Question about Maytag Washing Machines
MAV95O1FWW start switch is broken - Maytag Washing Machines
  • cande561 Jan 04, 2011
    It is switch on the lid that turns on the washer when you close it.
    Top Expert:
  • Maytag Master
  • 9,472 Answers
Not sure which switch your talking about but here is a link to the page with all the parts for your washer.
Posted on Jan 04, 2011
Thanks.. I have a onan 7500k living in from the storm. Will not start with remote inside switch. But you can shut it off with inside switch. Outside switch works great.
Need more info.
Inside does it have an 'on/start' switch and a separate 'off' switch ?
If it does -
1) the start switch is bad.
2) could be a broken/loose/corroded wire at the start switch 3) broken/cut wire to the Onan
4) broken/loose/corroded wire at the Onan where the inside start switch connects.
The fact that it starts at the Onan tells you it's OK.
Sep 17, 2017 | Electrical Supplies
How do I replace a broken start switch
Washer Start Button Replacement -GE Top-Load Washing ...
? 2:05
https://www.youtube.com/watch?v=tEVwT4mL9ZU
Sep 27, 2012 - Uploaded by RepairClinic.com
This video provides step-by-step repair instructions for replacingthe start button on a GE top-loading washing ...
Cabrio Washer Start Button Broken Quick Fix - YouTube
? 5:54
https://www.youtube.com/watch?v=h1CRcehOCxY
Mar 23, 2015 - Uploaded by FreidasGarden
This video is about Cabrio Washer Start Button Broken QuickFix. I hope it helps you get some wash done
Nov 28, 2015 | Washing Machines
Ge electric dryer dpsr483ea1ww, dryer stops when start switch is released
Broken belt or broken belt switch or broken wire or bad motor.
Sep 05, 2012 | GE Dryers
I have a GE Profile Prodigy eletric dryer that wont start. When I turn the switch it hums and stops when I let go of the switch, but won't start. Is that a switch problem or motor? How do I tell?
That sounds like to me the drum belt is broken..GE dryer use a belt switch that if the belt is broke will perform exactly as you describe ..as long as holding the start switch the motor will run and as soon as you release the start switch the motor will stop.
To check for a broken belt remove the top by removing the 2 phillips headed screws inside of the door at the top of it and pull off the top to see if the belt is in place and attached to the drum..if no belt seen when top off its broken and laying down in the base frame
GENE
Aug 28, 2011 | Dryers
Dyer will not turn on. Can hole the starter button in and dryer will run. remove and the dryer will stop running. When holding the start button the dryer does not heat. Any Idea's as to what may be...
broken belt or broken broken belt switch most likely. Open the door. Hold in the door switch and push the start button. Does the drum turn? If it does turn then the broken belt micro switch is where I would look first. If the drum don't turn of course I would replace the broken belt.
The only Kenmore dryer that has a broken belt switch is the 4 wheel drive model. Here is a video which shows how to get into this dryer and replace the belt:
Jul 08, 2011 | Kenmore 63932 Electric Dryer
My Kenmore 800 series dryer won't start when i push the start button. It does start to spin but stops after i release the start button. Any ideas what the problem might be??
This dryer has a broken belt switch. If the drum turns then the belt is not broken but the broken belt switch could be. The start switch itself could be the problem. This video shows how to get into your machine:
Sep 02, 2010 | Dryers
My frigidaire stackable dryer wont turn on when i turn the start switch any clues?
The dryer will not start with a broken door switch. Replace the door switch if found defective.
Most dryers have a door switch actuator lever - when you close a dryer door, it presses against the lever, which actuates the door switch. If the lever is broken, the switch will not activate and the dryer will not start. Replace the lever, if broken.
Note: Door switch actuator lever usually comes with the door switch assembly and it is recommended to get the whole assembly since there is almost no price difference between the door switch assembly and just the lever.
I would also check the thermal fuse as well. it is located on the vent duct or blower housing. If this fuse is damaged or tripped, it will not allow the dryer to run as well.
Jul 20, 2009 | Frigidaire GLEQ2152ES Electric Dryer
Dryer drum will not turn
Note: Door switch actuator lever usually comes with the door switch assembly and it is recommended to get the whole assembly since there is almost no price difference between the door switch assembly and just the lever. Check your model for more details.
Jul 20, 2009 | Dryers
Dryer just stopped
Most dryers have a door switch actuator lever - when you close a dryer door, it presses against the lever, which actuates the door switch. If the lever is broken, the switch would not activate and the dryer would not start. Replace the lever, if broken.
I would also, check the Thermal Fuse as well.
Jun 25, 2009 | Kenmore 62602 Electric Dryer
Dryer knob sticks in one spot- won't move
 Door switch / Door switch actuator leverThe dryer would not start with a broken door switch. Replace the door switch if found defective.
Oct 25, 2008 | Maytag Clothes Dryer Almond Timer Knob...
Washing Machines Logo
14 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
