Question about Canon PowerShot A560 Digital Camera
I have good batteries in my camera but when i turn it on it makes a clicking sounds and sometimes it says change batteries. What is the problem?
    Master:
  • 340 Answers
Is there another Canon PowerShot A560 battery? If all of your batteries are of the same question, maybe the problem is on your camera. In many cases, this problem is caused by the bad contact, clean up the contact place of the battery and the battery box. And have a try again.
Posted on Jan 04, 2011
Kodak camera easy share does not turn on
Is battery good? does switch feel like it clicks sounds like a power problem batteries go dead after a while and contacts get dirty. make sure you have a good touch of battery power.
Sep 06, 2012 | Kodak Easyshare C813 Digital Camera
Engine do not start (no cranking), only the sound of clicking (relay??). All indicators are normal (lights up), battery good (tested by turning on headlights, blowing horn). Happens after turning off a hot...
Hi:) That sound like the solenoid is the problem it is located on the starter and if the solenoid is not working right it will do all the things you are explaining.And yes heat has alot to do with it and being ware out.If it is the original it is time to replace the starter anyways it's 16 years old.
Mar 08, 2011 | 1995 Toyota Corolla
Car has been starting eratically. every now and then when i turn ignition i get a click, click, clicking sound with no engine turn over. i'll do this several times. sometimes the car will turn over in 5...
CHECK BATTERY CABLES FOR TIGHTNESS AND MAKE SURE BATTERY POST ARE CLEAN FREE FROM CORROSSION CHECK BATTERY VOLTS. SHOULD BE 12.6 VOLTS.IF NOT. HAVE BATTERY TESTED.BEFORE REMOVING NEGATIVE BATTERY CABLE TURN OFF RADIO FIRST SO YOU WONT LOCK OUT RADIO.IF ALL IS GOOD STARTER SOLENOID OR STARTER FAULTY OR BATTERY GROUND CABLE COULD BE BAD.
Dec 11, 2010 | 1999 Oldsmobile Alero
My camera wont turn on.
If the lens is stuck inside the camera and you hear a motor noise - changing batteries will not help. This has happened because the lens barrel is jammed inside the camera. Unfortunately, you will not be able to repair that issue. If the lens is stuck outside the camera, slightly tilted, and you hear a motor noise; you might be able to save camera. First, only use good batteries (stay away from alkaline batteries - waste of money), go with Energizer Lithium or Duracell Power Pix (you will get your moneys worth and have less problems with the camera). Second, very GENTLY, pull the lens barrel up and in the opposite direction of the tilt (to make the lens barrel straight), you will hear a slight click sound - DO NOT PUSH ON THE LENS BARREL!!!. Put in the new batteries and the lens should retract.
Oct 06, 2009 | Polaroid i733LP Digital Camera
Depressing the button, it clicks but doesnt take photo
Go to all your settings in the menus and reset all to default. Then when things are working, set the settings as you like.
Make sure the battery is good and full charged. If not, may cause some problems.
Sep 25, 2009 | Nikon D40x Digital Camera
My 1999 new beetle won't start
Sounds like the battery is dead..Sometimes you have to clean the jumper cables and terminal on the battery to make a good connection try that and let your battery charge for a few minutes before trying to start it. If that doesnt work you may have a seized starter! Good Luck!
Sep 15, 2009 | 1999 Volkswagen Beetle
1997 Spyder will sometimes not start. There is a click sound when turn key but thats it. Then later it will decide to start.
SOUND LIKE DEAD BATTERY.IT THE BATTERY VOLTAGE SHOULD BE 12.5 VOLTS.IF NOT.CHARGE BATTERY OR REPLACE IT.IF BATTERY CHECK OUT GOOD.MAKE SURE BATTERY CABLES IS TIGHT AND FREE FROM CORROSSION.IF ALL IS GOOD.TURN OFF RADIO SO YOU WONT LOSE CODE TO PLAY RADIO.REMOVE STARTER.HAVE IT CHECKED AT AUTO ZONE OR ADVANCE AUTO FREE.ALSO MAKE SURE YOUR ALTERNATOR IS CHARGING.IT SHOULD BE 13.5 TO 14.5 VOLTS WHILE CAR IS IDLING.DO THIS TO MAKE SURE THIS IS NOT THE REASON YOUR BATTERY GOT WEAK.
Sep 03, 2009 | 1996 Mitsubishi Eclipse
Wont turn on!!!
My problem is this; i changed the battery after i had signal that battery should be changed. I changed the batteries with new one but when i press the on/off button, the camera will turn on.
I put in new batteries again and is still the same problem.
Mar 11, 2007 | Vivitar ViviCam 3765 Digital Camera
Canon PowerShot A560 Digital Camera Logo
56 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
