Question about Goldstar MV-1515 Microwave Oven
Door has two cracks on bottom rail. How do I get replacement door?
  • Goldstar Master
  • 43,501 Answers
That is not that hard to fix and you can easily buy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy
Appliance Parts Online
heatman101
Posted on Jan 04, 2011
Door frame on microwave broke apart
If it is out of warranty, I'd just buy another. Most repairs would cost more than a replacement nowadays.
Nov 13, 2013 | Maytag MMV5208W Microwave Oven
Neff H7871 oven door does not stay closed. Catches do not appear to be working
The door latch is either cracked or broken.The door when gets closed the door latches clicks.But if the door latch is loose or cracked it will not click and door will not close.The door needs to be disassembled and the door latch has to be replaced, if the latch is cracked.Also to check the latch from inside the door needs to be removed.-------- This will help.thanks.Helpmech.
Jun 29, 2011 | Neff Microwave Ovens
There is a whirlpool Microwave (model:MH1150XMB4) in our apartment. Unfortunately, there is a crack in the door. Although the crack is only in the plastic frame of the door, the landlord asked us to...
Got the same problem. Still inquiring but I might have found a solution here : http://midwestapplianceparts.com/microwave-parts-537/whirlpool-microwave-parts-648/microwave-door-panel-663/whirlpool-microwave-door-panel-w-glass-4212.html
$79 for the panel only
Jul 01, 2010 | Whirlpool MH1150XMQ Microwave Oven
Faceplate of door by lower L/H hinge cracked. How do I remove the door to replace the Faceplate?
Front doors are attached inside the microwave at the top and bottom of the oven cavity. Top case has to come off using, likely, security torx screw drivers.
Remove the top hinge.
Remove the bottom hinge.
Door falls off.
Replace the front panel of the door.
Reinsert the lower hinge with the door, close and latch the door.
Holding the door firmly to the microwave, tighten the door hinge. Replace the top hinge.
(On some units, both hinges need to be installed at the same time. Use masking tape to hold the lower hinge - makes it easier.)
Apr 19, 2010 | Sharp R-1490 Microwave Oven
Broken door handle
The in side door panel ( at total pain) must come off
If the damage to the bottom is not too bad.
On mine I took the cover for the handle loose from the bottom ( it pops off, but be careful).
and put screws at the bottom
Jan 12, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Front Plastic door is cracked and needs replacement.
Do not use a microwave with a cracked door as it could be emitting dangerous microwaves.
Sadly the cost of replacing the door would be more that the cost of a new microwave. Look for a good sale and treat yourself.
Jun 11, 2009 | Microwave Ovens
How to replace the whole door unit
This should be a fairly simple procedure. To replace most microwave oven doors, all you have to do is open the door as wide as it will open and then lift straight up. The door will come off the hinge mounting pins and lift off. Install the new door by holding it in the open position and aligning it properly on the hinge pins. NOTE: On some models, you may have to remove the upper trim above the door. I hope this helps you. Let me know if you have further questions.
Jan 03, 2009 | Maytag MMV5000 Microwave Oven
Microwave door tension spring
See answer here http://www.fixya.com/support/t265705-microwave_door
in different thread.. Basically have to pry plastic trim ring off inside of door with putty knife (careful, it cracks easily) to get to screws on bottom of door. See second pic. Top screws are easily accessible from inside of door. Spring can easily be replaced by hand once you get adequate access. You'll need a fairly stubby right angle screwdriver (I used a cut-down #2 Phillips bit and small Vice-Grips as a make-do) to get to the screws. Also need Torx (T10, I think) to detach the shock absorber doodads from the door where they attach above the hinges. If you're just starting to take the door apart, be careful when you take out the top 2 screws on the inside-- they hold the inside plastic piece on , but they also hold the whole outer stainless/ glass/ handle piece on. It just slips in at the bottom, so be ready to slide it out when you take these screws out.fea33aa.pngc391898.jpg
Dec 16, 2008 | KitchenAid KEMC377K Convection / Microwave...
Door crack
Doors can be purchased, but they usually aren't cheap. Door panels can be purchased, but usually only the INNER panel. You can also get the door latches and handles. I don't know, however, if Sharp has any of the outer door components available without having to purchase a whole door. Refer to your owner's manual to see if there is a part listing index. If you can't find any part information, post back with your complete model number (located around the door opening) and I can see if I can find a part number for you. Hope this helps you.
Feb 07, 2008 | Sharp R-1500 Microwave Oven
Door spring
this model is very tricky you will damage the inner frame if your not experienced ,call for service and save your money,there are 2 springs inside the frame that criss/cross and they may look alike but are not,when you undo the screws the door glass will let go and fall to the floor if you don't know and crack the inner fram assy. thats plastic ,there are 4 screws that hold the door together that you can see and 2 more inside you can't. the 2 on the bottom of the door that support the glass are hard to getat.the micro wave oven can be seperated from the bottom unit and pulled foward for access of screws.
Nov 30, 2007 | KitchenAid KBMC140HSS Convection/Microwave...
Microwave Ovens Logo
83 people viewed this question
Top Goldstar Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
SHARCNET-USA
SHARCNET-USA
Are you a Goldstar Microwave Oven Expert? Answer questions, earn points and help others
