Question about Kenmore 54701 Dehumidifier
How do you test solenoid?
How do you test the solenoid on the refrigerant coils? my dehumidifier only gets cold near the valve. If it is defective do you have to recharge the
system once it is replaced or is there some kind of fitting that keeps the gas in the system once you remove the bolt?
  • 770 Answers
No there is not the freon should never escape you have a leak in the system
Posted on Jul 09, 2008
Freezing up and bucket not filling
The coils you see on the back of your dehumidifier are the evaporator. When the unit runs, the coils get very cold. As the fan draws the room air over the coils, the humidity in the air condenses out of the air onto the cold coils. But, if the temperature of the air the fan draws over the coils is too cool, the humidity that condenses out of the air freezes on the coils. To remedy this problem, you can try any of these: Warm up the room the dehumidifier is in. Put the dehumidifier on a sturdy table (the room air is coolest near the ground).
Turn the unit off until the room warms up.
Good luck
Aug 19, 2010 | Kenmore Dehumidifiers
Freesing up and bucket not filling
The coils you see on the back of your dehumidifier are the evaporator. When the unit runs, the coils get very cold. As the fan draws the room air over the coils, the humidity in the air condenses out of the air onto the cold coils. But, if the temperature of the air the fan draws over the coils is too cool, the humidity that condenses out of the air freezes on the coils. To remedy this problem, you can try any of these: Warm up the room the dehumidifier is in. Put the dehumidifier on a sturdy table (the room air is coolest near the ground). Turn the unit off until the room warms up.
Take care.
Aug 19, 2010 | Kenmore 5230 Dehumidifier
The coils freeze up after less than a half hour of running. It does not matter what humidity setting I use or if I select the 2 hour or 4 hour run cycle. B/c the coils are freezing up, the dehumidifier...
the coils freeze up for one of two reasons .. if air flow is blocked .. sometimes by dust buildup or fan bearings needing lube .. second if the fan is working properly then ice buildup can be caused by low refrigerant levels .. the proper charge produces a steady coolness across the entire evaporator (cold coil) .. as the level drops it tends to cool a small part of the evaporator way too cold .. that creates ice .. the ice blocks the air flow and soon the whole thing is blocked ...so check the fan first .. if its running properly and there is nothing blocking air flow then suspect low refrigerant.. that requires adding a saddle valve service port to the system to allow adding refrigerant .. often the problem is caused by the fan not working at all because of lack of lube in the bearings or a bad starting capacitor ..
Aug 15, 2010 | Goldstar DH504EL Dehumidifier
Hi I have a Danby DDR3008EE dehumifier that is putting water on floor There is ice inside where the filter is. What should we do besides turn off and let melt?
Good luck.
Aug 14, 2010 | Danby DDR3008EE Dehumidifier
My dehumidifier ices up. It will not remove moisture when it ices up. What can I do and is it under warranty?
Take care.
Aug 10, 2010 | Fedders A7DH45B2A Dehumidifier
Unit runs but the coils dont get cold
The compressor should be cool near the bottom and hotter at the top. If it runs but the coil is not cool, it probably lost its charge. Developed a leak and lost all the refrigerant.
Jun 28, 2010 | Fedders A7DH45B2A Dehumidifier
Dehumidifier efficiency
I'm surprised that you are trying to dehumidify if you are in the northern hemisphere right now.
But, before you go off trying to fix the refrigerant, see if you can get a glass of ice water to sweat near the dehumidifier. While relative humidity might be high in cold climates right now, it's a relative number, as the total grains of moisture is far lower than what it would be in a warmer climate. Cold air saturates easier, because it holds less, moisture.
Most people use a humidifier in the winter because they want to saturate the air with water, which is better for the human body, and minimizes static electricity.
I can help you diagnose the dehumidifier if you want. The coil should only get to 40 degrees or so. But the sweating glass of water will tell you if there is enough moisture in the air for the dehumidifier to wring out.
Jan 30, 2009 | Haier HDN655E Dehumidifier
Fan fixed but evaporator solenoid keeps activating at times
the purpose of the valve is to de-ice the evaporator and the valve is turned on by a timer usually. in normal operation, the evaporator builds up with ice (that is how water is extracted). when the valve operates, to put it simply, the hot gas is routed to the evaporator and hence melts the ice off
Aug 28, 2008 | Goldstar DH504EL Dehumidifier
Frigidaire MDD40WW2
Your dehumidifier may be low on refrigerant. Seems cold may not be cold enough to reach the dew point to condense moisture from the air stream.
May 09, 2008 | Frigidaire FDL45P1 Dehumidifier
Kenmore 54701 Dehumidifier Logo
146 people viewed this question
Top Kenmore Dehumidifiers Experts
Bill Long
Mike Squire
Are you a Kenmore Dehumidifier Expert? Answer questions, earn points and help others
