Question about GE D52GW12 52" Rear Projection HDTV-Ready Television
My GE D52GW12 Rear Proj. 52" TV won't turn on. The
  • 8 Answers
SOURCE: GE D52GW12 52 in. Rear Projection HDTV-Ready
Please report these problems to the consumer product safety commision. I beleieve this common problem with large sparks and flames warrants a recall.
https://www.cpsc.gov/cgibin/incident.aspx
Posted on Feb 07, 2008
Slinteriors
  • 8617 Answers
SOURCE: GE D52GW12 52 in. Rear Projection HDTV-Ready Television
The ITC222 chassis actually has two different boards that are related to the power supply.
(1) Main power filter board #MIS222E0000.00
(2) Power supply #PP222E0000.37
The first board is a small board where the power cord enters. The second board is the large board that the small board plugs into.
Posted on Apr 11, 2008
Slinteriors
  • 8617 Answers
Most likely bad solder connections around the flyback area of the circuit board, that model is famous for bad solder around the flyback and bad flybacks them selves. But if the led doesnt flash 3 times then go out, its most likely a solder issue.
Posted on Jul 05, 2008
Slinteriors
  • 8617 Answers
SOURCE: where can i get picture tube for Ge D52GW12
you can get one at the following link with free installation instructions.
http://servicemanuals.vstore.ca/
Posted on Jan 30, 2009
SOURCE: ge tv model d52gw12 powers up green light flashes
picture had a yellow tent then several dayes later went blank
Posted on Nov 14, 2009
My 52 " GE Projection
Tv needs to be realined by adjusting the Screen Drive Controls to Tubes.
Located behind the Front bottom Panel on front of Tv.
Focus/Screen Control Block 3 on top for focus and 3 under them for screendives to each Tube R/G/B.
Jul 03, 2011 | GE D52GW12 52" Rear Projection HDTV-Ready...
ON our GE D52GW12 52" AFTER TURNING TV ON IT
Try resoldering the flyback transformers connections on the board. Its very common for the flyback pins to develope cracks around the pins which can cause that issue. I would check that first with that model.
Jun 13, 2011 | GE D52GW12 52" Rear Projection HDTV-Ready...
My GE D52GW12 52 in TV only turns on after I push the power button numerous times (sometimes up to an hour). The green light on the power button comes on but kicks off after about 5-10 seconds. It is...
Thats a very easy repair which is almost always related to failed power capacitors CP150, CP120 and CP114. You can get the RCA repair kit which is the same as the GE from www.tvrepairworld.com the kit is called the ATC221 CP150, CP120 & CP114 repair kit . The kit contains the caps and the CD with instructions for the repair.
Apr 30, 2011 | GE D52GW12 52" Rear Projection HDTV-Ready...
How do i adjust the picture on a GE D52GW12 52 in. Rear Projection TV? The picture is too large.
There should be a zoom button on the remote control. Each time you press it the size of the picture changes. If there is not a button on the remote, there should be a on screen menu display that allows the size to be adjusted. If you are using a HD cable box or HD satellite receiver, they also have picture zoom options.
I hope this helps
skyassoc
Dec 10, 2010 | GE D52GW12 52" Rear Projection HDTV-Ready...
GE D52GW12 52 in. Rear Projection TV, serial#. 101551428, chassis PTK195p2b, Servie # 52GW948YX2 TV keeps getting slowly darker, is there a lightbulb inside that I can replace...TV is perfect other than...
There is something else you can try if the set has not been "serviced" for several years.
This model has three picture tubes with large black lens on top of each, if the set is in a dusty area and the lens have never been cleaned, dust on the lens will gradually make the picture duller and darker.
Unplug set and remove back cover, see if you can see the three large lens and if so wipe them clean with a lens cloth or a paper towel with glass cleaner sprayed on it.
Let me know if you need more information.
SD TECH
Nov 26, 2010 | GE D52GW12 52" Rear Projection HDTV-Ready...
High pitch noise, no picture. GE 52" projection, Model D52GW12
Ur high voltage FBT the flyback tranformer,a big black block of plastic with a gray wire connected to a board.The cap it dead.The FBT it useally it dead too,arching noise FBT not holding the high voltage.
Mar 30, 2010 | GE D52GW12 52" Rear Projection HDTV-Ready...
52 inch GE big screen projector
Your TV is a RCA even though it says GE its made by Thompson/ Deflection Board Call UED 1-800-648-6657
Dec 31, 2009 | GE D52GW12 52" Rear Projection HDTV-Ready...
Where can i get picture tube for Ge D52GW12
Jan 29, 2009 | GE D52GW12 52" Rear Projection HDTV-Ready...
52'' GE Projection TV will not turn on
Called a service technician. Found bad board and wanted $437.00 I bought a new TV
Nov 12, 2008 | GE D52GW12 52" Rear Projection HDTV-Ready...
GE D52GW12 52" Rear Projection HDTV-Ready Television Logo
119 people viewed this question
Top GE Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
