Question about Kenmore Refrigerators
Leaking, Icing up in Refrigerator - Kenmore Refrigerators
  • Kenmore Master
  • 43,501 Answers
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Jan 04, 2011
How do I keep my RF266AEPN refrigerator with twin cooling, from icing up on the right side. This is a problem that has frequently happened in the summertime , but now, it is happening in the fall. Thi
Did you check the door gasket see if it is gunked up or air is leaking on that side? Have you felt around the door see if cold air escape? If air is escape means you will get icing or frost.
Nov 28, 2014 | Samsung Refrigerators
JCD2389GT
WHAT IS WRONG WITH YOUR REFRIGERATOR?
small_4_1.jpg For a detailed Refrigerator illustration, click below.
redarrow.gif Side by Side
redarrow.gif Freezer on Top
redarrow.gif Freezer on Bottom
redarrow.gif Under counter
Warning!To avoid personal injury or even death, always disconnect yourappliance from its power source--that is, unplug it or break theconnection at the circuit breaker or fuse box--before you do anytroubleshooting or repair work on your appliance. Also, because somecomponents may have sharp edges, use caution while working on yourappliance.
It's stopped completely
It's not cool
Cooling is poor
It's noisy
It leaks
The freezer compartment is icing up
The food in the refrigerator freezes
There's water dripping inside the refrigerator
The refrigerator never cycles off
The ice maker has a problem
There's an ice- or water-dispensing problem
Aug 12, 2008 | Jenn-Air JCD2389G Side by Side...
I own a whirlpool refrigerator model G15FVAXB 01. The front of the freezer keeps icing up regardless of the temperature setting. What can I do?
That model number comes up as a deep freezer. If it is icing up near the door only it is a gasket leaking air into the freezer.
Nov 05, 2012 | Whirlpool Refrigerators
Frig is icing up and leaking.
heatman101
May 08, 2011 | Refrigerators
Major ice crystals in the freezer section
If the icing is on the back wall in the freezer, the main reason for ice to form will be, if the defrost system is not working. There are 3 main parts to the defrost system:
  1. Timer or Board
  2. Heating element
  3. Bi-metal (sensor)
If any of these parts fail, it won't defrost and icing will occur.
Another reason will be if the evaporator fan motor quits. It will have the same affect as a no defrost condition.
If the icing is everywhere, side walls also, this is usually caused by moisture. This is from air leaking into the cabinet. It could be from the door not closing good, gaps in the door gasket or it could be leaking around the cabinet flange. For gaps in the door seal you can use a hair dryer to straighten it, just be careful not to get the gasket too hot. If the cabinet flange is leaking, some RTV will seal it.
Feb 09, 2011 | Samsung RB2155 Bottom Freezer Refrigerator
Sub zero 561, evaporator is icing. 1st tech came in and after checking gas pressure told us that evaporator is leaking. we called in secong tech, he filled up gas and it started cooling fine but couple...
It may be leaking but I think more likely is that you have a problem with the defrost system and it is not defrosting properly... that can give the same symptoms as a low charge or leak condition...
How to Defrost Refrigerator Defrost Timer Problem
heatman101
Nov 23, 2010 | Sub-Zero 561 / F
My sub-zero refrigorator is icing up on the first
Hello
There could be some other reasons for the ice.
1 bad or cracked door seal,have a look at the door seals.
2 Defrost timer may need to be set longer.
3 T sat set to low or not working properly.
Unit may be low on freon also,causing a lower pressure which would cause a lower tempreture,this occurs with a small leak or a pin hole leak.Once enough freon leaks out it will warm up and no longer work.
You can have a leak check done by a service person.
May 13, 2010 | Sub-Zero 661/F Side by Side Refrigerator
Maytag freezer icing up
If is just one spot in the whole back wall like snow ball (small) ,the unit is leaking refrigerant and the leak has to be fixed and only after that recharged.But if the back inside the freezer gets all ice up and won't defrost by itself the problem is with the defrost system ,timer ,heaters or defrost terminator.
Aug 09, 2009 | Maytag MTB1976HR Top Freezer Refrigerator
Freezer icing over fan
Check the water spout comeing into ice maker and see if water is leaking out or spilling over
May 24, 2007 | Kenmore 50522 / 50524 Side by Side...
Refrigerators Logo
Top Kenmore Refrigerators Experts
John Tripp
John Tripp
minguy15
Level 1 Expert
mike cooper
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
