Question about Canon EOS Rebel XSi Digital Camera
What is the reason for a "busy" reading when I
  • 747 Answers
Your internal flash is recharging from the camera batteries, this time can be reduced with fresh charged batteries. Really what is happening is that the internal flash is taking as much power as it can to charge and the whole system slows down. Not only that you may be shooting in the highest picture quality which will again slow things down a bit put the two together and it's really noticeable.
At least the camera is telling you without letting you go ahead and make another picture and further compound the problem and give you a dark picture, Smart Camera.
Posted on Jan 04, 2011
How do I reformat SD to HP photosmart 945
try the ccleaner there might be still something in it
Apr 22, 2012 | Cameras
Tip
Reasons for going into Business
Hi! There are reasons that a person think in going into business. The most common is gaining "Profit" and "Motive". Or an individual want to have a business venture because he/she knows that they are good at. They might think I am good in cooking that's why they want a business that offers food to their customer. Being successful also might their interest that's why they want to go into business. It is by their own interest why they want to be in business and for profit.
on Sep 06, 2011 | Microwave Ovens
My name is Madhu. I use the camera Canon EOS 400D / Digital Rebel XTi. When the inbuilt FLASH is on then a message pop up as "busy now", when i tried to click the camera to take a photo then...
Welcome to Fixya
Err 99 could mean several different things, such as... Memory Card, Lens or Lens contacts....
Here's what you can try:
Remove the memory card an enable "shooting with out memory card" and see if you still get the error. If it works your memory card is bad. Try another lens if you can. Clean the lens contacts with a pencil eraser (be careful not to get eraser dust in the camera body or in the lens). Worst case scenario is, Err 99 could be related to the shutter failing which would mean a trip to Canon.
Thank you
Apr 04, 2011 | Canon Rebel XTi / EOS 400D (body only)...
Well, my flash doesn't always pop up. It has been working on and off and now will not shoot. It says "ERR 05" - keeps blinking that. Can you help?
I have the Canon Rebel t1i (500d) and I had the same problem (built in flash not working). I tried a number of remedies I found on forums etc but none worked. I then tried this with the camera pointing away from me as if taking a picture. In the external flash housing is a metal sprung plate which surrounds the five circular pins (one big, four small at the rear). If you get a small straight headed screwdriver and lift the front of this plate and at the same time pull it back towards you it will come out altogether. (In picture 2 I show this plate removed and sitting in front of the mount only so you can see it removed, it was brought out backwards so towards me from the camera).
I then removed the four small screws being careful not to drop them and took off the mount for the external flash and then tried the flash it opened straight away. I then cleaned all the area of the mount and the two plates and replaced them all ensuring I fitted them exactly as before. I then checked the camera again and presto working fine. I hope this helps everyone with the problem.
Dec 25, 2010 | Canon Rebel XT / EOS 350D Digital Camera
What can i do if my fridge is not cooling?
Hello and Welcome to FixYa!
Refrigerator mal function can be due to several reasons...To trouble shoot poor/no cooling problem, you need to carefully check all the below quoted possibilities one by one:
  • Start Relay (Compressor Clicking won't Start in case of faulty).
  • Bad/dirty Condenser.
  • Defrost timer Settings.
  • Cold Control Settings.
  • Defrost (Ice built up on the evaporator coils that chokes the air flow to the freezer/refrigeraot compartment).
  • Evaporator Fan.
  • Main Control Board mal function.
You need to cross check all above quoted possibilities one by one to locate/trouble shoot the problem.
Best of Luck,
Your token of appreciation in form rating will be highly obliged.
Concerned.
Sep 18, 2010 | Avanti Refrigerators
My canon eos 40D says busy when trying to upload...
i often find with SLRs (and other proprietary cameras) its far safer to use a card reader.
May 06, 2009 | Canon EOS 40D Digital Camera
Error 5 ! Canon Rebel Xti w/ 28-135mm It was working fine! had it for 10 day's and after about 560 images taken ( 4 gig flash card ) The message read : "The built in flash auto pop up was...
  • Try the scotch tape or masking tape technique: get around two to three inches long sticky tape, stick about an inch above the flash housing, turn on the camera, hold the remaining tape upward , shoot the camera and pull the tape upward with a force enough to pull-up the flash bulb housing.
Jan 04, 2008 | Cameras
"busy" Error
check your firmware version and update if necessary. Usually you get the "busy" message when your camera is writing to the card and it's possible the card isn't quite right - a format should fix it. Alternatately you might try a different CF card to see if the problem goes away. Good luck!
Sep 14, 2005 | Canon EOS-20D Digital Camera
Failure of flash sync in F828?
I experience similar failure sometimes. I un-mount the flash (or adapter) from the hot shoe and put it back, and am back in business. The reason is, at least in my case. loose contact, resulting from movement of the flash/adapter in the shoe.
Sep 12, 2005 | Sony Cyber-Shot DSC-F828 Digital Camera
Canon EOS Rebel XSi Digital Camera Logo
195 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
