Question about Canon PowerShot SD880 IS Digital Camera
My camera says no memory card but it has one - Canon PowerShot SD880 IS Digital Camera
  • 747 Answers
Okay a few possible problems first the card might be new and need formatting or the card has been formatted in another camera or computer and needs formatted in the camera it is being used in. Or the lock has been placed on the card here is a diagram to show the proper placement of the lock switch.
Another thing is your camera may be set on internal memory BUT, generally that switches over once a memory card is installed.
Posted on Jan 04, 2011
Who can repair a Gateway DC-T50
Refer to the manual page below - note the last 2 items
If you take the camera and the card to a sales outlet the assistants are usually helpful
Inserting an SD Memory Card(Optional)
All images and video clips taken by the camera can be stored in an SD (Secure
Digital) Memory Card. Even if the camera's power is OFF, the images saved in the
SD Memory Card are not erased. An SD Memory Card can be repeatedly read and
written. You may also expand the memory capacity up to 512MB so that you can
store additional images and video clips.
1. Make sure the camera is off.
2. Slide the battery/SD Memory Card cover in the direction of the [OPEN] arrow.
3. Insert an SD Memory Card :
The front side of the memory card (printed
arrow) should face towards the front side
of the camera.
If the card cannot be inserted, check the
orientation.
4. Close the battery/SD Memory Card cover.
To remove the SD Memory Card, make sure
the camera is off. Open the battery/SD Memory Card card cover. Press
lightly on the edge of the memory card and it will eject.
Note:
If the camera is powered-on without the card, the "NO CARD" message appears on
the LCD monitor.
To prevent valuable data from being accidentally
erased from an SD Memory Card you can slide the
write-protected tab (on the side of the SD Memory
Card) to "LOCK".
To save, edit or erase data on an SD Memory Card,
you must unlock the card.
MultiMedia Card (MMC) can not be used.
You need to format an SD Memory Card before using it in this camera
Feb 19, 2015 | Gateway DC-T50 Digital Camera
Camera says out of memory won't let me take pictures. i cleared all the pictures out and still cant take pictures. What do you think the problem is?
I'm assuming you are trying to use an SD card in your camera and not the internal memory. I suggest you format the memory card if you are sure there is nothing on the card. Formatting the memory card deletes everything on the card and sets it up with a file system that your camera recognizes. Follow these steps to format your memory card using your camera. 1. Turn camera off 2. Insert memory card 3. Turn camera on 4. When the memory card is inserted in the camera, the [Format card] option appears in the setup menu 5. Choose Format to format the entire card. Don't choose Quick Format 6. Wait until your card is formatted
After formatting your memory card, try turning your camera off and on and you should now be able to take pictures to your memory card.
P.S. If you remove your memory card you can choose Format Memory from the setup menu to format the camera's built-in internal memory
Sep 01, 2011 | Nikon COOLPIX L5 Digital Camera
I am using the camera for 2 monthes and now its says memory card error. i didnt changed the memory card SDHC what sould i do
Welcome to Fixya. Getting a card error means that:
* memory card is not yet formatted for camera use
* memory card requires cleaning
* using a incompatible memory card
* camera malfunction
Here are some troubleshooting steps that you can do it by yourself. However if the error message still persist, you should contact your Canon service center.
Memory Card not formatted
You have to format the memory card. Some memory card can't be formatted using a PC's, or formatted by another digital camera. I suggest that you have to format the memory card using the camera itself.
Memory Card requires cleaning
Use a dry and soft cloth in cleaning the memory card and the memory acrd slot.
Using a clean pencil eraser can also be useful in cleaning the memory card but you have to be careful, slightly rub the eraser on the memory card.
Incompatible memory card
Please use a compatible memory card
Camera malfunction
In this case you have to contact you service center. It will be a big help if you can check if your camera is still under warranty to get a free service.
Please let me know if you have any questions and if this solution was helpful.
Thank you for using FixYa.
Apr 20, 2011 | Canon PowerShot SX210 IS Digital Camera
I keep getting a card error and I have tried 9 dif cards including a new one and still the same thing.
Welcome to FixYa.
All you need to do is:
Camera malfunction
Apr 11, 2011 | Cameras
I just bought a new memory card-4 gb SD-K046. It says that the memory card is full but it is not. I have only used this memory card to scan pictures. I uploaded these pictures onto my camera and deleted...
The following information lists the type and maximum storage capacity of the memory card that each type of camera accepts.
EASYSHARE CX-, DX-, LS-Series Cameras accept:
DX3500, DX3600, DX3900: CF memory cards up to 1 GB
LS755: xD memory cards only
All other CX, DX, LS: SD memory cards up to 1 GB
EASYSHARE C-Series Cameras accept:
C300, C310, C315, C330, CD33, CW330, C530, CD40, CD50: SD memory cards up to 1 GB
C340, C360, C433, C503, C533, C603, C633, C643, C663, C703, C743, C875: SD memory cards up to 2 GB
CD43: xD memory cards only
All other C-Series Cameras: SDHC and SDHC UHS-1 memory cards up to 32 GB
EASYSHARE M-Series Cameras accept:
M590, M583, M577 TOUCH, M5370 TOUCH: MicroSD and MicroSDHC memory cards up to 32 GB
All other M-Series Cameras: SD, SDHC, SDHC UHS-1 memory cards up to 32 GB
EASYSHARE P-Series Cameras accept:
P850, P880: SD memory cards up to 2 GB
P712: SD or SDHC memory cards up to 4 GB
EASYSHARE SLICE Digital Camera accepts:
MicroSD and MicroSDHC memory cards up to 32 GB.
EASYSHARE V-Series Cameras accept:
V1233, V1253, V1073, V1273: SDHC, SDHC UHS-1 memory cards up to 32 GB
All other V-Series Cameras: SD memory cards up to 2 GB
EASYSHARE Z-Series Cameras accept:
Z610, Z650, Z700, Z710, Z730, Z740, Z760, Z7590: SD memory cards up to 2 GB
All other Z-Series Cameras, including MAX: SDHC and SDHC UHS-1 memory cards up to 32 GB
FUNSAVER FD-Series Cameras accept:
SD and SDHC memory cards up to 32 GB
EASYSHARE ONE Camera accepts:
SD and SDHC memory cards up to 1 GB
Notes:
Most KODAK Digital Cameras are compatible with SD, SD/MMC, and/or SDHC memory cards.
Most current KODAK Digital Cameras are compatible with SDHC UHS-1 memory cards.
All KODAK Digital Cameras that are compatible with SDHC and SDHC UHS-1 memory cards use cards with Speed Class up to Class 10.
MicroSD and MicroSDHC cards with SD adapters can also be used in cameras that use SD or SDHC cards if the storage capacity criteria above is followed.
KODAK Digital Cameras are not compatible with SDXC memory cards.
reference: http://www.kodak.com/global/mul/service/index.html?reqURL=http://support.en.kodak.com/app/home/src/gosupport
http://support.en.kodak.com/app/answers/list/p/2/selected/true
Phone Number for Kodak is:
800-235-6325
or try get human below for more info on support:
http://gethuman.com/phone-number/Kodak/
Jun 11, 2010 | Computers & Internet
Took 5 pictures and camera said memory full. shouldnt it take more pictures than that?
Generally there ara two memories in a camera. First one is internal memory but some camera does not have internal memory. Second one is memory card. There are a couple of memory card models are used in cameras. These days SD/SDHC cards getting very famous in the market. According to your settings generally cameras use firstly its internal memory and automatically passes to the memory card. But if there is no memory card in camera then it gives a message that its memory full. You should control if there is a memory card in your camera.
Jun 05, 2010 | Cameras
My Kodak DX4900 lense will not retract when I turn the camera off. If I hit it, then it retracts. It has no problem coming out when I turn it on, but won't retract when I turn it off unless I hit it....
This is a list of the error codes, obviously some aren't of much help but ...
E1 The memory card is not compatible with the DC50 Zoom Camera. Use a compatible card. E10 Take the camera to your dealer for service. E11 Take the camera to your dealer for service. E12 Take the camera to your dealer for service. E13 Take the camera to your dealer for service. E14 Take the camera to your dealer for service. E15 Take the camera to your dealer for service. E16 Take the camera to your dealer for service. E17 Take the camera to your dealer for service. E20 Reseat the memory card.
or
Replace the memory card with a known good card.
or
Take the camera to your dealer for service. E21 Confirm that the memory card is compatible with the camera.
or
or
or
Take the camera to your dealer for service. E22 Reseat the memory card.
or
or
Take the camera to your dealer for service. E23 Confirm that the memory card is compatible with the camera.
or
Take the camera to your dealer for service. E24 Confirm that the memory card is compatible with the camera.
or
or
Take the camera to your dealer for service. E25 Confirm that the memory card is compatible with the camera.
or
or
Oct 05, 2009 | Kodak EasyShare DX4900 Zoom Digital Camera
My camera will not read my memory card anymore. It is only using the memory from the camera. How can I get it to read the memory card
Confirm first whether the memory card is still good or bad by using a card reader, put the camera memory card into the card reader then connect it to your system, see whether the system will read your card, if the system doesn't read it, it simply implies that memory card is bad and you need to replace it with a genuine memory card, but if it works it implies that the card slot on the camera is bad. so, your either need to service your camera or you replace the memory card. Thanks
Sep 24, 2009 | HP Photosmart M417 Digital Camera
Transfer of photos on camera without memory card to memory card
take out the memory card and plug the camera to your computer and it should show that way and save them. hope that helps..
Apr 05, 2009 | Samsung Digimax A7 Digital Camera
Canon power shot SD200
You can take out the memory card from camera and then download a memory card recovery software to recover photos from memory card, you can refer to this tutorial that helped me before
http://www.asoftech.com/articles/how-to-recover-lost-photos-from-memory-card.html
If needed, you may do a quick format of the memory card and then use asoftech data recovery to recover your files.
Dec 30, 2007 | Canon PowerShot SD200 / IXUS 30 Digital...
Canon PowerShot SD880 IS Digital Camera Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
