Question about Garden
My shop fox w1666 dust collector has a broken electrical switch x1666009 is broken. Where can I get a replacement?
4 Suggested Answers
sleepy_user
  • 140 Answers
SOURCE: on off switch
http://www.westerntool.com/product.htm?pid=455686
Posted on Jan 21, 2009
  • 468 Answers
SOURCE: Switch on dust collector doesn't seem to be working.
Maybe you just need to clean the switch.
Posted on Apr 08, 2013
chilli1327
  • 174 Answers
SOURCE: Looking for dust collector Hitachi Vacuum Cleaner CV-BL16
Go to their website, look for your model and see if they have replacement parts.
Posted on Feb 18, 2015
My Genesis 10" sliding compound miter saw doesn't have any power or sould i say it won't start ????Plugged it in and squeeze the trigger and theres nothing .
broken powercable , carbon brush (autostop or to short brushes) or the switch itself or one of the 4 coil (2 for one coil) contacts on the electric field can be broken or a collector on the armature is ruined .
first control only turn by hand the blade a littlebit to check the last option before you connect the wallconnector so it can start because if brushes stands on a defect collector it wont start , if it willm start and sparks replace the armature and maybe also the electricfield and also the drivinggear on the armature in some cases. if only to short brushes replace brushes.
Jan 26, 2017 | Saws
My sa380 15 inch auto planer dumps the shavings out the bottom even with the 4inch dust collector running this just started Is there a ajustment Ican make to correct this problem
Although the way you worded the questions suggests a wood shop problem, it is listed under vacuum cleaners.
I will speak to the planer being a wood shop machine.
I'd start by checking the dust collector for suction.
If it draws strongly, then perhaps you need to design a "chute" to cause the chips to go to the collector.
Perhaps a "rake" would be in order to move the chips neared the collector.
A rake nothing more than a broomstick with a flat board fastened to the end.
God bless your efforts.
Sep 08, 2016 | Vacuums
How to correct a saw dust problem on a kobalt 10 .dust does not go into chot a 2 shop vac hel
The hole behind the saw blade can become blocked solid with sawdust ( especially if the timber is green or wet). clean out the vacuum hose back to the collector.
Jun 19, 2015 | Shop Vac Vacuums
My dyson ball has no suction ... i turn it on and sounds normal for a few seconds then it sounds like it clogs then no suction but i checked the tubes theres nothing there...
Take off the dust collector , put the machine somehwere out in the open air and switch it on if the motor runs up to speed then the probelm is inside the dust collector and it is probably a blocked hepa filter
If the motor does not run clean with the dust collector removed then you need to remove the base plate and check for blockages there
Jan 25, 2010 | Dyson Ball HEPA Upright Bagless Vacuum -...
Hi! I have a delta dust collector model 50-850 and electric motor has like this little starter or i dont know what you call it, that started to throw smoke out of it, i had used it since but i need to find...
Look for the part here. From your description of the problem it might be item 21 (switch box) or item 26 (capacitor). If it is the switch box there may be additional part numbers to be ordered.
Dec 03, 2009 | Delta 50 - 850A Dust Collector with 2...
Dust collector
dust collectors usually work off the motor via a fan. Either the fan is broken or the bag is blocked up.If the bag is too dirty inside you don't get any airflow through the bag which can stop it collecting. A good wash should do the trick
Aug 29, 2008 | Porter Cable 3" x 21" Electronic Variable...
Garden Logo
78 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
