My vaillant boiler is displaying fault f.22 - Heating & Cooling
  • 1 more comment
  • D4Danny Nov 23, 2008
    My Vaillant boiler is displaying error F.22. This meant no hot water and also the radiator is not hotting up, any idea or help will be much appreciated
  • caledonian63 May 10, 2009
    How do I fill and how much water do I add to my Vaillant eco tec pro 28?
  • Anonymous Mar 26, 2014
    intermittent fault boiler stops no h.w. no heating on refiring boiler both heating and h.w. restored . few days later same thing happens
Have you topped the system up with water? The pressure gauge should be showing an operating pressure of 1.5 Bar in the green section.
Posted on Jan 13, 2009
Got a f.75 on boiler have to put pressure up to 2.0 bar before it starts
I take it this is a Vaillant EcoTec boiler? If your having to pressurise to 2.0 before the F75 goes, there's a strong probability there's a problem with the water pressure sensor. These can sometimes just have dirt/sludge in them, and can be cleaned, however a lot of the time they just need to be replaced. F75 can also mean there's a circulation problem through the boiler, and you will get the same fault code. If you have the old rubber hoses on the flow and return pipes, these can be prone to blocking/restricting and Vaillant have actually modified this part whereby by the pipes are solid copper.
Dec 04, 2012 | KDS Valiant 6380iPTD-01 Notebook
I have a Vaillant ecoTech central heating boiler which has stopped working & is showing fault code F.76 Anyone know what this means please? Thanks
f76 over heat protection triggerd on heat ecxchanger , check water leval of just google vaillant fault codes
Jun 03, 2010 | Heating & Cooling
Code f28 what isit?
According to the user's guide, the fault code means that the boiler failed to start after 5 attempts. Here is the manual where I got the information. I would confirm the codes with your particular model. I am presuming that the codes would be standard for all their models. Source(s): http://www.vaillant.co.uk/stepone2/data/…
Mar 10, 2010 | Water Heaters
Vaillant Combi boiler
LOOK ON ONE OF THE COVERS 75% OF ALL CODES ARE ON THE INSIDE OF A COVER FOR SERVICE TECHS, NOT MUCH HELP BUT HOPE IT LEADS YOU DOWN THE RIGHT PATH
Jan 23, 2010 | Heating & Cooling
Hi i get fault 28 on my vaillant boiler
F-28 is a common error for my vaillant. I have had this problem serviced at least 10 times (all under warranty). It is an ignition problem and can be connected to a number of things. I have had the starter electrodes cleaned only to later have them replaced(4 times). I just had the "panel" replaced yesterday (looks like a motherboard or electronics panel). This is the second time to have this replaced. All of these things can give you an F-28 error message. I have an atmotech pro and have had ongoing F-28 issues for two years. They are looking at venting/air issues as well to see if this is the problem. douglas
Dec 20, 2009 | KDS Valiant 6380iPTD-01 Notebook
My parents have a Vaillant Ecotec 831 boiler. Has continually broken down ever since it was fitted nearly 2 years ago. The guy who fitted it keeps coming out and it works for a few days then packs in...
Get vaillant to look at it. It could be installation fault. Their advise is impartial and they can advise if boiler can be repaired.
devinder
Corgi engineer
Oct 14, 2008 | Heating & Cooling
Vaillant Boiler time switch no user manual
http://www.vaillant.co.uk/stepone2/data/downloads/9a/42/00/timeSWITCH_120.pdf
Nov 04, 2007 | KDS Valiant 6380iPTD-01 Notebook
Heating & Cooling Logo
1,373 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
