Question about Siemens SpeedStream Modem (4100) (SS4100)
How do you achieve a nat type 1 or a nat type 2 connection to a playstation3?
  • 708 Answers
PS3
You will have to open the following ports in your modem /router
Make sure the firewall is disabled in the Modem /Router
Make sure that UPnP is Enabled
Playstation Network Required Ports
TCP 80
TCP 443
TCP 5223
UDP 3478
UDP 3479
UDP 3658
Playstation Online Game Ports
Call of Duty 3:
UDP 3074
TCP 3074
MotorStorm
UDP 3659
UDP 3660
You can use http://whatsmyip.org/ports/ to test if the ports are open.
Posted on Jan 09, 2011
I am trying to games on PS3 and cannot connect with friends. I believe this is because I have NAT Type 3 (closed) and I would like to change it to NAT Type 2 (moderate) but I do not know how.
Hi ..
The PS3 has 3 different NAT types. They are shown below.
Type 1: The PS3 is connected to the Internet without a firewall or router. No NAT issues.Type 2: The PS3 is connected to the Internet through a router which is configured correctly. No NAT issues.Type 3: The PS3 is connected to the Internet through a router that needs configuring.Ideally, you want to have a Type 2 NAT. However, a Type 1 NAT does not affect your game play.
First of all you will have to Disable the firewall in the Router / Modem
If you are using a Router ..
Then
Make sure that UPnP(Universal Plug n Play) is enabled
Enable the IP Address of the PS3 in DMZ
Or Forward the ports
Below are the TCP and UDP ports that need to be forwarded:
TCP: 80, 443, 5223
UDP: 5223, 3478, 3479, 3658
For more details on port forwarding , log on to http://portforward.com/english/routers/port_forwarding/routerindex.htm
Hope it helps
Regards
Tom
Aug 18, 2011 | Computers & Internet
I cant play online becouse of this a NATtype3 what dose this mean
Nat 3 is the result of being hooked into a router without being properly setup for data transfer. essentially it is restrictive.
There are 3 ways to change your Nat type to type 2 or 1. (Nat type 2 meaning that it is properly setup without restrictions behind a router, and Nat 1 being a direct connection to the Internet).
1.) Hook the PS3mag-glass_10x10.gif directly into the modem will result in a Nat type 1, but of course that means disconnecting everything but the ps3 and that's an unnecessary hassle.
2.) Going into the router settings and Port Forwarding the PS3's necessary ports to the Ps3's ip address.
3.) Probably the simplest (on most routers) and most effective is to go into the router and set the PS3's ip address in the DMZ (DeMilitarized Zone), essentially the router doesnt have any say from what comes and goes to the Ps3, which is good so the connection isn't hampered.
Feb 14, 2011 | Sony Playstation 3 (PS3) Console
I can't change the nat type for ps3 or call of duty black ops how do i change the nat type
When you do a connection test on your PS3, what NAT type shows up; 1, 2, or 3. If you're worried about the STRICT NAT type in Black Ops, don't worry about it, the problem is the game and not your router.
http://forums.dlink.com/index.php?action=printpage;topic=21218.0
Feb 06, 2011 | D-Link Xtreme N DIR-655 Wireless Router
How do you change from nat type 3 to nat type 2 on this router
To reduce the NAT
1 ) Disable the firewall in the router
2) Enable the Playstation in the DMZ
3) Make sure UPnP is Enabled
Jun 22, 2010 | Siemens SpeedStream 4200 (13A4200001)...
How do i change my nat type
go on a computer.
1. in the internet address bar type in 192.168.1.1 or routerlogin.net
2. enter admin and password in the fields
3. your now in your routers setup
4. find a setting called nat
5. set it to open instead of secure
this changes your nat type to 2
if that doesnt work
1. login to router as usual, but find a setting called default dmz server
2. enter the IP address of your PS3 as the dmz server (to see what your ps3's ip is go to network > connection settings and have a look.
this should definitley make it a nat 2 - but try the first method
Apr 27, 2010 | Sony Playstation 3 (PS3) Console
NAT Type 3
You need to give it a static IP.
Follow these instructions.
Video walkthrough here.
May 12, 2009 | NetGear WGR614 Wireless Router
How do i set my nat to open
I believe you want your Playstation3 or XBOX 360 to work, am I right? If you wanna set your NAT to open, you need to do Port Forwarding. Contact XBOX or Sony and ask for the port number that you need to open on your router. That's should do it.
Apr 15, 2009 | Belkin (F5D8231-4) Wireless Router...
Halo 3
make sure the security settings on router is WEP-Personal. I don't know what you have for internet but Dial-up, DSL, and satellite internet will not get NAT 1.
Mar 14, 2009 | Linksys WRT54GX2 Wireless-G Broadband...
Help?
You most likely have a NAT Type 2 or 3 you need to get it to NAT Type 1. If you are using a router contact them and try to open ports for the PS3. Also internet might not support NAT 1. Dial-up, DSL, and Satellite at best get NAT 2
Oct 27, 2008 | Video Game Consoles & Games
NAT
Everyone has NAT, whether its strict (which i'm guessing yours is) mederate, or open.
Open NAT can be achieved by buying a new router or connecting your 360 via ethernet to your modem. If you connect it to your modem, restart both the modem and your 360 and you WILL have an open NAT
-Erk
Jun 08, 2008 | Microsoft Xbox 360 Console
Siemens SpeedStream Modem (4100) (SS4100) Logo
970 people viewed this question
Top Siemens Computers & Internet Experts
Prashant M
Prashant M
john smith
Are you a Siemens Computer and Internet Expert? Answer questions, earn points and help others
