Question about Toshiba NB255N245 Mini Notebook
I've got this netbook (PLL2PU00701F), and would like to use it with my new Linksys E2000 router @ 5 GHz. How can I make it work?
  • 3 more comments
  • sheepdog0331 Jan 04, 2011
    Does your computer detect the wireless network broadcast by router or any other routers in the area? or is your problem more to do with authentication to the router?
  • jwiles300 Jan 04, 2011
    My computer only detects the wireless network if I drop the network's bandwidth from 5 GHz to 2.4 GHz. The whole point behind the new network was to get away from the clogged lower bandwidth! Sigh...
  • jwiles300 Jan 05, 2011
    I do not want either a wired connection or a 2.4 GHz wireless connection. I want a 5 GHz wireless connection. Can this be done? If not, I will have to return my new router, as it won't be worth the money I spent on it. Thanks!
  • jwiles300 Jan 08, 2011
    If I set the router to the 2.4 gigahertz band, the netbook can communicate just fine, but I'd like to be able to configure the netbook to communicate in the 5 gigahertz band as well. Is this possible?
    The netbook talks to the router just fine with the router set to the 2.4 gigahertz band, but not set to the 5 gigahertz band. I need the higher frequency since my condo building is overloaded on the lower frequency. Can I change the netbook's settings to use the 5 GHz frequency to talk to the router?
  • Toshiba Master
  • 32,281 Answers
First you need to configured your Linksys wireless with the SSID and encryption key and then configure the wireless card in your notebook with the Linksys wireless settings.
The password is the encryption key in your wireless router, without this key the wireless router won't allow the laptop/computer to connect to this wireless router.
The WEP, WPA, WPA2 encryption key is in your router's wireless settings. Log into your router and got to the wireless settings, you will need to get the SSID and the encryption key. Then go to your computer/laptop's wireless card and configure it with the router's SSID and encryption key, so it will then connect to the wireless router and the Internet.
To secure your wireless network from unauthorized access,please click on this link and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
Posted on Jan 05, 2011
  • Toshiba Master
  • 4,924 Answers
If your router is already connected to the network ..things are easy ..you can either connect the laptop in one of the ports using a LAN cable ...and set the tcp/ip protocol in the LAN card of the laptop to automatically assign an IP address and it will take one in the range of the router settings...or ...connect it wireless by clicking on the icon of the wireless in the task bar ...and open it ...and in there click on the scan for network ..and choose from the list the one with your router 's name and connect ..
(assuming again the router has been configured..)
If you didn't set the router ...you have to follow the steps in the next link ...and configure it ..
In short ...connect the cable that came from your modem or after case the internet for a direct connection ..into the Wlan port ..and a computer into one of the lan ports ..
after that choose in the lan card to get an IP address automatically ..in the TCP/IP protocol ..
and to connect to the router's settings type the router's IP address in the internet explorer ( or what ever browser you have ) like this ... http://192.168.1.1 or the address written on the back of the router ..
IN this moment the log in page of the router will appear and you have to write the admin and password for it ..Usually the factory set ones are ....admin for the user and admin the password
Cause it is too much to write it ...the actually settings I link them cause they are available on the net ..
you can also find them on the support page of the router ..but basically it has a dhcp setting which will behave like a lan card ..and for the wireless feature all you have to do is enable it ...set a channel ...and a name and password for your network ..
http://www6.nohold.net/Cisco2/ukp.aspx?pid=80&app=vw&vw=1&login=1&docid=e30f926604334d538668529cb50ad174_21463.xml
http://www6.nohold.net/Cisco2/ukp.aspx?pid=80&vw=1&articleid=21474
and here you have the manually configuration in case you can not run the disk ..
http://www.home-network-help.com/wireless-router.html
Where is the security key on a cisco linksys E2000
if you enter into the configuration mode of your linksys,go to wireless and in security the section for enter the passphrase or key is what your router is asking for.copy that and use it.
Oct 27, 2012 | Cisco Computers & Internet
Need Driver for the Linksys E2000 Advanced Wireless-N Router? Where can I download?
You can Find the Downloads Here
http://homesupport.cisco.com/en-us/wireless/linksys/E2000
Mar 06, 2011 | Cisco Linksys E2000 Advanced WirelessN...
My acer aspire one netbook will not connect with my new linksys e2000 router.. It was fine with my former linksys router
If your former linksys router was NOT N but rather b/g, then the problem is likely that your new router is running N and must be reconfigured to run b/g instead of n on its wireless. The acer aspire one netbook's integrated WiFi is 802.11b/g and the only way to do 802.11n is by using a plug-in USB 802.11n wireless adapter. To manually configure the router's wireless for 802.11b/g or n...
1. Connect the netbook using an ethernet utp cat5 patch cable between one of the four RJ-45 LAN ports on the router to the 10/100 ethernet RJ-45 port on the netbook's left side.
2. Start a browser like Internet Explorer and enter IP address 192.168.1.1 (default for Linksys)
3. On the login window, enter admin for username and admin for default password, then click OK
(The password may be changed if the router's setup software on its CD has been run.)
4. On the Linksys Setup page, click the Wireless tab
5. On the Linksys Wireless page, for Network Mode, click v for drop menu and click BG-Mixed
The preceding is from Chapter 3: Advanced Configuration which starts at page 16 of the 59-page Linksys E2000 user guide/manual. If you are missing this manual, it can be obtained by clicking...
http://homedownloads.cisco.com/downloads/userguide/E2000_UG_USA_V10_NC-WEB.pdf
A final note: The easiest way to setup the router is to run its setup software on the CD that comes with it. If you want to do this with the netbook (which doesn't have an internal CD drive), an external CD drive would have to be plugged into one of its USB ports.
Jan 25, 2011 | Cisco Linksys E2000 Advanced WirelessN...
Hi, After flashing dd-wrt.v24-15508_NEWD-2_K2.6_openvpn.bin (which obviously was a bad idea Sad) onto my Linksys E2000 the device is now stuck with a blinking Power LED. When I connect a PC via LAN the...
Since you flashed your router, you need to reset your modem as well, so it recognizes the "New" router. Turn off both router and modem. Turn on modem first, give it a minute to boot up, then turn on router and you should be ok.
Jun 29, 2017 | Cisco Linksys E2000 Advanced WirelessN...
How do I install software on cd from linksys when my acer netbook doesn't have a cd/dvd drive?
you will need to download the drivers from the internet and install them that way, no CD needed.
Dec 28, 2010 | Cisco Linksys E2000 Advanced WirelessN...
How to install the cisco links E2000 advance wireless N router in the computer. i tried bt cannot install it
there are two ways of installing a linksys E-series router
>>first is the easy setup disk/ if it will not work, try to dissable the firewall of your computer
>>if still doest work, you can access the setup page of the router with the DG, 192.168.1.1
>>for cable connection always do a mac address clone
>>for DSL, change the lan IP,
>>call linksys tech support, iwill be glad to solve your problem
Dec 12, 2010 | Cisco Linksys E2000 Advanced WirelessN...
I have a linksys e2000 router and it continually drops out. The only thing I notice is that the port 3 light is on constantly. That seems to freeze it up and I cannot get it to go away. Previously, we...
Try upgrading the firmware. Linksys' website should have the latest version for your router posted there.
Are you able to log in to the web interface for your router? Are you able to ping your gateway address (likely, 192.168.1.1)?
You may also want to try resetting it to factory default.
Dec 10, 2010 | Cisco Linksys E2000 Advanced WirelessN...
I have a clearwire modem. I have to locate it 80 ft from my two home desktops and laptop. i need to know how to best do this. i have an e2000 router that i was hoping to use a wre54g range extender...
The Linksys E2000 router is N series router and the WRE54G is G range expander.
WRE54G is only computer with the WRT54G and WRT54GS routers.
You have E2000 router. I believe that router is capable of broadcasting the wireless signal upto 100 fts.
As Linksys says that router is capable of signal up 200 - 300 fts, but it is not.
You can try changing the wireless channel on the router to increase the signal.
Open the setup page of the router.
Go to wireless tab and change the configuration view to manual.
Try changing the channel to 11, 9, 6 ,1. See if that works.
Click Here for more information about the routers and network
Oct 02, 2010 | Linksys Computers & Internet
Toshiba NB255N245 Mini Notebook Logo
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
