Question about Keurig Elite B40 Coffee Maker
I'm new to the keurig system. I have misplaced the book. I can't remember how to get the water from the resevour to the machine and to heat. Please Help
  • 1,772 Answers
Sorry to read about your problem, I hope this helps you out.
you lift out the reservoir and take off the top cap.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Posted on Jan 04, 2011
When I turn my keurig on(power button) the cold water immediately goes through the system into the cup. we have cleaned the unit but no change. Before this it was working perfectly
It could be the heating element inside the machine. Or I could be the water pump. The water pump pushes the water into a chamber where it is heated up before it goes into the cup. If there is a manual near by, read the part under water pump.
Apr 25, 2015 | Keurig Elite B40 Coffee Maker
Why is the heated water not going through?
Is this a new or used Keurig? If new, get a replacement. If it is an older model, check the discharge hole where it empties into the K-cup for clogs.
Dec 11, 2017 | Keurig Coffee Makers & Espresso Machines
Our brand new keurig mini plus wont heat or dispense water
I had the same problem with my Mini ! I also had this problem with my last Mini which was given to me and I tossed out. So I replaced with the new one which just went on the fritz. Called Keurig who were very helpful and told me to descale, but I explained the machine is almost new. So I prodded them for what else could cause the problem and its water that is too cold.
Turns out the problem is that I was using very cold water and the machine can sense the water is cold and will not heat. It does not heat so it wont damage the heating element. I was using 40 degree water from the fridge.
My symptoms were: I would fill it, that the blue light would flash, I would push the button, then the red light would flash and then nothing it would shut off after a while. Now with not so freezing water it works fine!
Hope this helps as I threw out a good machine because the water was too cold!
Jan 22, 2013 | Keurig Mini B31 Plus Red Coffee Maker
I have the platinum B70 Keurig coffee maker. The hot water is backing back up into the water resevour. It says to descale it, however i've been descaling with vinegar all day and it hasn't helped. I did...
The top needle is part of a check valve. This valve sticks now and then. Lift the handle to open position. You need to remove the long black cover between handle to expose valve. There are two silverish screws upside down by top needle. You might have to put maker on its side to see them. (UNPLUG FIRST) Remove the screws and stand the maker up. Pull the black cover to you and out. Now you can see the valve.Carefully cut zip tie securing supply tube to valve and remove tube from valve. Carefully, using a paperclip push down the ball inside the valve. You will have to bend the clip to fit. It wont take much pressure to move it. I suggest removing the valve via the two screws now. That way you can blow in the end where the hose was connected to see if you got it or not. When done, re-assemble. Good luck!
Feb 01, 2011 | Keurig Special Edition B60 Coffee Maker
We purchases a new Keurig coffee maker and tried to set it up for the first cup of coffee. the menu and add water prompts came on; however, it never heated the water. It is now continually flashing not...
you can contact Keurig at 1-866-901-2739 or Keurig.com
You do have a 1 year warranty, and if you are out of warranty. They will give a discount on a new unit.
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 22, 2010 | Keurig B50 Coffee Maker
I have a Keurig B66, the reservoir water gets heated but then comes back into the water reservoir from the top vent tube. The water coming back into the reservoir is very hot; almost no water goes into the...
ds
sdf
s
fs
f
Dec 22, 2010 | Keurig B60 Coffee Maker
My keurig b200 is stuck in the mode saying that is "heating please wait" nothing seems to be happening i dont have the user maual. is there a way to reset the machine?
It is most likely the 12v air pump not working. It doesn't provide the air pressure to pump the water into the heating canister and, thus, the unit will try to heat the water indefinitely. See the following forum; it's about the B70 but much useful info, including sources for the air pump that you most likely need: http://www.singleservecoffeeforums.com/dissassembly-repair-guide-keurig-b70-platinum-t8124.html
FredF
May 06, 2009 | Coffee Makers & Espresso Machines
Keurig Elite B40 Coffee Maker Logo
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
