Question about GE Profile JT912 Electric Single Oven
Oven does not heat to desired temp. It is a GE spectra
  • Barrett Palumbo
    Barrett Palumbo Jan 04, 2011
    Sorry to read about your issues.
    But you really need to give us the make and model, off of the sticker on the oven, by the door of your unit. It kinda helps us to help you. and a more detailed explanation, of whats is going on..
  • GE Master
  • 43,501 Answers
If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Posted on Jan 06, 2011
GE Oven 326B1230P001 - Ovens won't heat to desired input. Input 350F for top oven, it only reaches 275F, input 350F for bottom oven, it reaches 325F. All elements are in great condition and turn red when...
FIRST HOW ARE YOU DETERMING HEAT OUT PUT WITH ONBOARD TEMP READING OR WITH A OVEN THEMOMETER THAT YOU PLACED IN OVEN EITHER WAY IT COULD BE A CALIBRATION ISSUE
Apr 21, 2014 | Ovens
I have an XL44 GE Spectra Oven/range. The cleaning feature no longer works and recently we have experienced the oven not getting to the desired temp for both Bake and Convection Bake. We set it to 350 and...
Page 22
Of the service manual shows your diagram. The oven sensor should read 1100 ohms @room temp (75f) All these new fangled electronically controlled ovens use a sensor. The negative temp coefficient sensor relays back changes in resistance whenever the temp changes inside the oven. If that sensor is not correct, open, or shorted to frame then the control will not function properly.
More here
Aug 23, 2011 | Ovens
GE profile Spectra gas range/oven is taking approx.20-30 min to preheat. Once it finally reaches temp. it seems to hold at that temp and maintain it. I have noticed occasional puffing sounds when it...
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Apr 17, 2011 | Ovens
My GE oven heating element heats red hot no matter what temp I put the oven on
Something is probobly wrong with the thermostat, it gets hot to warm up, but should lessen as it reaches your desired temp. If the thermostat is bad it will just keep going.
Nov 20, 2009 | GE Profile JTP18 Electric Single Oven
The oven pre heats to desired temp and then loses
SOUNDS LIKE THE TERMOSTAT IS FAULTY REPLACE IT AND YOUR OVEN SHOULD WORK FINE.
Nov 09, 2009 | Thermador SMW272 Electric Double Oven
My Mother has a GE oven which is not working properly. The problem: the oven is turned on to bake,it heats up to the desired temp, works for awhile and then the oven just turns itself off and there is an...
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Asker's Testimonial " thanks i will have my husband look into that. " - 2gunsally
Oct 27, 2009 | GE 30" Built-In Single Electric Wall Oven...
My ge spectra stove bake element is not heating
I have a GE Spectra stove. The top element over heated and broke in half.
Dec 18, 2007 | GE JKP20 Electric Single Oven
Oven Temp
After it drops temperature, how do you get it back to the desired degrees? It sounds like the thermostat isn't keeping up.
Nov 15, 2007 | Whirlpool RBS245PDS Electric Single Oven
GE Profile JT912 Electric Single Oven Logo
213 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Are you a GE Oven Expert? Answer questions, earn points and help others
