Question about Ricoh Aficio 2022 All-In-One Laser Printer
Ricoh Aficio 2022 Unit indicates to call for
Ricoh Aficio 2022 Unit indicates to call for service using SC990 Other error codes are as follows: 925 (Net File fuction) 870 (Address book error) 872 (Email reception error) plus HD data error Does anyone know how I would go about clearing these codes myself?
  • 591 Answers
You could reset all the counters but you should call a proffessional with a good mantenance KIT, your copier probably needs it...
Have fun!
Posted on Jan 04, 2011
What's your question? I HAVE AFICIO 2022 COPIER AND ITS GIVING ME THREE ERROR CODES SC548, SC792, SC870 WHAT COULD BE THE PROBLEM AND HOW CAN I SOUGHT IT OUT
some potentially useful information can be found here: what the error codes mean, and the services manual; (I have pointed to error code 792 but the others are different pages), there is a copy of the service manual too. This is only a starting point !
http://printcopy.info/?l=en&mod=free&chap=erc&brand=Ricoh&model=Aficio 2022&page=6
(link hasn't copied well, last line is part of it)
Try also this
http://copierliquidationcenter.com/Copier_Repair_Service/index.php?topic=44.0
for Error sc792 see
http://www.copytechnet.com/forums/ricoh-savin-gestetner-lanier/35515-ricoh-aficio-2022-a.html
for sc870
Thread Ricoh 2238c SC 870 Address book error
for sc548
Thread RICOH Aficio MP C3500 Error Code SC 548 and 549
hope that lot help :)
May 25, 2016 | Office Equipment & Supplies
SC392 ERROR CODE
There's a video showing how to clear SC error codes: Resetting Ricoh Savin Lanier SC Error Code There's also a discussion here: Thread Ricoh Aficio 220 error SC392
Jun 30, 2014 | Ricoh 885288 Black Copier Toner Cartridge...
How do I clear error sc546 on a Ricoh Aficio 2035
replace thermostat in heating section or u yuor tirmistor is directly touching the heat roller
Feb 13, 2012 | Ricoh Aficio 2022 Black and White Copier
SC548 AND SC990
Sc548 can generally only be reset by entering service mode, and generally is caused by a defective thermistor (thermostat) in the fuser, and/ or power fluctuations. Sc990 is a software issue. I'd consider a new HDD> You'll need a tech for these problems.
Aug 13, 2011 | Ricoh Aficio 2022 All-In-One Laser Printer
Ricoh Aficio 2022 AllInOne Laser Printer error code sc 541
This error appears when you have problems with TERMISTORS in fusing unit. You have to replace termistors if you can't reset the service call condition in service mode.
pifonski
Feb 24, 2011 | Ricoh Aficio 2022 All-In-One Laser Printer
I have A problem of SC990 in the ricoh aficio 2035/45 and also I get light copies and over tonning problem.
The light copies and overtoning is probably caused by the developer going bad. Do you have a service contract on your copier? It's likely time for a whole PM (preventive maintenance) procedure.
The sc990 is probably caused by the copier's condition as well. Once you have the PM done (or at least replace the developer, rebuild the photoconductor unit, and clean or rebuild the transfer unit) the sc990 codes should go away along with the poor copy quality.
Jun 19, 2010 | Ricoh Aficio 1035 Copier
Sc990
sc 990 relates to the nv ram chip on the main board also check the values of the lazer unit are correct and not changed
Jun 16, 2010 | Ricoh Aficio 450 Copier
Error code sc 172 on ricoh aficio 2103
Hello sir; This error code is indicate video process error, may be can be reset, the procedure as follow;
press "clear mode", "107", then press and hold down "clear/stop" key for about 3 sec., until SP menu display, touch "copier sp" on screen, enter 581002 then press 1, then turn power off and back on. see what's happen. good luck !
Feb 23, 2009 | Ricoh Aficio 2022 All-In-One Laser Printer
SC 548 on ricoh aficio 2022
Hi Andreas: The fusing unit has not been reinstalled properly. There is a receptical on the back of the Fuser that mates with a plug in the machine when you install the part. the machine is telling you it did not detect the fuser. Undo the screws and remove it and reinset it again, makin sure that it seats properly. then you will need to reset the code. Go into SP Mode: Push in sequence; Clear-107-red stop button(hold this down until display changes and shows "copy etc"), turn machine off(using red power switch, wait 10seconds and turn back on. If you still get the error code the fuser still is not inserted correctly. Hope this helps.
PS: Black spots can also indicate a new drum is needed. It may have a small chip in the surface.
Regards
Munybuny
Jan 22, 2009 | Ricoh Aficio 2022 Black and White Copier
Ricoh aficio 2022 error code sc542
1. Mode(Yellow Button)
2. 107
3. Press STOP Button for 3 second (RED Button)
4. Copy Sp
5. 5810#
6. Excute
7. Power Off
8. Power On
Oct 23, 2007 | Ricoh Aficio 2022 All-In-One Laser Printer
Ricoh Aficio 2022 All-In-One Laser Printer Logo
603 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
