Question about Vacuums
How do i operate self clean mode - Vacuums
  • 43,501 Answers
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
Posted on Jan 04, 2011
How to get it to do self clean and how long is it suppose to take
Electrolux Self-Cleaning Oven ' Electrolux Kitchen Range ...
? 0:47
https://www.youtube.com/watch?v=JNVPSVe_MV0
Mar 25, 2015 - Uploaded by Universal Appliance and Kitchen Center
Electrolux fresh clean feature is the perfect ingredient for cleaneroven, with 3 different levels of cleaning .
Manually Starting Self Clean cycle on Electrolux Washer
ths.gardenweb.com > Home Forums > Laundry Room
Feb 10, 2011 - So, I want to do a self clean cycle manually. ... wake up washer by pressing any button rotate cycle knob to handwash press start and then cancel. ... I am not sure my machine is operating on the clean cycle.
Nov 23, 2015 | Electrolux Vacuums
After cleaning the filter the self clean just keeps on flashing and will not go back to working mode
First thing to do is double-check and make sure everything is reinstalled just as it was before taking it out - if something is out of adjustment or not aligned properly it can cause problems and the vacuum may think there's still an issue. Double-check that (and clean up any parts that you can reach or remove) and let me know if it helps out. If so, great. If not, we'll take the next step.
Aug 25, 2008 | Electrolux Vacuums
Can't lower handle on Hoover wind tunnel vac U6432-900
Anne, Do you mean that when you depress the pedal on the left side of the machine body that you can't get the upper portion to release into a lower mode? Or are you fully depressing the pedal?? As for the switch for the self propelled mode, that's actually just a small button that you move around in the slot of the handle to select which mode you want to use. It's not actually a switch. If you are fully depressing the handle release pedal and it's not releasing, you should take it to the store where you purchased it, if it was a vacuum store. If you bought it at a big box store, then you'll need to take it to some repair shop that does warranty work, if it's within the warranty period of course.
Nov 10, 2013 | Hoover U6437-900 / U6439-900 Windtunnel...
Self clean and power lights flashing on electrolux
you either need new filters or you have a bad electronic board or possibly both. Most of these machines only last a couple of years. Not to discourage you, but do yourself a favor and don't buy another one. It's a chinese made Eureka with a lux label. Electrolux went bankrupt many years ago and Eureka bought the name. Miele, Sebo, Riccar, or Lindhaus are all better choices.
Oct 19, 2013 | Electrolux Twin Clean Bagless Canister...
I have the Hoover, self propelled vacuum. I have only used the self propel function a few times, but our babysitter used the feature and now the vacuum only works on the highest carpet setting. The middle...
Move the carpet height control switch to a higher position if the vacuum is difficult to push. If the setting is too low for the carpet being cleaned, the brushes press against the floor preventing the vacuum from moving easily.Set to a medium-high height setting then check.Slide the "Self-Propel" button to the "ON" position if the cleaner does not self-propel. -----------
The self-propel feature operates only when the cleaner switch and the self propel button are both ON. ---------- Try this settings and check.This should help.Thanks.Helpmech.
Jun 24, 2011 | Hoover Self-Propelled WindTunnel Bagless...
Just put handle on windtunnel u6401-9rm and the self propelled switch will not flip into self propel mode. is there an adjustment on the self propel part?
When installing the handle on this machine, you must be sure the on/off switch and the self propel button are both in the OFF position. The actual switch inside must also be OFF, and the metal fitting on the end of the power drive cable should be between the two lines molded into the plastic. After it is re-assembled, it is sometimes necessary to wiggle the handle up and down a bit to engage or disengage the drive button.
Mar 16, 2011 | Hoover Floormate H3000 Upright Wet/Dry...
How to clean the iron it has scorch marks on the bottom. It has a self cleaning button
To remove the scorch marks the self cleaner might not work so well as doing a manual job. So get a good degreasing spray and use it to wipe off the marks. Do not scratch or use any hard wipes to strach the iron but only to achieve with cleaning.
Aug 31, 2010 | Vacuums
My vacuum has good suction the belt is good and i cleaned all the filters but it still wont pick up anything or pull itself
sounds like its self propelled, if so check your belt and self propelled switch. John
Oct 18, 2009 | Vacuums
Direct Drive System on Kenmore 31913 Vacuum
you need to reset it on the front. overload reset button
Oct 29, 2007 | Kenmore 31913 Progressive Direct Drive...
Vacuums Logo
35 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
