Question about RCA RTD317 Theater System
How can I make the speaker wire longer??? - RCA RTD317 Theater System
    Scholar:
  • 85 Answers
To extend speaker wire you need to splice it. The proper way to do this is with bu tt connectors. You will also need a crimper, but a cheap set from the hardware store will do the job just fine. Make sure all components are off and unplugged when doing this. It is also a good idea to splice 1 conductor at a time so that you don't accidently cross the wires and end up shorting your system. Once your wires are spliced through, it is also a good idea to re-insulate your connections with electrical tape.
Posted on Jan 04, 2011
What wires do I need to connect my denon avr-1803 to the speakers
All you need is some speaker wire long enough to get to each of the speakers your running. Use larger gauge if your running big speakers hard and/or over longer distances. Otherwise a medium gauge (16) will do fine.
You'll also need all the cables required to connect external components.
Feb 25, 2016 | Denon Audio Players & Recorders
Original speaker wires lost - can they be replaced with commercial speaker wire, and if so will longer wire lengths work just as well?
I checked my Sharp system and it uses ordinary wire for the speakers. The difference in length won't matter. $20 for replacement wire? They must be kidding.
Nov 26, 2013 | Sharp XL-HP500 CD Shelf System
When I push ON button I see in display " protect" mode...
It could be a short in your speaker wire or the crossover in your speakers.
1) Turn off your unit and disconnect your speaker wires at the amp, if the protect is no longer displayed when the unit is turned back on, check the connections on the speakers. If you do not visually see a short on the speaker wire connection, turn off the unit and disconnect the wires at the speaker and isolate them so they do not touch then connect the speaker wires at the amp. Turn on the amp and see if the protect is on. If it is on, the wire has a short somewhere in the line. If the protect is off then suspect the speaker has a short in the voice coil or crossover.
2) If the protect is still on after you disconnect the speaker wires at the amp, it could be the power IC in the amp is shorted and needs to be replaced.
Feb 17, 2011 | Sony STR-DE685 Receiver
RCA jack in back of the speaker is no longer connected. I can NOT get the cover off the speaker.
cut connectors from board & join cable of speaker & output wires
raj@npconline.in
Jan 26, 2011 | Klipsch ProMedia GMX D51 5 Speakers
I have **protect** in my kardon harman avr85?please give me solution
Jan 10, 2011 | Harman Kardon Audio Players & Recorders
Rear Speaker delay
It will not be the length of the wires, as the signal travels at close to the speed of light!
If the connections to the speakers are bare wires the cause is probably that you have wired the speakers with opposing polarity. Check the wiring and ensure that positive (red) is wired to positive on the speakers.
The speaker cable should be marked in some way to indicate which core is which. It doesn't matter which core you use provided that you wire red to red and black to black, or whatever other colours your output and input have.
Apr 01, 2010 | Dell 5650 Computer Speakers
NEED LONGER SPEAKER WIRES- IS IT POSSIBLE TO ORDER
Yes you can goto www.Bogue-Engineering.com
and they will make custom length cables with the special connectors for you.
Jan 03, 2010 | Sony DAV-DX255 System
Need longer ribbon speaker wire for Acoustimass 16
I have the same question. I just called Bose at 1-877-210-3782 (prompt 6) and they have two solutions:
1. 20 foot Input extension - $25
2. Input adaptor - $12 (you can run your own speaker cable to the input adaptor)
Apr 10, 2009 | Bose Acoustimass 16 System
Kenwood vr 615 speaker sound cuts out
it means there is some shorting in the speakers.. check for the shorting
Dec 14, 2008 | Audio Players & Recorders
RCA RTD317 Theater System Logo
102 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
