Recovery disk full and windows explorer keeps feezing
  • yasinec24 Mar 22, 2009
    message coming my c: is full.but there is no that much data.
    c: is 40GB
    but free space 0 byte.
    i stop that restore point and cleaned all temp files
    still problem occur.can you help me
    Novelist:
    Scholar:
  • 96 Answers
Right-click on "My Computer" then select properties, then System restore.
You now have two choices, expand the % disk space to use for the system restore, or Turn off System Restore, which will wipe out all past restore points.
Do the first one, see if everything goes back to normal. if not, then run disk cleaner foundat: start, programs. accessories, systems tools. This should mkae your Operating system speed up a bit by cleaning out temp files and other clutter. Then defrag, also found in the same folder as Disk cleaner. Next, do a search of your entire hard drive for all files ending in .tmp. delete them all. Those steps combined, should speed things up considerably. Only when everything is working fine again should you turn of system restore and then turn it back on again to get everything cleaned out. This last should be a last resort only, when you are running out of Hard drive space.
Posted on Jul 09, 2008
NEED TO KNOW HOW I CAN PREVENT BACKUP FILES FROM GOING INTO MY RECOVERY(D), AND FILLING IT UP. I AM RECEIVING MESSAGE THAT I HAVE LOW DISK SPACE IN RECOVERY DISK. HOW DO I FREE UP THIS SPACE, AND HOW
Are you sure the files are going in there? Many times the manufacturers only allocate the size that they need partitioned on that drive. I have seen many cases where that drive is full from factory and people always get that message.
  1. Click Start c01508537.gif and right-click Computer .
  2. Select Properties .
  3. Click System Protection from the left side of the Window.
  4. In the section "Automatic restore points", remove the selection next to the D: drive, and then click OK . If the D: drive was not selected, close this window. Figure 3: System Protection tab with D: drive unselected
  5. Right-click Start Explore All Users .
  6. Before you can remove the backup files and folders, you need to be able to view hidden system files as follows:
    1. From the explorer window press the Alt key on the keyboard to make the menu bar appear in the window.
    2. From the file menu, click Tools , and then select Folder Options .
    3. Select the View tab.
    4. Select Show hidden files and folders , remove the selection from Hide protected operating system files and then click OK .
  7. From the Folder Options window in explorer, double-click Recovery (D:) .
  8. If a Window opens stating "You don't currently have permission to access this folder" opens. Click Continue .
  9. If you previously copied or created any files into Recovery (D:) and you want to keep them, copy them to another drive - such as the C: drive.
  10. Find and delete any files that you previously copied onto the Recovery (D:) drive.
    CAUTION:Do not delete any files that are associated to recovery! Do not delete the items RECOVERY, $RECYCLE.BIN, boot, hp, PC-Doctor, pcdr, or PRELOAD! Doing so can prevent a future system recovery from the hard drive. If you are not sure, do not delete the file.
    Press Shift + Delete to permanently remove the files.
    To delete files created from MS Backup (MS Backup files are not recovery files), find and delete the folder with the same name as the computer name in the Recovery (D:) partition. For example if the computer name is BOB-PC, the folder containing the backup files would be named BOB-PC and would be deleted.
  11. Several confirmation windows open. Click Continue , and Yes until the folder is deleted.
  12. To set Windows Folder Options back to their original setting as follows:
    1. From the explorer window press Alt to view the file menu.
    2. Click Tools , and then select Folder Options .
    3. Select do not show hidden files and folders and select Hide protected operating system files .
    4. Click OK .
  13. Close explorer. The Out of Disk Space errors should no longer appear. If you would like to use the Microsoft Backup Tool again, open it and select a different external backup device to store the backup files on.
Aug 17, 2012 | HEWLETT-PACKARD Computers & Internet
My windows wont load
I understand that the Windows is not loading on your computer. It may happen due improper shutdown of the computer or any files corrupted. Please try the steps below to resolve the issue:
1. Keep on tapping F2 key on your computer keyboard as soon as you hit the power button.
2. Then press F9 key, press "Y" to confirm and then Press "F10" and press "Y" to confirm, the computer will restart.
It should take care of the issue, however, if the issue still persists, then follow the below mentioned steps:
You can restore the computer back to factory default,to do so, follow the below steps: Turn OFF the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10" key, i.e Alt+f10, it will open the recovery console, select full factory restore and follow onscreen instruction. NOTE: This will erase all the data on the computer.
You can also create a set to Recovery disk from the recovery partition, to do so
Start Menu> All Programs> Acer erecovery management> Click Create Factory Default Disk, if you receive any error code or unable to burn the disk, please contact Acer Technical support at 1 800 816 2237 and order for an Recovery Disk.
Thanks and regards,
Jitha
Nov 17, 2011 | Acer AZ5610U9072 Allinone PC 23' Touch...
My smartbook does not want to turn on because of a error saying '' Application explorer exe. error '' what should i do?
you can recover your windows by recovery disk (if you have a recovery disk, due to specification of your notebook, it's use windows xp which has built as your original os, it means your notebook has a recovery disk) but you will lost your data in drive C (drive contains your operation system)
turn on your notebook
press f3 immediately from your keyboard
select MSI recovery manager
press OK
wait until the process of system recovery finish
Jun 05, 2011 | MSI Wind U100-016US Laptop
Hi i have a proplem in my acer aspire 5315 .When i boot it .i saw in screen boot "file messing..." id not rememmber what kind file.
It appears that the Windows is corrupted on your computer, you can restore the computer back to factory default,to do so, follow the below steps: Turn OFF the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10" key, i.e Alt+f10, it will open the recovery console, select full factory restore and follow onscreen instruction. NOTE: This will erase all the datas on the computer.
Thanks and regards,
Jitha
Feb 01, 2011 | Acer Aspire 5315 Notebook
I get this problem and can't get past it help please Unmountable_boot_volume its a problem with the recovery system a blue screen for dell inspiron 2650
I sure hope you kept a recent backup. Something has gone terribly wrong in there. If you didn't keep a recent backup, do you still have the Windows setup disk(s), or the Recovery disk? It sounds like you will need to do one of those. STRONG ADVICE_ DO NOT start to run a Recovery or Resoration disk NOR a backup and then stop it part-way done! I did that recently, and it took me 3 months to find a solution. It deletes all your partitions. Then nothing will work without much research and work. Once you start a recovery from a disk or a backup, let it finish! It may take awhile, but it's worth it. Don't panic. Just do a backup restore or a restoration disk, and any lost data, will be lost. People call using the Restoration CD a "reformat". It gives you a fresh install of Windows. Try to always keep a recent full partitions backup, it's worth it's weight in gold. Feel for you!
Dec 21, 2010 | Computers & Internet
When I turn my netbook on it starts but goes straight to black screen and nothing happens, I went to safe mode but whenever I press Entre it reboots and goes to black screen again, I have no cd-rom ... so...
It appears that the computer is infected with virus and may need full system recovery. You can restore the computer back to factory default,to do so, follow the below steps: Turn OFF the computer, now as soon as you hit the power button, keep on holding "Alt" key
the computer.
Thanks and regards,
Jitha
Nov 25, 2010 | Acer Aspire One PC Notebook
I lost my recovery disks during move now i cannt reboot system theres a problem on hdd it says no room left so now wont let me make any recovery disks yet there is nothing on hdd
Start Internet Explorer.
Click Tools.
Click Internet Options.
Click Delete Temporary Internet Files.
Close Internet Explorer.
Click Start.
Click Run.
Type CMD and press ENTER.
Type CD LOC and press the TAB key and then the ENTER key.
Type CD TEMP and press ENTER.
Type ERASE * and press ENTER.
Type Y to confirm that you want to erase everything in this "temp(orary)" folder.
Type CD \WINDOWS\TEMP and press ENTER.
Type DIR and press ENTER.
You should see something like:
20 File(s) 3,165,781 bytes
20 Dir(s) 1,443,053,568 bytes free
i.e., where 1.4 Gigabytes is enough space to hold about 2 full CD-ROMs of data.
Find a USB memory-stick that is mostly "empty", and connect it,
to create more "available" disk-space, e.g., 1 or 2 or 4 or 8GB more.
Now, try to make the recovery disks.
Nov 18, 2009 | Acer Aspire 5315 Notebook
I have a thinkpad t20 and a 570e, both with
The IBM Recovery Disk that comes with those laptops is set up for Windows 2000, not Windows XP Pro. The answer is No, you cannot use the IBM Recovery Disk for them, if you install Windows XP Pro.
However! You will have a recovery disk, because you will have the Full Installation disk for Each laptop. Windows XP Pro Full Installation Disk.
(Microsoft Users License states "One genuine copy of Windows per One computer" That means you need Two, genuine copies of Microsoft Windows XP Pro)
Sep 06, 2009 | IBM ThinkPad T20 2647 Notebook
Recovery partition full error
Please go to Start + Run and type cmd
Type chkdsk d: /F /X /R
It will dismount and check for any errors after the system restarts
follow the method to clean the disk space.
) Open Internet Explorer and click on Tools
2) Click on Internet Options
3) On the General Tab, in the middle of the screen, click on Delete Files
4) You may also want to check the box "Delete all offline content"
5) Click on OK and wait for the hourglass icon to stop after it deletes the temporary internet files
6) You can now click on Delete Cookies and click OK to delete cookies that websites have placed on your hard drive. To clear the Internet History in IE:
1) Open Internet Explorer and click on Tools
3) On the General Tab, in the middle of the screen, click on Clear History
4) Click OK
To clean up other temporary files on your computer in Windows 98 or higher:
1) Click Start, Programs (or All Programs), Accessories, System Tools, Disk Cleanup
2) Choose the correct drive usually C:\
3) Check the boxes in the list and delete the files
Dec 10, 2008 | Gateway 2520915 Keyboard
My computer is displaying a message about the recovery disk is running out of space, I have cleaned it and it is still displaying this message, what shall I do?
Sometimes manufactures make the recovery partition so small that windows sees it as low space hard drive, it is annoying, as you arn't even supposed to save data to it anyway (it is reserved for emergency recovery) your best bet is to turn off windows disk monitoring, the only trade off is that if you C: drive gets full, windows won't warn you (but you should be able to monitor it on your own anyway.
goto START then RUN and type REGEDIT.EXE and push enter
Navigate to
HKEY_CURRENT_USER\ Software\ Microsoft\ Windows\ CurrentVersion\ Policies\ Explorer
If it's not there, create a DWORD value and call it NoLowDiskSpaceChecks.
Double-click on NoLowDiskSpaceChecks, and enter the value 1, and press OK.
BE CAREFUL IN THE REGISTRY!! AS YOU CAN CORRUPT YOUR ENTIRE WINDOWS INSTALL!
DO THIS FIX AT YOUR OWN RISK!
Mar 03, 2008 | Computers & Internet
Computers & Internet Logo
1,026 people viewed this question
David Payne
David Payne
