Question about Whirlpool Washing Machines
How to remove the front/side panel on whirlpool washer model WTW5800swo? No screws on the consol are visible. I have a small leak on the bottom of the washer.
    Top Expert:
  • Whirlpool Master
  • 9,472 Answers
Here is a video to show you how it's done.
Posted on Jan 04, 2011
Whirlpool washer door wont open
1. Remove the lower panel under the door by loosening the three screws under the bottom edge on the front of the washer. HINT: If you prop up the front feet of the washer with some small blocks of wood, this will make access to the screws much easier.
2. With the screws removed, the lower panel should drop down then come off. If the panel sticks, a light tap on either side will knock it loose.
3. Reach your hand up inside the washer behind the front casing on the right-hand side. This is where the door latch assembly is located.
4. At the bottom of the door latch assembly is a small pull tab. This is the manual release for the door. Pull the tab straight down and the door will come open.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 21, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool model # wfw8300 duet washer door will not open with wet clothes in it-how do I unlock door?
Jun 30, 2010 | Whirlpool Duet 3.8 cu. ft. Front Load...
Duet GHW9150P Front Load Washer: how do we open a whirlpool front loading machine w...
May 17, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Need to Remove the top of a Maytag LAT7300AAW washer
if its a top load,you need to remove the front panel first by removing screws near floor of front panel,then the top screws are visible at the underside of the front of top cover
Mar 12, 2010 | Washing Machines
Take off whirlpool duet front panel for filter
Dec 29, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Mt front load duet whirlpool is locked full of water
Oct 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
How do I get the front off of Kenmore 24962 washer
You may not need to remove the front. Unplug the washer and remove the control panel (there will be some screws set in the trim at the bottom front of the control panel and some more in the upper back corners). The panel should lift off about a half-inch. You may be able to see the fill valves through the hole where the wiring harness goes up to the control panel. If you can see them, start a fill cycle and watch for stray drips or spraying (lime streaks, corrosion or wet spots on the outside are also evidence of the leak location). If you can also see the hose going from the tub to the water level switch, check that.
Some washers have removable backs; others require removing the top before you can get the front off. Still others have a narrow panel at the bottom front that comes off by removing several screws down near the floor or at the top of the panel (often matches the corresponding panel underneath the door of a front load dryer in a set). On most washers, the front and side panels are one piece of metal, so you have to remove all of the other covers to get it off and you probably will have to tip the machine in order to get at screws in the bottom. In other words, unless you are one of the lucky people with the panel at the bottom front, look for an easier place to watch for the leak.
Aug 10, 2009 | Kenmore Washing Machines
Need to Know how to remove top and cabinet
first, do you have phillips screws on back of console at bottom goin down or in front bottom? one or the other remove these then slide console forward and fold back on hinge on top. if no screws then clips are hidden on front edge on end plates. use putty knife from front to push and release lifting console at same time. fold back.
use screw driver to pry and release brass clips holding top to rear panel. unplug lid sw connector and pull cabinet body away from machine. top and cabinet is screwed together and removed as one piece. cabinet hinges under base on front and sits on top of sides.
May 02, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Water is leaking out of the machine Im not quite sure where from.I guess pouring out would describe it better .It`s not coming from the door.
leaks are usually from valve /dispenser area on top left or from door boot. to check valves open top cover by removing 2 or 3 torx/ 1/4' screws at rear and slide back. check underside of dispenser for cracks, check rubber hose connecting valves to dispenser.
to open front and check around boot, remove top cover, remove screws beside dispenser opening (remove drawer) snap control console off starting at dispenser side. On older non teardrop front disconnect and remove interface cables from ccu at rear (ribbon cable in clips on right side. On new teardrop models remove teardrop by unsnapping at top then work down carefully, then unclip console starting at left, disco cables at right side of interface. remove lower kick panel with 3 screws on bottom. then remove 2 front panel screws. remove 2 door lock asm screws and spring clip around boot, then 2 front panel top screws. panel comes right off, carefull of boot. door lock stays behind.
Apr 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Leaking in on the left side of the washer on bottom
you can remve the lower acess panel (3 screws along teh bottome front panel) too look to see where it coming from. the top also removes with 3 screws along the top of back panel
Nov 06, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
79 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
