Question about Toshiba 32A50 32" TV
Toshiba 32A50 The horizontal scan lines seem to roll off the top of the screen and fold back down like the guns don't know where the top of the tube is anymore, just started about two months ago. Any help, suggestions or thoughts are greatly appreciated. Thanks... Robert
    Novelist:
  • 129 Answers
There are 2 or 3 filter capacitors found near the vertical IC on the printed circuit board. One of them is likely defective. It would be a relatively inexpensive repair at a repair shop. The filters cost $1 each at most.
Posted on Jan 04, 2011
Horizontal lines in the top
CAUTION!!!!
you should never fix the inside of the tv unless you are a professionel tv repair man
there is High voltage and the only thing you should to is get a new tv set.
Nov 15, 2009 | Televison & Video
Flatline!
the vertical drive ic that drives the yoke for vertical sweep has blown.
sometimes it is solder problems like sharp and toshiba had.
the part is 10$ the pc board will label it ,the yoke is the coil setup on the picture tube.if you follow the wiring half goes to the horizontal drive,and the others to the vertical section.the chip drives the coil directly.there are VERY high voltages in there ,even turned off. the pix tube cap on top is 30000v. like a stun gun.the horizontal drive 2000 volts and the main power supply 165 volts dc high current.you need a special setup to discharge the picture tube.
May 15, 2009 | Mitsubishi CK-35308 35" TV
Mitsubishi TV had horizontal lines across the screen and rolls up
Answer
ONE: Yes, the speaker mounted close/near to the set can be a cause of mischief; please move it further away and see if that helps clear up the problem. But, you must keep it away for several days before you will know for sure because it takes some time to degauss all the internal parts that may have become corrupted by the magnets in the speaker.
TWO: Yes, any set can be repaired the question is cost and wisdom. Old sets are sometimes not worthy of the repair simply because of the likelyhood that another failure will follow soon after. A big screen always invokes a repair charge of $200 and up. After a few of these you will wish you had put all the money into a new set!
THREE: The lines are most likely a problem in the vertical blanking circuits of the set. These are horizontal retrace lines that are supposed to be blanked out during vertical retrace of the raster. Think of it as a paintbrush that scans across the screen painting thin lines and when you get to the bottom of the screen it goes quickly back to the top, but during that time the horizontal, which is many times faster, has made several sweeps; so it must be blanked out during the retrace. The repair involves finding the guilty parts and replacing them. Usually this repair runs over the $200 somewhat.
FOUR: Prior to calling in a service tech try a hard reset to see if that will recover any of the circuit degradations. Merely unplug the power cord and leave unplugged for 4 hours or more. It may help. Or, it may not help; but worth a try since is won't cost you anything.
If the set is over 5 or 6 years of age it probably is not a condidate for any expensive repair. On the other hand, it is a Toshiba - and they make a fine set.
Hope this helps. Let me know if you have further thoughts.
May 09, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Toshiba 32A40 32" TV Problem
does any one can send me the schematic of TOSHIBA 32A40? I have a vertical problem and I need to locate the vertical IC or trancistor.
I only see a horizontal line on my Tv.
thanks.
teranco@hotmail.com
Jul 13, 2008 | Toshiba 32A40 32" TV
Toshiba 40pw8db with colored lines horizontally
there are some boards in the tv that plug in (push down) have the power off and unplugged have a look around, and see if any boards have come loose, stay away from any thick red wires (EHT) DO NOT PULL At the Gray Rubber Caps that go to each gun (tube) RED GREEN Blue, this can carry a heavey charge even if the tv is off and has been for days, regards mark
Mar 15, 2008 | Toshiba 40H80 40" Rear Projection...
Samsung TXG2547
The picture on your TV is created by an electron gun firing at the phosphor coating on the screen. The position of the guns beam is controlled by magnetic coils, which are driven by scan circuitry.
Normally, the gun scans left to right, top to bottom to create each single frame of the moving image.
From what you are saying, it sounds like there is a fault in the vertical control system somewhere - basically the gun is going left to right but not up and down, resulting in your picture being squashing down to one row high!
It is unlikely to be a fault with the magnetic coils. My guess would be a faulty resistor that is breaking down (and changing its value) as it gets hot.
It should be a relatively easy to fix, but given the age/value of the TV it might be worth considering a replacement.
Matt
Feb 26, 2008 | Samsung TXG2547 25" TV
43H71 43 In Projector
Use Toshiba STK392-110T X 2 for exact replacement..........T.
Nov 21, 2007 | Toshiba 43H71 43" Rear Projection...
Does anyone know why my tv screen goes black while the power light flashes on and off?
it seems that there is a problem in power supply. if it is ok check horizontal section it is a simple problem &can be fixed by skilled tech.
Sep 28, 2007 | Toshiba 32A50 32" TV
Zenith Model SR3238RK horizontal lines
There must be a capacitor which would be brust or leaked.So check it in th horizental section.And power supply section.Find that one and replace it. Good luck
Aug 12, 2007 | Zenith C27A24T 27" TV
Toshiba 32A50 32" TV Logo
103 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
