ghw9150pw0 not draining water
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question******
Aug 27, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Kicking out water during wash cycle - spin instead of agitation
Try these
  1. Check the drain hose, it should be at least as high as the top of the wash tub, about 38 inches.
  2. The drain hose must sit loosely in the house drain. Do not seal the air gap around the drain hose or a siphon will occur.
  3. Check the drain control lever
  4. Test the drain control coils
  5. Check the cam bar
pls rate my suggestion..
Jul 19, 2009 | Maytag LSE7806A Top Load Stacked...
GE prodigy washer Water remains in the bottom of the basin after teh cycle has ended
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
Apr 30, 2009 | Washing Machines
Hoover Saver 1300 Washer Dryer - drum not emptying fully
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
Feb 18, 2009 | Washing Machines
Incomplete wash cycle.
It sounds as if you have something acting as a flap causing the restriction. You should take the hose that leads from the tub to the pump off and see if there is anything just inside the tub. I have noticed that alot times you could have a coin that blocks the opening. You may have to remove the inner tub to remove anything in there
Dec 30, 2008 | Maytag SAV3655A Top Load Washer
GE Nautilus won't drain after Rinse Cycle
Check disposer plug. If a garbage disposer has been recently installed, it is possible the disposer drain plug was not removed. The drain plug is a plastic piece in the disposer that blocks the hole where the dishwasher hose connects. Also check the hose connected to the disposal. Mine apparently had a kink in it. When I straightened the hose the dishwasher drained at full speed (I recently had a plumber re-route a hot waterline. He must has bent the hose). Hope this helps. If not go to the GE website. That's where I found my answer.
Nov 03, 2007 | GE 25 in. Nautilus GSC3400J Free-standing...
Washing Machines Logo
20 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
