Question about Samsung RM255LASH Side by Side Refrigerator
How do I level a 3 door samsung refrig tile floor is lower on the right side by 3/8". Tks Jerry Rohe Mail2rohe@aol.com.
  • 1,531 Answers
There are two screws they may be white on the bottom of the fridge turn them down and you should be able to level it off
Posted on Jan 04, 2011
Is there an adjustment to tighten the refrigerator doors to stay open? Samsung refrig it is balanced.
You can adjust the front and back levelers that touch the floor so that the fridge tips forward just a bit. If you don't have a level, but do have a smartphone, there's a level built in, or you can download an app. Get some help adjusting the levelers -- fridges are heavy beasts.
Aug 04, 2016 | Samsung Refrigerators
Can plywood be glued to tile floor before laying vinyl planks ??
There are cement based compounds on the market that will allow you to just go over top of your tile floor. Make sure your tile floor is not loose anywhere, clean the floor well and use a patching compound over the existing tiles (this will fill in the grout lines and any uneven areas of the tile). It may take a couple of coats, maybe even 3 to get the floor smooth and level. You should be able to install your vinyl right on top of this and not have the added height of the plywood. If you insist on the plywood you could use a good quality construction adhesive with drilling and installing screws.
Mar 06, 2015 | Building Materials
Water leak samsung rm255barb
sorry,don't have same refrig nor that kind of problem so can't help you!
May 29, 2014 | Samsung RM255LASH Side by Side...
Arcylic shower base installed backwards
If it were mine... I'd kick myself several times (yeah, I've done stuff like that), then bring in a 4" angle grinder with a cutoff wheel. That would cut the flange MUCH faster - and generate far fewer sparks - than a belt sander. Work really carefully, though, and maintain really close control so the angle grinder absolutely stays level while you work. In fact, this would be a good spot to make up a special little jig to keep the angle grinder level and supported at one uniform height all the way across the door.
May 11, 2014 | Plumbing
I have a built in Hot point dishwasher that is 15 yrs old. I will be putting a ceramic tile floor down. Will I be able to pull the dishwasher out with no problem?
thank you for thinking about and asking that..i have serviced so many dishwashers where their was new flooring and they were tough to pull out..the best thing is remove the lower panel and raise the legs,and even if it is scrap from a peice of tiles that is cut slip that tile under then lower the legs so the legs will be at the same level of the floor and come out easily in the future..their is no need to even use tile mastic or grout under the dishwasher since it will be hidden by the panel
Aug 24, 2011 | Hotpoint Dishwashers
Can ceramic tile be installed over old ceramic tile?
You can install tile over tile. However here are the risks. The new tiles will require at least 3/16" of tile adhesive UNDER the tiles when put in place after they have been pressed into position. Additionally the trim around the tiles willhave to be removed and elevated the distance of the tile thickness and the 3/16" grout distance. The tiles if on the second floor of a home will easily losen due to the expansion and contraction of the home and the difference in the 2 types of tiles expansion and contraction rates.
It is not difficult to remove old tiles. You use a flat bar type scraping tool and the old tiles usually will pop right up off the floor. You will have to break maybe 2 tiles to get started but after that they are easy to remove.
My experience in my own fully tiled in all rooms 2900 sq ft home in the tropics is that I have to remove the old tiles as over time the new tiles losen on top of the old tiles. I have tried it several times and have had at least 1 tile come loose each time.
Thanks for choosing FixYa,
Kelly
Oct 05, 2010 | Home
How do you level the refridge side to side?
Hi, normally, the units have a screw in type foot at each corner to level the unit. To raise a corner you would turn the round like foot CW. You may need to push on the corner you are working on to relieve pressure and also use a pair of pliers or channel lock pliers to turn them, but this is how it is done. Just remember, to raise you turn it CW which puts pressure on the floor and CCW to lower it, it will screw back into the box. To raise the right side you will go CW screw out and to lower left side go CCW screw in to lower.
Sincerely,
Shastalaker7
Jun 30, 2010 | Samsung RF265AA Bottom Freezer French Door...
How do I get it level on the floor? The doors are uneven because the refrig is not level on the floor what do I do?
on the bottom of the fridgerator there is small feet that screw up and down to ajust on the frunt and rear it uses a 1/2 wrenh or 9/16 inch wrench to raise or lower the feet. however the door screws on top and bottom could be loos as well.
Apr 14, 2010 | Frigidaire 22.6 Cu. Ft. Counter Depth...
How do you remove the refrigerator door of a whirlpool side by side so we can replace the lower cam ?
Remove the top hinge cover , and the 3 top hinge screws . Then , lift the refrig door , off the bottom hinge . Set the door on the floor , and tilt slightly , enough to get a nut driver or ratchet , under the cam on the door . Also replace the cam on the bottom hinge .
Dec 09, 2009 | Whirlpool Refrigerators
I need help to level my kitchenaid fridge, and the owner manaul does not show this.
leveling refrigs, can be abit tricky, depending on level of floor especially, for the most part only the front 2 legs/wheels are going to be adjustable, the rears if need be will have to be chocked with wood shims . as a repairman for nearly 20years, i rarely "level" refrigs, , for the reason of who knows if the cabinets are level, or how level the floor is, i in turn make the refrig appear level and make sure its stable when the doors are opened and closed. not essential for level (shloud be close butno need to be perfect, id much rather a refrig tht looks good and doenst shake when door is closed, rathe then tryin to get it perfectly level and then seeing a 2 inch gap at top of cabint and flush against the bottom.
Apr 03, 2008 | Refrigerators
Samsung RM255LASH Side by Side Refrigerator Logo
67 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
