Question about Husqvarna Garden
Where is the clutch locater on husqvarna cth151?
  • Paul Sikkema
    Paul Sikkema Jan 13, 2011
    The CTH151 has a "clutch" for the blade. It is an electric unit attached to the bottom of the motor. You engage the clutch when you pull out the blade engage button on the dash.
    It does not have a transmission drive clutch. When you step on the parking brake it releases the tension on the belt from the engine to the transmission. This acts like a "clutch" for the drive system.
    Feel free to ask any other questions. Please remember to rate this answer!
2 Suggested Answers
  • 2239 Answers
SOURCE: how do you fit a
There is a schematic sticker on the under side of one of the foot wells to show the belt orientation.
Posted on Apr 29, 2011
Husqvarna problems
There are so many reasons for this it could take all day! First check the safety cut-out switches: seat, brake, drive lever and blade control, etc. Then check the battery leads and connections are clean and tight at the battery, starter solenoid and starter. If still no luck make sure the engine will actually turn over by removing the spark plug(s) and turning the drive pulley. Good luck!
Jul 15, 2014 | Husqvarna Garden
Husqvarna h2201-18 reel mower blades wont turn
I have the same mower and had the same problem. You need to install a new clutches part H2201-18-05. They're located beneath the wheels which you'll need some snap ring pliers to remove.
Sep 03, 2012 | Husqvarna Garden
How do you fit a Husqvarna CTH151 belt Thanks
Apr 28, 2011 | Garden
How to get the clutch off on a 142 husky
  1. Turn off the saw and release the chain brake. The chain brake is the plastic handle located on the topside of the saw's body, and is between the bar and the throttle. With a gloved hand, spin the chain to ensure the brake is off.
  2. Use the wrench to loosen the bar nuts until they are finger tight. Use the flathead screwdriver to loosen the bar tensioner screw. This screw is located in between the bar cover's two metal posts, and can be reached through the small, round hole in the cover's center.
  3. Finish loosening the bar nuts and remove the bar cover. Take off the bar and chain; set them aside in a safe place.
  4. Unplug the spark plug from the rubber spark plug connector, located on the top of the saw's body. Push some of the chainsaw's starter chord string into the spark plug cylinder to block the piston from moving while taking apart the clutch.
  5. Remove the clutch assembly with the clutch socket wrench. Husqvarna chainsaw clutches are left-locking nuts, so you will need to turn the bolt clockwise to loosen it. Tap on the socket's handle with a hammer if the bolt won't loosen.
  6. Remove the bolt and pull off the clutch cover, clutch spring and clutch drum. Replace these parts if they are chipped, warped or heavily worn.
  7. Follow these steps in reverse order to reassemble the clutch.
Nov 15, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
I want to know where the oiler is on the husqvarna 141
Bill if you indicated the model in your question it did not appear here. Without it we can only provide our best guess. Most Husqvarna oilers are mechanical pumps and are located behind the clutch (99/9% of clutches have a left hand thread, please verify before you attempt removal).
You can locate an OM and IPL (exploded parts list, useful for disassembly and part numbers) here:
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – useful when downloading IPLs and Manuals
06 1500198
06 = year produced – 2006 (single digit before 2000; please contact Husqvarna for single digit clarification http://www.husqvarna.com/us/homeowner/support/customer-support/)
15 = week produced – March
00198 = 198th unit Husky produced that week
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Jul 17, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
CTH151 lawn tractor stopped dead. Nothing happens when I turn the key. Is there a series of micro switches to check?
There are four micro switches on this mower. Go to www.gardenresources.co.uk/ Look at the bottom of the page for husqvarna tractors, then to further reading, click on husqvarna manuals, click on husqvarna ride on mowers, then click on cth151 xp. It will bring up the operator's manual in PDF format. About page 23 it should have a diagram showing the electrical part of the mower.
Hope that helps mate
Dec 27, 2009 | Garden
Garden Logo
210 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
