Question about Punch Viacad Pro Pc & Mac Sb for PC, Mac (664446891037)
Unable to install via cad pro - states admin rights needed. I have admin rights.
Unable to select destination folder
Have you checked in your program settings to see if it has a default, or chose destination folder option?
Feb 12, 2014 | Bullzip PDF Printer
Unable to access a fresh Audio codes box via http using default IP address.
What IP address are you pointing at? 10.1.10.10? 192.168.0.1? try with 10.1.10.10 and worst case scenario install wireshark on your PC and take a trace when connected directly to MP and power it on, there you will see some bootp messages (IP address 0.0.0.0) and after that you will see messages from MP announcing its IP address. If device is brand new you should login fine using Admin / Admin. Beware that some internet explorers do not allow login even with right user/password, try with a couple of them.
Aug 22, 2011 | AudioCodes MediaPack MP-114 FXS and FXO...
Recently purchased an emachine with windows 7 - but i am unable to install my hp officejet 7310 all-in-one. I have downloaded the driver from the hp site, but i still receive the error to log on as the...
first right click the setup.exe and select "run as administrator". If it does not work, create another admin user profile, then install it there using the first step.
Sep 16, 2010 | Computers & Internet
How can I bypass password in XP Pro for Dell GX280
log on through your ID
and click on Start
right click on my computer
click on Manage
one you see computer management pane
expan Local user and groups
select User
now double click on Administrator
then check mark on Account is desabled.
or just you can delete to Admin
and restart your computer.
Remember: before you disabled your Admin user get yourself admin rights.
thanks
Feb 09, 2009 | Dell Computers & Internet
Canon 9080c unable to select scan ahead unless logged in as Admin
Try in install captureperfect in Admin mode and give full rights and select the setting you want. Log off and get into user mode and try Captureperfect. This can work. If there are not too many variations in settings required, the best is to select Autocontrast option, but you may get a samll black patch on the top.
Jan 06, 2009 | Canon DR-9080C Path-Through Scanner
Launch Quickbooks pro 2005 for first time with error
This usually indicates a bad registry in windows, where the admin accounts are damaged. You can try creating a new user with admin rights. If the problem persists, you will probably need to do a system recover on the laptop, setting it back to factory specifications.
Backup any data you want to save first.
Nov 14, 2008 | Intuit QuickBooks: Pro 2005 for PC
Installa
if you knew how to edit registry in there clean that progame registry install it again
Aug 16, 2008 | Computers & Internet
Installation
press ctrl+alt+delete look for the processus then press on users otoredr the prussus that u occur then select intallwizard /istsheild somthing like that
highlight it and shut it down then run the instllation and tell me what happneds
so i can arrange a new solution
rate me!!
Wireless router
Have you tried getting into the router setting via the ip ( 192.168.1.1 ) It should ask you for a name and password. Linksys usually uses ( admin, admin ) as name and passsword. sometimes its blank for name and admin for password. Look on the bottom of the router it usually tells you there. Also, you could call there tech support, they helped me alot one time in my early days, they spent like 20 minutes helping me.
Im not familiar with mac so i dont know if this helped at all.
Feb 19, 2008 | Linksys Wireless-G WRT54G Router
Punch Viacad Pro Pc & Mac Sb for PC, Mac (664446891037) Logo
238 people viewed this question
Top Punch Computers & Internet Experts
k24674
Are you a Punch Computer and Internet Expert? Answer questions, earn points and help others
