Question about GE Spacemaker Washer and Dryer Electric Laundry Center
I am looking for a gas to propane conversion kit for a dryer mod no[ DPSB613GDOWW ] serial no is GG730156A THANKS
    Top Expert:
  • GE Master
  • 9,472 Answers
Posted on Jan 04, 2011
How do you convert to propane a kenmore elite model # 79671622310
You have to get the conversion kit. Mostly the burner gas nozzels has to be changed. Propane has a higher BTU value than natural gas. So the burner nozzle has to be smaller with propane.
You have to have the right nozzle kit for your dryer. Normally the propane nozzle kit comes with the new dryer. It is attached in a plastic seethrough bag and attached somewhere in the back of dryer.
Also you have to adjust the air opening in the burner for propane. Propane need more air than natural gas to burn properly. If you buy the conversion kit or find the conversion kit in the back of your unit, it will clearly give instructions how to do it.
Sep 26, 2014 | Dryers
Propane conversion
You can call your local propane supplier to do it for you or buy the conversion kit at a local appliance parts store and do it yourself. You'll need the make, model and serial # to order the kit. If after you buy the kit, you decide you can't figure out how to do it yourself, then you can still call your propane co. to do it. Just keep in mind today's dryers are not as service friendly as they used to be and if it's a new dryer, you might be better off hiring someone to do it than risk screwing it up and voiding the warranty. Let us know if you need further advice on this. Douglas
Oct 05, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Need to change from LP to propane. How do I get access
Gas to Propane requires a Propane Certified technician. These technicians are provided by the company that provides Propane that they will be using.
You may need to get a Propane conversion kit, for technician from the Propane company to install.
You can certainly double check on this...Hope this helps.
May 01, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
I need to convert my gas dryer to propane. I
Here are the basics of the conversion process:
Make sure the gas is turned off and the dryer2.gif is unplugged from the power source. Extreme care needs to be taken when installing the kit and making the conversion, since there is a very obvious safety issue if the kit is not installed properly. The kit will consist of a brass fitting with a nylon pin sticking out of it. This is called the blocking pin. At the gas valve and regulator you will remove the plug on the gas valve (called a leak limiter) and replace it with the fitting containing the blocking pin that comes in the conversion kit. That will change the gas regulator pressure setting from gas to propane.
Next, you will have to change the orifice metering plug in the burner. This does just what the name implies... it meters the amount of gas that enters the combustion area. The fittings that come with the conversion kit (blocking pin and orifice metering plug) are made of brass, which is a soft metal, and since they are being connected to a much harder steel, make sure that the fittings are not overtightened. I generally use some pipe dope on the threads. Once the conversion is completed, you want to check for leaks. I generally mix up some soapy water and spray it around the fittings to check for leaks. Look for bubbling which is a sign that there is a leak. The last thing to do is to reassemble the dryer. Start it up and make sure that it is operating correctly and that there are no obvious smells that would indicate a leak. If so, shut down immediately.
These are the basic steps for a gas/LP conversion. If there is any doubt that you feel comfortable making the conversion, then I recommend that you contact an appliance technician for assistance. Hope this helped and best wishes.
Oct 02, 2009 | LG DLG5988 Gas Dryer
How to convert my new kenmore 600 natural gas dryer to propane
Hi!
You will need a conversion kit for converting your dryer from natural gas to Propane. Please see this link for converting your dryer from natural gas to Propane---
Kenmore 600 natural gas dryer to propane
Please ask for further clarifications.
Please rate this solution as Fixya if found useful.
Thanks
Rylee
Mar 13, 2009 | Kenmore Dryers
JDS8130 Cooktop Conversion Kit : Propane to Natural Gas Conversio
here is a site that has gas conversion kits
http://en.allexperts.com/q/Major-Appliances-3603/Jenn-Air-gas-range.htm
Jan 31, 2009 | Jenn-Air 30 in.JGD8430ADS Gas Cooktop
Older Frigidare Elite Dryer conversion
You'll have to contact Frigidaire to see if a conversion kit is available. Normally, it's just an orifice replaced on the gas valve.
Feb 18, 2008 | Frigidaire GLGR341AS Gas Dryer
GE Spacemaker Washer and Dryer Electric Laundry Center Logo
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
