Question about Maytag MFF2557HES Stainless Steel French Door Refrigerator
HOw do you know if your compressor is going out on a maytag model#MFF2557hes
  • Barrett Palumbo
    Barrett Palumbo Jan 04, 2011
    what are your issues
  • kim_nichols Jan 04, 2011
    Freezer is not cooling there was no frost on the coils, but they were cold and the fan is running. It did make a loud rattling noise earlier this aftenoon
  • 1,772 Answers
Sorry to read about your problem. you can have many different problems.
1. Bad temp control
2. Failing compressor
3. Defective start cap
4. Defective overload protector
5. Defective control board
But in your case, your freon maybe low
I suggest you call a service company. as they have the equipment to check for low freon.
I have tried to help you. Please help me, by Vote/Rate my response. Thanks.
If you live in the Denver area, I can help you.
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
1 Thumb - Not Helpful
Posted on Jan 04, 2011
Freezer not cooling, but fridge works fine
In most cases the problem you are having is a defective start relay, overload and run capacitor. These parts can wear out or the symptons are caused by a defective fan motor. What is the correct model number? Sea Breeze
Sep 25, 2013 | Maytag MFF2557HES Stainless Steel French...
Fan is running but compressor is not working
the ptc overload relay on the side of the compressor is bad unplug it off the side of the compressor and buy a new one plug it back on the compressor,there may be a capacitor associated with this component replace this also
Dec 08, 2012 | Maytag MFF2557HES Stainless Steel French...
I have maytag mff2557hes fridge that seems to run more often than not. Freezer and fridge cool fine but it seems to run all the time. Is this normal?
Pull the unit out from the wall and check the coils at the compressor for lint and dirt buildup. The coils and fan should be free of any debris to operate correctly.
Nov 03, 2012 | Maytag MFF2557HES Stainless Steel French...
Model # MFF2557HES Top refrigator section stoped cooling freezer is working
You may have Ice buildup in the freezer. You freezer has a fan in the bak that sends the cool air to the fridge. Your fridge dial determines how muh cold air comes from the freezer. Try defrosting the freezer. You may have to pull the back panel off of the inside of the freezer to get the ice thawed. The ice build up is likely causing the air to not get to the fridge. Hope it works.
Aug 16, 2012 | Maytag MFD2560HES Bottom Freezer French...
Maytag Refrigerator MFF2557HES - won't stop running, everything frozen... despite adjustment to temp setting What to do, please and thank you?
Possible that the thermostat or the control unit is faulty as it fails to cut off the compressor.In some cases the frost or ice formation can reduce the connection or wire contact of the thermostat and so the function will not work. You need to remove the freezer rear covers to confirm if the wires are intact and also if the thermostat is working along with the auto defrost timer.
Sep 19, 2011 | Maytag MFF2557HES Stainless Steel French...
My Refrigerator and Feezer are not cooling. mff2557hes
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
we
Aug 01, 2009 | Maytag MFF2557HES Stainless Steel French...
Maytag mff2557hes icebox not cold, freezer works.
OK, I will take you to the Maytag Service Library, You will need to put your refrigerator through some self diagnostic to locate the problem, click on link below and let me know when you are ready, Thanks, Sea Breeze
http://www.servicematters.com/maytag_library/docs/16025690.pdf
May 22, 2009 | Maytag MFF2557HES Stainless Steel French...
Everything in my Maytag model MBB1952HEW refrigerator freezes. It is running pretty much non stop now
You will need to replace the control board, which controls the temperature in both compartments, refrigerator and freezer.
Aug 12, 2008 | Maytag MFF2557HES Stainless Steel French...
Re; control board
behind the display control youll find two slots for inserting a screwdriver and releasing tabs that are holding the control up, no screws just 2 press to release tabs, might be a little awkward to feel might have to twist your head in a little sideways to see them. there is or at least should be a tech sheet mounted to the underneath of the cabinet, just behind the kick plate on rightside
Mar 04, 2008 | Maytag MFF2557HES Stainless Steel French...
Maytag MFF2557HES Stainless Steel French Door Refrigerator Logo
104 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
