Question about Consew 226R2 Sewing Machine
I have a consew 210 ive had it for 4 months. it was going well until i turned it on it made the normal tuning sound then the sound just cut out it makes no sound at all except for a low buzzing sound does it need a service?
5 Suggested Answers
  • 848 Answers
SOURCE: TIming Consew 210
I am not sure about this particular machine but in most machines there will be a nob on the front loose low numbers like 0 1 -2 work well on number 3. If the nob is not on the front check and see if it is on the side.
Posted on Aug 27, 2008
what Brand sewing machine you got and model
SOURCE: Consew
Sorry For being late this machine i cant find anything on this sorry
Posted on Sep 04, 2008
  • 71 Answers
SOURCE: service manual for a consew 106rb
Hope this helps! Let me know if it not the right manual, and I will find you the correct one.
http://consew.marginspluslive.com/images/products/parts%20books/106R.pdf
Posted on Oct 31, 2008
Consew sewing machine 210 model slack stitch underneath, have put in new needle cleaned everything, oil level good, tension discs cleaned but still having dramas.
Assuming your top thread tension at no.4 or mid range, still not good, check your bobbin thread tension ok or not. If tight try reduce the tension. Problem persist, possibly bobbin case tension spring dirty or ageing.
Nov 05, 2013 | Sewing Machines
Consew 101
Go to www
consew.com/Files/112347/InstructionManuals/CM-101.pdf
Page 4 LW x 6T Size 3, 3.5 and 4 depending on what you are sewing.
Oct 15, 2013 | Sewing Machines
My Bernina 210 Activa won't power up. I had it tuned up by a Bernina tech a few months ago and this is the first time I've pulled it out. No power/nothing. Seems like I'm just missing som
seems silly, but did you remember to plug it in? If you used a power strip, did you remember to make sure the strip is turned on?
Make sure the connection is plugged into the machine.
Good luck
Jan 23, 2013 | Sewing Machines
I need a manual and a bobbin case for a new home model 764
http://www.sew4less.com/index.php
I don't know if the link will work for the bobbin case, if it doesn't
go to sew4less.com
Bobbin Case # 52237 NB, Click for model info.
p_4754_1148578825.jpg Product #: 4754
Price: $ 19.95
Bobbin Case # 52237 NB, No backlash type.
A bobbin case, also known as a bobbin holder or bobbin shuttle, holds the bobbin that is filled with thread.
Each machine has a specific bobbin case. # 52237NB
Brother 755 Brother B714 Brother B735 Brother DDL-227 Brother DDL-555 Brother DL-5550 Consew 103 Consew 104 Consew 210 Consew 230 Consew 231 Consew 7360R Consew 99 Consew CN 223OR Janome / New Home 764 Juki DDL-227-L Juki DDL-5530 Juki TL98E Kenquilt 622 Singer 1300 Class Singer 1400W Singer 188K Singer 191U Singer 195K Singer 196K Singer 241 Singer 245 Singer 251 Singer 281 Singer 291U and more!
here are is a site that have manual
http://www.sewingpartsonline.com/
Jun 09, 2012 | White Sewing Sewing Machines
Hey i have a 210 consew straight stitch i think the timing is out the threads break easy and stitch is not running truely straight can you help me out please
okay i think you have the 6needle pushed in too fa.take out the needle and turn it the other way from the position it is right now and when you reinstall it dont push it too far up...that will remedy your problem. good luck.
Sep 13, 2011 | Sewing Machines
I need a manual for a model 230 consew, I recently bought it from a friend, I want to learn how to thread it, and wind my bobbins, can you help me, unable to find one
You can go to the consew official website and download the PDF file for the 210 model. It's the same as the 230 r-1 (which i have). I found this information by calling the consew headquarters. You can also download a PDF with the full parts list for the 230 model specifically. This link may help http://www.consew.com/default.aspx?pageId=4
Apr 06, 2011 | Sewing Machines
Consew 206rb-1 thread was caught in the boobin area i removed
Had the same problen today, Remove your bobbin, the part where the bobbin is in should move a little, if it does not you have string you can not see behind that part. To get it out turn the machine backwards, it will really turn hard, but will turn, do this until you can see the thread come out or until the piece that holds the bobbin will move a little. good luck
Apr 06, 2009 | Consew 206RB
Loose top stitch when in reverse 206 RB4 Consew
Do you know how to check the timing of your machine? It sounds like a timing problem to me. If you don't know how to check the timing:
take the side plate off, take the needle plate off, take the presser foot off, and put a new needle in the machine. Make sure that the needle is in the lowest position and look at the needle bar for the two timing lines. Locate the top line. Then, turn the handwheel toward you until the top line is where the bottom line was. At this point, the tip of the hook should be directly in the scarf of the needle.
Oct 19, 2008 | Consew 206RB
Consew
Aug 28, 2008 | Sewing Machines
Thread cutting
If you are asking about the consew CN2230R , the answer is No ; it does not have a trimmer system.
Aug 03, 2008 | Consew CN2230R Sewing Machine
Consew 226R2 Sewing Machine Logo
126 people viewed this question
Top Consew Sewing Machines Experts
Michael Galve
Michael Galve
Oloyede Monsuru
Irene Tulloch
Are you a Consew Sewing Machine Expert? Answer questions, earn points and help others
