Question about Kenmore Humidifiers
Kenmore Humidifier 14114 - the fan suddenly stopped running. Changed fliter and water, unplugged the unit, changed dial to highest humidity level - the unit will not run.
  • leggett200 Jan 04, 2011
    I guess I didn't realize this was a website for professional technicians. I have no idea where the fuse or wires are - nothing is visible. Only plastic. I don't know what a multimeter is. The only model number visible on the unit - and it's not very visible - is 14114.
    Genius:
  • 1,456 Answers
Hello
You should replace the TCO (thermal cut off) in the motor this cost about 2 dollars,this should fix the problem and your humidifier should work perfectly again
Also oil your fan motor and this should free the motor right up.some bicycle gear spray should do the trick,inadequate lubrication overheats the fan.
Posted on Jan 04, 2011
  • 4,323 Answers
Hi
Please turn off the power to the unit and unplug it. Now check the fuse inside the unit, make sure its fine and not burnt If fuse seems OK then inspect the connections to the fan and make sure the wires are not cut. Also, inspect the control for any burnt components, use a multimeter to confirm. Hope this helps... Please post back with complete model# if you need more information.
Daniel
  • Daniel Scott
    Daniel Scott Jan 04, 2011
    If you don't know how to use a multimeter then leave the unit unplugged for around 30 minutes. If the issue returns then contact a professional as it is dangerous to play with electronics if you are not comfortable on how to do the repair.
Am getting just a little bit of water coming through the clear hose at the bottom of my unit. Maybe 4 oz every 5 minutes. According to what I have read here it should be a quart about every 5 minutes. My...
Humidifier may be undersized or a restriction at the inlet side of the solinoiud valve. Turn water off to humidifier and remove inlet side of water line at the solinoid valve. Carefully remove the inline filter at the inlet side of the valve and wash under some warm water making sure it is clean.
Jan 31, 2011 | Aprilaire 700 Humidifier
Hello! Humidifier quit working. Turned dial to test and nothing. Usually I hear the humidifier working if I increase the dial to a higher level but nothing. Could it be the solonoid is gone? Thanks!
if you hear a "click" at the unit when you increase the demand for humidity it could be a clogged solenoid valve. If you heart nothing this could indicate a power problem. turn the humidistat to the highest setting and verify the proper voltage is available at the solenoid, if so, the solenoid needs to be replace. hope this helps.
Dan
Nov 25, 2010 | Aprilaire 550 Humidifier
Not working
HI, Troubleshooting an Aprilaire Humidifier
Aprilaire, a manufacturer of indoor air quality products including thermostats, air cleaners and dehumidifiers, also offers a line of whole house humidifiers. Installed in your existing heating and cooling system, humidity is produced by a supplied water source that flows over a water panel before being distributed throughout your air through the heating and cooling system. Issues you may need to troubleshoot with your Aprilaire humidifier include error messages and the unit producing too little or too much humidity.
Things You'll Need:
Replacement water panel
Turn down the control dial by one setting if condensation appears on your windows or walls.
Turn up the control dial by one setting if there is a lack of humidity, often indicated by dry skin or peeling wallpaper or paint.
Turn the control dial to "Test/Reset" if the humidifier does not run. Verify the heating and air conditioning unit blower is operating. If the heating and air conditioning unit is not operating or you are unable to resolve the issue contact a heating contractor.
Contact a heating contractor if you turn the control dial to "Off" and the humidifier continues to run.
Contact your Aprilaire dealer (see Resources) if you notice an error code on the display and the "Call Dealer for Service" light flashes.
Turn the control dial to "Off" and turn off the water supply if the yellow "Change Water Panel" light flashes. Lift the front panel off of the humidifier. Slide out the water panel. Insert a new water panel. Replace the front cover. Turn the control dial to "Test/Reset" until the "Humidifier On" light flashes. If you feel uncomfortable changing the water panel, contact a heating contractor.
Tips & Warnings
Purchase replacement water panels through your Aprilaire dealer or a heating contractor.
You can get parts from the link below:
arnoldservice.com/humidifier_parts.htm
Hope it helps.
Thanks for using fixya....
Nov 17, 2010 | Aprilaire 700 Humidifier
760 aprilaire humidifier does not let water to the filter. I have cleaned and checked the lines in and out of solenoid.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Your Aprilaire Humidifier is designed to operate in conjunction with your furnace blower motor. Most installers wire a humidifier to operate when the furnace is calling for heat. To determine if your Aprilaire Humidifier is maintaining proper humidity, turn up the heat temperature 5 degrees above the current room temperature on your thermostat and set your humidifier control to call for humidity. The humidifier control is located on the cold air return duct. To set your humidifier control to call for humidity, turn the control dial to the off position and slowly rotate the dial until you hear a “click” on the control. You should also hear a click at the solenoid valve located on your Aprilaire unit. The humidifier control will have a click point at the current relative humidity level in your home. If the current relative humidity is 45% or the outdoor temperature is above 60F, the control will only operate the humidifier in the test mode.
  1. No click at the solenoid valve indicates an electrical problem. Contact your heating and air conditioning dealer to further check the electrical components of your Aprilaire Humidifier.
  1. The click sound at the solenoid valve indicates there is electricity to the solenoid valve. By turning the dial of your humidifier control to a setting above the “click point” you should see water coming out of the drain line within a few minutes which would indicate your humidifier is working.
  1. If the solenoid valve makes a click sound and there is no water draining from the unit, this would indicate the flow of water is being obstructed.
1. To determine if water flow is being obstructed, turn the dial of your humidifier control to the off position. The first location you would want to check for an obstruction would be at the saddle valve located on the water line supplying water to the humidifier. When checking the saddle valve, you want to make sure it is completely open. This can be done by turning the valve all the way to the left. If anything is clogged, it can be dislodged by turning the saddle valve all the way to the right and back to the left. Once this is done, turn the humidifier control dial above the click point and you should see water coming out the drain line.
If water is still not coming out of the drain, check the orifice and in-line strainer to make sure they are not clogged. The orifice is located in the tube on the discharge side of the solenoid valve and the in-line strainer is located on the inlet side of the solenoid valve. You may clear the orifice by inserting a needle through the small opening. Clean the strainer by running it under warm water to dislodge deposits or replace. After clearing and re-installing the orifice and strainer (be sure to double wrench all water connections), turn the humidifier control dial above the click point and you should see water coming out the drain line.
Mar 10, 2010 | Aprilaire Humidifiers
Kenmore Humidifier not operating?
Turn the unit off, lift the fan assembly off the base, and push the connector together that goes to the float switch on the bottom of the fan motor. If you hold the switch in with your finger (careful not to get into the fan blades) and turn the unit on, the F indication should go away. F (as in Fill), apparently, means the base has no water. The plastic tube that sticks up out of the base floats on the water and pushes the switch. Put it back together, it should work!
Dec 08, 2009 | Kenmore Humidifiers
Aprilaire 600 humidity level too low
The max the aprilaire can put out is 45% Rh. Your humidifier may wired up to run only when the heat is on. In some cases this is not enough time to maintain your humidity level your seeking. To correct this, the hum. has to hooked up the hot side of the water supply. And the humidifier has to be hooked up when the fan runs and leave the fan run constantly
Jan 12, 2009 | Aprilaire 600 Humidifier
Aprilaire 600: water only runs in "Emergency" Heat mode
When your unit is on normal the outside unit works and the inside only the fan runs. your heat pump does not remove any humidity when it operates so the installation cotractor did not wire it to operate then. you can change the wiring on the humidifier to operate all the time by wiring it to the fan (g) terminal then it should work just turn it all the way to the lowest humidity when you are in cooling mode.
Jan 07, 2009 | Aprilaire 600 Humidifier
The humidifer on the Sunpentown SH-1500 heater
what country are you in... winter time is low humidity to begin with.
Robert
Jan 06, 2009 | Sunpentown 1500W Heater Fan Humidifier...
Fan is running but humidity is not changing
Q: My unit has been running for several hours. I hear the fan spinning, but I do not notice the water level in the tank decreasing.
A:
First, check the filter to ensure it is wet. If the pad appears dry, remove it from the Base and gently rinse under cool water. Reposition wet filter in the Base. You may also want to note the current moisture level in your home. If the humidity level is over 60% the unit will not put out much moisture
as your air is already saturated.
UV bulb and filter are user replacement items
see manual from my other post
Owners manual LINK
Comment by Soulvisitor, posted on Jan 20, 2008 You should notice moisture on the widows in the room after unit has run for awile, this unit carries a 3 year warranty. More info coming...
Comment by Soulvisitor, posted on Jan 20, 2008 see this
4b54ac1.jpg Comment by Soulvisitor, posted on Jan 20, 2008 If water level in tank is dropping and fan runs then I'd say it is working.
OK?
Comment by Soulvisitor, posted on Jan 20, 2008 Q: I hear the fan turning, but I don’t see any mist. Is my humidifier operating properly?
A:
Dry air is pulled through the system and a fan disperses invisible, moisture balanced air. There is no
“mist” emitted. When operating normally you will feel only cool air coming from the unit. Monitor the
water level in your Tank/ Base. If you notice a decrease in the Water Tank over 24 hours then the unit
is operating normally.
Dec 02, 2007 | Honeywell HCM-300T Humidifier
Humidifiers Logo
206 people viewed this question
Top Kenmore Humidifiers Experts
Mack Baxter
ftykjg
ftykjg
julian hayes
julian hayes
Level 1 Expert
Are you a Kenmore Humidifier Expert? Answer questions, earn points and help others
