Question about Frigidaire Dishwashers
I used it before but now no water is going in it. What should i do?
  • Frigidaire Master
  • 43,501 Answers
Here is a tip that will help you to find out why water will not come into the dishwasher...
Dishwasher Trouble
No Water entering Dishwasher
heatman101
Posted on Jan 04, 2011
Why is water going into the drum when not in use
Hi, it sounds like the water inlet valve is faulty and not completely closing and allowing water to pass through when it should be closed. You will have to get it looked at or replaced.
May 17, 2016 | Hotpoint Washing Machines
Can u use water softner pellets direct in to water
Water softener salt is used to regenerate a water softener after the softener has been in operation for a few days removing hardness from the water. If you were to only add the salt to your water you would still have hard water but now it would become salty. Go to youtube and look up How does a water softener work? If you want to buy one go to wqa.org and find a Certified Water Specialist close to you. He or she will be one of the only 5% of water treatment people who have received formal training in how to fix your water. There is a lot that can be done to improve your water.
Oct 18, 2014 | Morton Salt Inc 15010000 Water Softener...
Does anyone know Why the hot water does not go into the machine when using warm water selection, hot water is in hose but not in machine ?
The hot water valve is not opening. This could be the valve or the timer. What make and model and year is it?
Sep 12, 2014 | Washing Machines
I am going to start a small business, which i am going to clean bins. so i am going to use water, so i would like to know where can i get rid of the contaminated water that i am going to use once i have...
I would buy or find a huge water tank and drain the contents into it once its half full por wood shavings or an absorber in to dry it out,or if you filter the water you can use the water for plants,shrubs..
Oct 29, 2013 | Dyson DC27 Total Clean Dust Bin Container...
Metallic tasting coffee
You need to look in your manual and descale the unit. When you do this, make sure you use vinegar and water. This will take care of most of that. Also when filling your machine with water, if you use bottled water or going through a good water filter system will help this. So, between descaling the machine, with vinegar and water, and filtered water will help this go away. Thanks Mike
Please rate my solution if this was helpful. Thanks.
Sep 30, 2011 | Keurig B70 Coffee Maker
How do i clean my iron so brown dirt won't come out of it when i iron
Brown water and white scale are often the result of the water you use in the iron...
If you have scale, white vinegar will clean that...
For brown water, empty the iron, rinse out the insides with bottled water,
and then use the bottled water instead...
Also check out this tip...
Cleaning a Steam Iron White Scale and Brown Water
heatman101
Mar 23, 2011 | Sunbeam Vacuums
Do you use hot or cold water. It doesn't say in the manual
I have used both hot or cold water....but have found that hot water works best to rinse the starch off and also makes the cooking process go faster...
Here is a tip that will help you figure out about using a rice cooker...
How much Rice and Water go in the Cooker
heatman101
Feb 23, 2011 | Black & Decker Black Decker RC3406 6Cup...
How much roundup do i put in 3 liters of water
Round up is currently offered in a few variations. If you have the "Spray and GO" or the "Spray and Go" refill product do not add water. The ratio is already correct. Likewise for the "Redy-to-Use Plus", do not add water.
If you have the "Weed and Grass Killer Concentrate Plus", the ratio is 3oz/gallon water. 3 liters of water=0.79 gallons so use 2.4 oz of this type of Round Up.
If you have the "Weed and Grass Killer Super Concentrate", the ratio is 1.5oz/gallon water so you would use 1.2 oz of product mixed into 3 liters of water.
If you have a different product and just need to work out the conversion from gallons to liters, 1 gallon=3.78 liters.
Hope this helps.
Dec 31, 2010 | Roundup "" Weed & Grass Killer
Water not going into icemaker. Water dispenser works fine.
Check the water valve at the back of the fridge if present.
Even if you used blowdryer, ensure that linse are not frozen by performing a complete defrost.
Disconnect water lines from icemaker, and blow with compressor if the above did not work.
May 20, 2009 | Kenmore Refrigerators
Dishwashers Logo
41 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
