Question about Kenmore Oasis 27042 Top Load Washer
Why does my kenmore oasis washer 110.27042603 show f1 @ every start of load? what part do i need to replace to correct problem? please help!!!!
    Top Expert:
  • Kenmore Master
  • 9,472 Answers
Customer has F1 Error Code. The control is sensing an error in the signal from the air pressure sensor circuit. CAUSE: CORRECTION: HE Top Load Washers Models: F1 Error Code WTW6200S WTW6300S WTW6400S WTW6600S WTW6700T MTW6300T MTW6400T MTW6500T MTW6600T MTW6700T Serial Numbers: CT01 - CU52 There are four areas of concern that can cause the F1 Error Code. Each area must be sequentially addressed to ensure that the diagnosis is correct and the proper repair is completed. A) Air leaks in the air pressure (switch/sensor) hose. a. Inspect the hose for cracks, pin-holes or loose connection. b. Replace the hose and harness assembly (W10058730) if it is compromised. B) Moisture in the air pressure (switch/sensor) hose. a. Inspect the hose for evidence of water. b. Replace the hose and harness assembly (W10058730) if water is detected. C) Lint or flashing in the air dome hose connection port. a. Inspect the air dome hose connection port for lint or flashing. b. Use a small round device (small screwdriver) to ensure that there is nothing blocking the air dome outlet on the tub. D) The control needs to be replaced. a. Replace the control only after you have completed steps A - C above, and verified that there are no issues with the air pressure system.
Posted on Jan 04, 2011
Toploader kenmore elite oasis is showing F1 code for error. I do not have an owners manual. What does F1 mean?
The F1 error code means that the computer thinks a button on the touchpad is stuck. Sometimes this can be resolved by making sure the touchpad connector fits tight into the control board. The F1 code can be cleared by pushing CANCEL/OFF. If it returns the touchpad needs to be replaced .
Gene
Aug 21, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
What does F1 code mean
A Sublime Master at the Samurai School of Appliantology recently did battle with one of these newfangled Oasis washing machines. The F1 error code was intermittent, which made it impossible to troubleshoot. Turns out there’s a service bulletin out on this problem. Come, feast your bewildered eyeballs on the wisdom of the Masters.
Read more: Recurring and Intermittent F1 Error Code on a Whirlpool / Kenmore Oasis Washer | Washer Repair | Fixitnow.com Samurai Appliance Repair Man http://fixitnow.com/wp/2009/01/25/recurring-and-intermittent-f1-error-code-on-a-whirlpool-kenmore-oasis-washer/#ixzz0vdcTKwJA
Get appliance parts at http://parts.fixitnow.com
Aug 03, 2010 | Kenmore Oasis HE 27082 Top Load Washer
My kenmore oasis shows the f1 upon starting the machine and at 23 minutes and often shows th ul why is this
Mine is doing the same exact thing. Just after I press "Start", the F1 starts beeping. Then at 23 minutes into the cycle, it does it again. So frustrating! What is wrong with this machine?
May 20, 2010 | Kenmore Oasis HE 27082 Top Load Washer
Oasis HE 27082 Stainless Steel Top Load Washer: my kenmore oasis shows the f1 upon starting the ma...
The F1 error code on this washer indicates a Primary Control Board failure.
It is likely that the machine control board will need to be replaced to correct this problem.
The part number for the machine control board is undetermineable because you have not provided me with the exact model # of your washer.
The procedure for replacing the machine control board is provided HERE
LINK: http://media.fotki.com/1_p,wfgstgtftbtkrrdxgtqsskgwtqkq,vi/gfsfgfsgqxgfqtqtgwf/1/1303472/5961857/image55806img-or.gif
NOTE: Be sure to unplug the washer to disconnect electrical power before accessing internal components.
There is a slight possibility that a problem with the pressure switch hose could be causing this problem.
A pinched or twisted air hose can cause this fault code.
When you open the console, check the air hose connected to the pressure switch on the machine control board.
If it is pinched or crimped, I recommend rerouting the hose to resolve this problem.
This may fix your problem without replacing the control board.
NOTE: You may want to check for this condition before ordering the control board. Most electronic control boards cannot be returned for a refund or credit.
If you find no apparent problems with the air hose on the pressure switch, then replacing the machine control board on this washer should correct your problem. There is a risk involved in replacing this part yourself.
As noted above, you could have a problem with the air pressure hose that is not apparent upon your initial inspection. A service technician would normally need to properly and thoroughly diagnose this problem before replacing the control board.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question!!!!!
May 18, 2010 | Kenmore Oasis HE 27082 Top Load Washer
F1 & F51 error on my Kenmore Elite Oasis HE washer
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Good news for Oasis F-51 sufferers! Sears will replace the electronic control board (the F51 prob) for free, in warranty or not. Serial #s for the bad board are: CS48 - CS52 or CT01-CT49. Call Sears at 800-847-9083.
You hv to rate me ‘very helpful’, or the call won’t get thru!!
Feb 08, 2010 | Kenmore Oasis HE 27082 Top Load Washer
Machine stops several times shows F1 code
this is a main control board failure and needs to be replaced
Sep 16, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore washer model 110.27052601
F1 is the mcu failure code and yes I hope your under warranty as it needs replaced.
Sep 14, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Oasis 27042 Top Load Washer Logo
362 people viewed this question
Sal DeAngelo
fordexpert
 Brian Main
Brian Main
