Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
KitchenAid Superba refrigerator We need a new black plastic part where the ice comes out
Where do we buy it?
    Sergeant:
    Champion:
  • 330 Answers
Sometimes it is the dealer item.
Posted on Jul 10, 2008
KitchenAid fridge ice cubes taste and smell bad
Permanently place a black coal in your fridge to avoid bad smells.
Apr 12, 2012 | KitchenAid Superba Architect KSCS25INSS...
Kitchenaid superba the ice maker not filling up and making ice
dear owittione perhaps the tray if its plastic maybe its cracked and the water drains out while filling check to see if there is a clump of ice in the bin and if so replace the ice tray no if is metal maybe the same thing is happening also check for the clump of ice in the bin. Now if you dont hear any water going in the ice tray maybe the magnetic valve in the back of the fridge is bunded out or the hose from the tap to the valves has a leak or the hose from the valve to the ice tray has a leak . Check around for water puddles if formed. Those are the probable causes that can lead to your problem ofcourse if the refrigerator over all is working fine. good luck. Regards Tony.
Dec 02, 2011 | KitchenAid Superba Architect KSCS25INSS...
Ice maker won't stop making ice
Replacing the switch that senses the ice should solve your problem. CLICK HERE for rthe electronic switch assembly. It comes with the transmitter and receiver and needs to be replaced as a set. They are replaced from the front of the machine directly in front of the icemaker, mounted on the backside of the plastic pieces where the flapper and on/off switch is.
Jan 13, 2011 | KitchenAid Superba Architect KSCS25INSS...
Water leaking
the plastic tray is either cracked or the busing is worn out. ice is building up in the catching tray and is one large ice cube?
Feb 16, 2010 | KitchenAid Superba Architect KSCS25INSS...
Icemaker not making ice in refrigerator.
clean the coil behind the fridge or under the fridge (where ever they are) and make sure both fans are running, the one in the freezer and the one underneath the freezer needs to be0/4degrees to start if not that cold may need freonor compressor my be weak.
Aug 09, 2009 | KitchenAid Superba KFRS361TSS Stainless...
Water overflowing in ice maker.
I just replace my kitchenaid icemaker. My model is 4317943. And it comes with a sheet of menu. I scan a portion and hope it will help.
Apr 20, 2009 | KitchenAid Superba Architect KSCS25INSS...
Need to remove front black plate cover on my kitchenaid
MOST OF THEM YOU PRIME A FLAT SCRUE DRIVER ON THE FRON LOWER PANE THE Y HAVE TWO SMAL SLOTH AND TWIT THE DRIVE AND THEY WILL COME OF AND DO BOUTH SIDESRT AND LF.
Jan 25, 2009 | KitchenAid Superba Architect KSCS25INSS...
Kitchenaid side by side model ksrs25ikss01
CHECK YOU SECOND VALVE IS WORKING IF THATS OK YOU MIGHT NEED YOUR ICE MAKER CHECKED AND SERVICED.GOODLUCK.MOHAMED
Sep 06, 2008 | KitchenAid Superba Architect KSCS25INSS...
Ice maker
reach your hand into ice maker assy, is there ice in it and not ejecting??? there are tines that eject the ice, do these move around freely and easily(if so you need a new ice maker they should not turn by hand)
Feb 23, 2008 | KitchenAid Superba Architect KSCS25INSS...
Need to replace direct drive drum on Kitchenaid Superba side by side
May need to know your entire model # located on the inside in the refrigerator section. That plastic piece may unscrew but be a reverse thread.
Oct 07, 2007 | KitchenAid Superba Architect KSCS25INSS...
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
166 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
