Question about Bang and Olufsen Beocenter 9300 Shelf System
Beocenter 9000 won't play cd,help - Bang and Olufsen Beocenter 9300 Shelf System
  • 122 Answers
The most common cause of not playing cds is c2103 on the pcb under the cd mech.Try cleaning the laser lens also.
Posted on Feb 01, 2011
I have a BEO Sound 9000 system. When I try to play a CD (in the upright player with space for 6 discs), there are a few clicking noises sometimes a brief rotation and then the machine defaults to...
Are you using the 9000 in the same orientation as before ie vertical then a new cd mech is required, a workshop job only, if you have moved unit then adjustment of the cd mech suspension is required, a simple adjustment shown in the owners handbook.
Jan 09, 2011 | Bang and Olufsen Beocenter 9300 Shelf...
'Beocenter 9000' sounds problem
Hi talenso,
as the beocenter 9300 i assume its at least 7 years old. This model has 2 transformers in them one for when it is on standby and one during operation. I suspect one of these has degraded over time.
My best advice is see if you can go to your local store and buy one of those power boards that regulate the voltage coming into the unit. This may solve your problem, but my gut feeling is one of the transformers needs to be serviced.
good luck
smeags.
Jan 08, 2008 | Bang and Olufsen Beocenter 9300 Shelf...
Beosound 9000 scratching top cd
You have to look up in the manual which way the two arrows on the underside of the unit are pointing when the CD player is located on the far right. The arrows are screw heads which appear in two holes on the underside. If, for instance, you are playing the unit lying flat on a shelf or table top, if you flip it up and forward to get at the arrows, the two arrows should both be pointing left. If you are mounting it on a wall, it's a different arrow combination. I had the problem you describe and this fixed it for me.
May 21, 2010 | Bang and Olufsen Beocenter 9300 Shelf...
I have a Bang & Olufsen Beocenter 9000 with a missing CD spindle
You might be able to get one from online parts shop CPC, they stock B & O parts. You can worry about if you can fit it when you've got one!
Dec 24, 2009 | Bang and Olufsen Beocenter 9300 Shelf...
Beocenter 9000 cd player problem. it won't start. the cover moves back to open and the player doesn't start..
the disc isnt being read. the laser lens may be dirty or the laser power cct may be faulty. check tr6108 and c2103 located on the servo board beneath the mech.(bc338/33uf16v).
Oct 25, 2009 | Bang and Olufsen Beocenter 9300 Shelf...
Problem playing CD's
beosound 9000? have you moved the unit.this unit requires cd mech suspension adjustment depending on how it is placed,eg. vert. flat horizontal.check handbook and adjust as required.if it has not been moved then workshop repair needed
May 17, 2009 | Bang and Olufsen Beocenter 9300 Shelf...
On our Bang and Olufsen Beocenter 9000,
if sticking is only your issues, then replace all belts. Cleaning has nothing to do with the sticking of doors.
Apr 06, 2009 | Bang and Olufsen Beocenter 9300 Shelf...
Trying to change speakers from B & O to BOSE
All you need to do is to measure or look up the impedance of the speakers on the Beocenter 9000. Most speakers are either 4 or 8 ohms. Now measure or look up the impedance ot the Bose speakers. If the Bose speakers are the same or a lower number than the Beocenters, you are good to go. But, if the Beocenters speakers are a lower number than the Bose, then you should not switch speakers.
Nov 20, 2008 | Audio Players & Recorders
Broken cd player
The motor is last thing to gone before you go to service check the rubber belt which connect the motor to the door gears.Your set is 20 years old and this should be the problem and easy to fix
Feb 07, 2008 | Bang and Olufsen Beocenter 9300 Shelf...
780 people viewed this question
Top Bang and Olufsen Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Bang and Olufsen Audio Player and Recorder Expert? Answer questions, earn points and help others
