Question about Goodman GMS90703BXA Heater
We have already cleaned the sensor, but still not working what else could be???
  • Goodman Master
  • 2,597 Answers
The pressure switch not working try jumping it out
Posted on Jan 04, 2011
Had cleaned GE oven yesterday using SELF CLEAN and today my oven will not work as it keeps flashing UNLOCK DOOR when the door is already open. Cant use the oven
There is a sensor/switch that sends a signal that the oven door is locked and that it is unlocked, it must be defective.
Jan 11, 2017 | GE Ovens
2002 jeep map sensor problems
Not exactly sure what you're describing. Incorrect voltage to or from Map sensor? Map sensors are very sensitive. I clean mine with a Map Sensor Spray cleaner every time I change the Air filter. Check to see if the fine, almost hair like wires in the Map sensor are broken...replace and/or clean if necessary. Best of luck resolving this problem.
Mar 31, 2014 | 2002 Jeep Grand Cherokee
Code p0171
Oxygen sensor detected lean condition bank 1. Mas air flow sensor dirty or bad clean first or small vacuum leak
Jan 09, 2012 | 2008 Chevrolet Impala
My HP J6480 keeps insisting that I have a Paper Jam where there is not. I have already tried a Soft and Hard Reset of the printer. What else can I do to get it working properly?
11_16_2011_10_40_07_am.jpgRemove back cover check for paper, check paper sensor flag as shown in photo shot, check for dislocation/broken/no free movement..if feels good. Clean paper sensor located just below the sensor flag shown in snap shot, if you are tech guy you can open and clean it other wise blow pressure air to clean with out open the printer.
Thanks for questioning
Nov 14, 2011 | HP OfficeJet D135 All-In-One InkJet...
Message says to add paper to cassette 1 there is already paper in that tray how do I fix?
There is a sensor with a flag that may need to be cleaned or replaced. Take out the tray and put the printer on its backside (so you are looking underneath the printer. There is a flag and sensor visible. Clean the sensor. If that doesn't work, replace.
Dec 23, 2010 | Kyocera Office Equipment & Supplies
How to check speed sensor 2001 road king ( sensor has already been cleaned)
speed sensor is located in front of engine oil dip stick on my o1 rk,in frt of starter motor,my speedo stoped working today, and the sensor has one 7/16 bolt head easy to get to with open end wrench.remove the bolt and slowly wiggle the sensor and lift up and pull out,my sensor was coverd with metel shavings,i wiped it clean with a clean rag,a magnet is also helpful to remove shavings from sensor but the rag worked fine,put the sensor back and bolt it back in,not to tight just good and snug.it fixed my problem.speedo works great again.
Apr 14, 2010 | 2001 Harley Davidson FLHRCI Road King...
Scotsman cme506
i service scotmen cme506 blink 2 times in the water iclean bin sensors check water lebels install new inlet valve and due same
Apr 14, 2009 | Scotsman Cooled Modular Contour Cuber...
Water light on dryer
hey cadoras,
you might want to check the sensor for the water inside the dryer. you say that even if you already put water in it, the light is still on correct? which means that the dryer does not detect or sense that water is already there. so please check if the sensor is working and if not, replace the sensor.
Jun 04, 2008 | Hotpoint Dryers
Goodman GMS90703BXA Heater Logo
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
