Question about Refrigerators
Any idea how I can get my fridge freezer working again? fridge was not cooloing properly
    Top Expert:
  • Refrigerators Master
  • 76,109 Answers
Hello. in any refrigerator the most common problem that is the Defrost Timer failing, this causes loss of cooling to the fridge section. Without more specific information it is hard to say what else is wrong.
Posted on Jan 04, 2011
Frezer is working fine but ref side is not cooloing, it appears that the vent are not blocked
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Oct 26, 2010 | Maytag MSD2756G Side by Side Refrigerator
Hello
Sounds most likely it's just dirty, Unplug the fridge and pull it out and check out the coils on the back and or bottom of the unit. The coils need to be free of dust, pet hair, for it to work properly. It is very common reason for fridge cooling problems. If it is an old unit than it could be the coil inside and that would require a bit of work on your behalf.
Please respond back with results and vote if I have helped you in any way Thanks Dan
May 22, 2010 | Crosley CFFH10W Top Freezer Refrigerator
Hi, I have an LG refrigerator, the top freezer works fine but the fridge section has stopped cooling, I turned the unit off and next morning there was a large puddle of water on the floor, when I turned it...
When the fridge is not cooling that means the fan are not working or not working properly, need to replace or check if their is an ice bothering the fan to turn. ok
Feb 15, 2010 | Refrigerators
We have Maytag 25 cubic feet stainless steel double door fridge with pull our freezer on the bottom. The fridge as stop being cooled but the freezer works fine?
There is a defrost problem. Ice builds up between the ref and frz sections and wont allow coolo air through. You can also check to see if the damper is stuck closed
Jun 13, 2009 | Maytag MFD2560HES Bottom Freezer French...
Dandy 8.8 fridge not working but freezer does
freezer works but fridge wont cool
Aug 29, 2008 | Freezers
Bottom Part
Have you inspected the door gaskets .escpecially at the bottom.Make sure your not getting any air through the door seal,Whats the temp in freezer?
Jun 15, 2008 | Frigidaire FRT15G5CS Top Freezer...
Fridge not cooloing right
HI I'M HAVING THE SAME PROBLEM THAT YOU ARE...I NOTICED THAT THE FRIDGE DOOR WAS OUT OF LINE WITH THE FREEZER DOOR AT THE TOP...IF THE FRIDGE WAS EMPTY IT WORKED FINE, BUT WHEN WE REFILLED IT,IT WOULD STOP COOLING AGAIN,I THINK IT'S GOT TO DO WITH THE WEIGHT ON THE DOOR MAKING THE DIFFERENCE IN MY CASE...I BELIEVE IT HAS SOMETHING TO DO WITH THE SWITCH AT THE TOP, INSIDE THE FRIDGE THAT OPERATES THE LIGHT AND THE TEMP CONTROL IN MY CASE.TRY OPENING THE DOOR JUST A LITTLE SO THAT YOU CAN SEE IF THE SWITCH IS BEING FULLY CLOSED...I THINK I'M GOING TO HAVE TO ADJUST MY FRIDGE DOOR UP TO GET IT TO DO THIS FOR ME...WILL LET YOU KNOW IF THIS WORKS!!!!!
Sep 09, 2007 | GE GSL25JFPBS Side by Side Refrigerator
Indesit fridge freezer not getting cold (2 years old)
I would first check to see if the evaporator in the freezer is all iced up. If it is thats whay you do not have any cooloing. And If that is the case you have a defrost problem and it is not short on gas. If you see only a few coils on the evaporator frosted up then you do have a leak in the system and my be covered under the manufactures warrenty.
Jul 14, 2007 | Engel Freezer 22 Qt. Fridge/Freezer
Refrigerators Logo
131 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
