Question about Sharp Heating & Cooling
I have a Sharp Model AY1204J Serial No. 5101022 which leaks water from the front of the unit onto my carpet. How do we stop this?
  • 2,133 Answers
Common problem! Water leaks due to :
1. Indoor coil and airfilter dust blocked-clean it.
2.Drain pan blocked.- clean it.
3.Less rpm of fan motor.-check and replace capacitor.
4.Short of gas.-check leak and arrest. And re charge gas.
Posted on Jan 04, 2011
How do I know if I have leaking heater core unit in my 2005 chev equinox
You have a leaking heater core without any question. You can temporarily disconnect the hose that runs to it and connect it onto the return , this will bypass the heater till you fix it.
Aug 10, 2014 | Metra 40-cr10 2005-2008 Chevy Equinox Ls...
My 1999 jeep cherokee is leaking on the passenger floor board. how can i stop the leak?
what is leaking onto the floor? water? antifreeze? if its water and you have a sunroof it might be the drain tube for the passenger side of the sunroof has popped off and the water is running down the inside of the 'A' pilar and onto the carpet,if thats the case you will have to take down the headliner and take a look.hope this helps
Oct 12, 2010 | Jeep Cherokee Cars & Trucks
Dish washer leaking water from the front
And onto the carpet. We stopped using it. Help!
Sep 26, 2010 | Kenmore Dishwashers
Leaking water on spincycle
I have the same problem with my washer. The problem just began a few weeks ago. It is splashing out the front left corner of the tub and running down the inside of washer and then leaking out the bottom of the frame. It is just enough water to be annoying. The washer is about 6 years old.
Model: FAV6800AWW
Serial: 11277017EG
Any ideas??? Help!
Jul 27, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Where is the condensation pan located on a GE artica?
Look under the unit and replace the condensatin pan back in place. This should stop the leaking onto your carpet.
Sep 04, 2009 | GE GSS25JFM Side by Side Refrigerator
Dripping air conditoner
The "drip pan" is actually the entire base srround of the unit. There are two critical things you must confirm 1) is the unit angled back to the outside(you need water to flow away from the inside) and 2) there may be a plug/obstruction in the outer casing where the water is intended to drain from. You should check to see if either or both of these conditions exsist.
Aug 19, 2009 | Heating & Cooling
Sharp CV-P10NC AC unit it has a puddle of water coming down.
earlier models had a pan you had to empty .. your model has a small pump that is supposed to pump the water out the hot air vent (that goes thru the window} .. since its leaking it is likely that the pump inlet is clogged ... you might have to remove a panel to get at that ... it will be near the bottom of the unit (near the drainage nozzle) ... also check the hose that goes out thru the outside vent .. make sure its not cracked, clogged or smashed ... temporarily you can use the drain nozzle to drain off the water to a lower area (it cant drain up without the pump) ...
Aug 17, 2009 | Sharp CV-P09FX Air Conditioner
I have a Hoover Steamvac model #f5888-900. Recently, after finishing use, it leaks a lot of water from the bottom of the unit onto the recently cleaned carpets. Do you know what would cause this spewing...
Either the rod in the handle is holding and not releasing the resevoir asm, this where the tank sits on, is bad. So water is not being shut off completely when off.
Apr 14, 2008 | Vacuums
Air conditioner leaking
Hi, There are no pipes, just passage ways on a window unit. It probably needs cleaned. Window units naturally create water in the evaporator area. The water is suppose to drain to the back of the unit through passage ways to the condensing area where the slinger ring on the condenser fan blade slings it into the condenser coil making it more efficient. There is usually a drain hole to drain excess water from the back of the unit. Any dirt or algae in the pathway of this water or the wrong tilt will cause water to build up and drip or blow out the front. Anything touching the evaporator coil allowing water to run down the obstacle into the wrong area will cause the same thing. reduced air flow will cause the evap to freeze which could also cause a water problem. Since the tilt is right and it doesn't seem to be freezing, Maybe a temporary increase in tilt and a dropper of bleach at the base of the evaporator would do it. This will kill the algae and may unblock the water flow. NOTE: It may also cause stains on a carpet or floor if the bleach water drips onto it. If you want to pull it out and clean it, most units can be pulled out of the housing and sprayed with a water hose but you need to be careful not to get water in the electrical parts of the unit. They can be covered with plastic or foil. Make sure you unplug the unit before trying to remove it. You may have to remove some screws to remove it from the housing. Hope this has helped. kstfas
Sep 19, 2007 | Sharp AF-S120FX Air Conditioner
Heating & Cooling Logo
251 people viewed this question
Top Sharp Heating & Cooling Experts
AJMAL KHAN
Tim Whalen
Brandon Berry
Brandon Berry
Are you a Sharp Heating and Cooling Expert? Answer questions, earn points and help others
